Old 09-10-2013, 12:40 PM   #57
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by phloozy View Post
Just ordered then saw this. I ordered the standard, was that wrong?
I ordered the standard too and when I got it and looked at it, I thought it was dead wrong but it's not. It fits and works.
Sent from my HTC One X using Tapatalk 4
Old 09-10-2013, 12:55 PM   #58
phloozy
phloozy's Avatar
Drives: Scion FR-S
Also just realized you cant use the smartcord with this? Do you just mute from the radar detector?
phloozy is offline   Reply With Quote
Old 09-10-2013, 12:56 PM   #59
Sportsguy83
Drives: Limited BRZ
Yeah, just press the mute button. No biggie.
Old 09-10-2013, 12:58 PM   #60
phloozy
phloozy's Avatar
Drives: Scion FR-S
awesome thats the plan then
Old 10-10-2013, 04:19 PM   #61
mainstream
mainstream's Avatar
My Escort Max Directwire Install
Great guide, I used this with post from others to hardwire my Passport MAX radar detector
Just some clarification for those FR-S users that don't have the auto dimming mirror or even if you do, you can make the connections on the male (car side) and not the mirror side.
I bought my direct wire cable from ebay for $8.95 with inline fuse
http://www.ebay.com/itm/Escort-Radar...item2c7252d817
find the mirror connection cable to right once you remove the light housing
mine was taped down (I guess to prevent noise)
turn the now loose mirror cable so that the gray wire is on the left...
feed the red wire into the left slot where the gray wire is... feed the black wire from the direct wire cable into the middle slot of the mirror power where the black wire is.
When you feed the wires in depending on how you do this they should be snug so it may take a few attempts.
I secured it using a rubber band, you might want to use a small tie wrap or electrical tape. That way when you tug on the cord when moving your radar connector these connections won't come loose.
Result:
mainstream is offline   Reply With Quote
Old 12-04-2013, 04:54 PM   #62
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Result:
Is that cable long enough? I see you put on your radar toward on the passenger side? is it hard to see while you driving?
Old 12-20-2013, 04:20 PM   #63
mainstream
mainstream's Avatar
I wanted it in a place that wouldn't obstruct the windshield visibility, I initially wanted to put it below the mirror with a special mount. But decided this is better as it is not as visible from outside the car, kind of looks like part of the mirror mount from a distance. The escort max is a big radar detector and positioning is difficult.
I have no problem seeing it, and actually it being next to the rearview mirror is not as distracting as you would think, since you are checking your mirror often anyway.
Old 01-07-2014, 05:22 PM   #64
pseudo
pseudo's Avatar
Drives: 2008 Cayman S
I am a little confused by some of these statements...
Originally Posted by gmookher View Post
so where youre tapping thats 5v?
Originally Posted by Norkoastal View Post
...I opted for the 12V glovebox install since this plug cant power the concealed display and RD.
Originally Posted by Zardoman View Post
So this DIY is basically to get 12v power with minimal wires exposed?
Tapping the mirror is 12v with a 10A fuse, right? Is it true that this setup cannot power the valentine one concealed display? If that is true, could you just bump up to a 15A fuse?
pseudo is offline   Reply With Quote
Old 02-06-2014, 02:22 PM   #65
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
For those who want to use the power source in the glove. I took this route.. radar>>8ft phone cable >> 4pin phone jack coupler >> radar power cord >> cigarette lighter in glove box. Spent forever before this option looking for a cigarette lighter w/ a phone jack adapter.
mmmcambelsoup is offline   Reply With Quote
Old 02-06-2014, 07:29 PM   #66
modena
modena's Avatar
Drives: BRZ Limited WRB MT
Ran my V1 power cord on the drivers side, needed power from the ODB2 port.
Using the V1's Bluetooth and SAVVY adapter.
Running YaV1 app, and have GPS lockouts, custom sweeps ext.
This setup removes almost all false and bogus treats and makes the V1 a whole lot less "Chatty"
KartBoy SS | BlackVue DR550GW | Valentine1
GrimmSpeed MC Brace | GrimmSpeed Hood Struts
OEM Armrest | OEM STI Badges | 20% Tint
Rydeen duo | Halo's as DRL
Rexpeed Wide Mirrors
modena is offline   Reply With Quote
Old 02-07-2014, 04:48 AM   #67
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I just used this tutorial to hardware my 8500 x50. Thanks! I still haven't decided where I want to put a mute button...just a personal hold up haha, I'm picky about where things/buttons go
Old 02-07-2014, 01:26 PM   #68
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Result:
What is that mount? Is it specific to the escort or something aftermarket?
Ranatsu is offline   Reply With Quote
Old 02-07-2014, 09:25 PM   #69
continuecrushing
The mount holding the escort max is Escorts newest suction cup mount. I believe it only comes with the Max, currently.
Old 02-08-2014, 09:43 AM   #70
mainstream
mainstream's Avatar
Mount
Standard escort max mount... They are a new version should work with any escort
diy, radar detector, speedracer38
Direct wire radar detector Kieranz Electronics | Audio | NAV | Infotainment 25 11-02-2015 12:01 AM
Mounting a radar detector Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 24 02-06-2014 12:39 PM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 01:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
Mounting radar detector video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 10 06-07-2012 11:29 AM
