#57 | |
Kuruma Otaku
I was looking at adapting some QA1 dampers to my Supra, and they provide damping curves and re-valve kits for all their shocks. But the less-expensive non-adjustable ones you would have to rebuild and change shim-stacks instead of nifty clickers. But didn't know what starting point would be suitable. I get that high speed is more impact related and low speed is more weight-transfer, but what do the numbers mean and how do they relate to the spring rate/unsprung weight? (check that, they used to have the curves on their site, can't seem to find it now...) Edit: Saved earlier.
Because titanium. Last edited by Dimman; 11-30-2011 at 03:28 PM. Reason: Edit... |
#58 |
Yup there is a balancing act on our end for sure on releasing data to help people make informed decisions and doing other companies R&D for them. But generally we lean towards releasing the info when people ask because the companies that have the knowledge to actually use the information usually could just do it themselves at that point.
We are very close with Ohlins and JRZ....we used to be located in the same building as east coast JRZ USA and learned a lot about shocks from Bryan. Ohlins we've worked with for years. Those two alongside AST generally make up what we do for higher end race applications. We also work with Bilstein and hope to have some good monotube offerings from them on the more affordable side of things that function better than other entry level stuff from Europe, Japan, or China. We also have a few things up our sleeves for our custom KW options that should be very nice (in the mid-level and higher end of things). - Andrew |
#59 |
Hot Dog
Drives: quicker than arghx7
I'm sure there are fomulae to predict the correct damping force per spring rate based on motion ratios and sprung/unsprung weights, however I don't have that information, nor am I a damper dyno expert.
Since every car, and even every trim level within the model lineup are slightly different, I'd approach "ideal damping" a bit differently. I'd put suspension stroke linear sensors and accelerometers at the hubs and chassis to measure the "Q" of the bump response. I'd then back it up with seat time at the track and referenced street sections to ascertain low, medium, and high speed bump and rebound response. Of course, you could do it like so many race teams do; get out on the track with timers and see what goes quick and what doesn't. With enough testing time, you can narrow down what settings work best for your car and your driving style. -->Dimman: With your Supra, you may want to have QA1 dyno your existing dampers, and use a deduction based on new spring rates and personal preference as to what new damper curve they should shoot for.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#60 | ||
Drives: 2007 Impreza Wagon
If I end up getting one of these, like I"m planning to, I'll be very interested in what RCE brings to the table for this model. Edit: can a mod change the spelling of suspension in the title of this thread? |
#61 | |
Drives: '05 Legacy
I'm also trying to follow this as closely as possible. It's fine if the Scion drops some amenities to lower the cost, but I'd be wary if they go too cheap on the suspension front. On the other hand, we've got RCE here to (hopefully) provide us with great aftermarket upgrades for the suspension! Glad to know that there's still some people interested in the performance of the car! |
#62 | |
Drives: 2013 SWP BRZ
You don't work at that Porsche tuning garage off Route 1 near 175 do you? |
#63 | |
Rocket Surgeon
Drives: PSM GGA OMG
m*(d^2 x)/(dt^2) = C*(dx)/(dt) + kx Or, in more mundane terms: m*a = C*v + k*x It's the three forces in the system, force from the damper + force from the spring = the force acting on the sprung mass. The "ma" comes from Newton's Second Law, and the "kx" comes from Hooke's Law. C is the damping coefficient. It's the slope of the lines in your chart. An important concept to know before I go any further is Critical Damping (represented by Cc). Critical damping is a value of the damping coefficient that will bring the sprung mass back to equilibrium as quickly as possible after a disturbance without over shooting. Values of C that are less than Cc are considered underdamped, and values of C that are greater than Cc are overdamped Cc = 2*sqrt(k*m) Damping Ratio (similar in concept to ride frequency),represented by zeta = C/Cc with zeta<1 is underdamped and zeta>1 is overdamped. Zeta=1 is critically damped. Being critically damped isn't actually a good thing, it means that the damper is actually causing the suspension to bind up a bit. At the very least it will reduce mechanical grip on less than perfect tarmac, and at worst could cause your suspension to pack down on rough roads. The flip side to that coin is the stereotypical beat up old Cadillac Deville with blown out shocks that never stops bouncing. Zeta = 0.7 is a good compromise and a good place to start. Getting a little more indepth, the forces acting against the damper are usually about two times higher in rebound than in bump. So you'll want more like zeta = (2/3*0.7) = 0.47 in bump and (4/3*0.7) = 0.93 in rebound. But then, you need the damping coefficient to be digressive to soak up big bumps. A good place to start is to halve the damping coefficients for high speed bump/rebound starting at ~4-5 inches/second. So you end up with the ballpark figures of: High speed bump: C = (1/3*0.7)*Cc = 0.233*Cc Low speed Bump: C = (2/3*0.7)*Cc = 0.47*Cc High speed rebound: C = (2/3*0.7)*Cc = 0.47*Cc Low speed rebound: C = (4/3*0.7)*Cc = 0.93*Cc Example: Let's say your car's sprung mass weighs 1800 kgs, and you're a total badass w/ coilovers and kidneys of steel, so your super stiff springs are giving you a ride frequency of 4 Hz. so: 2*pi*4 (s^-1) = sqrt (k/1800kg) .... k = 181,000 N/m for a wheel rate of 45,000 N/m. Let's assume you've got a 1.1:1 motion ratio, so your imaginary spring rate is 50,000 N/m. That means that Cc= 2*sqrt(50,000 (N/m)*1800(kg)/4*1.1) = ~10000 (N*s/m) --You need to include the motion ratio in here. So you'd want start with roughly: High speed bump: C = 2300 N*s/m Low speed Bump: C = 4600 N*s/m High speed rebound: C = 4600 N*s/m Low speed rebound: C = 9200 N*s/m |
#64 |
Hot Dog
Thanks old greg
I figured it was too juicy a topic for you to ignore.
#65 |
Drives: 2015 86, 2015 Evo X
Personally from all the footage Ive seen thanks to this site, the 86 wont need alot of attention suspension wise.
The Japanese news/tv showing the factory has an orange 86 driven off the production line and it seems very stiff already. Also alot of the driving/track footage has the car showing not bad body roll but if you compare the amount of body roll V's the size of the sway bars (tiny) id say there isn't a whole lot you can do with out going all out unstreetable spastic. |
#66 |
Kuruma Otaku
You rock, Old Greg. First spraining my brain with Mr Young's Modulus and now this.
If this was what they used in high-school physics, I might have hung with it longer. More questions will follow, naturally. (I'm also reading up on frequency as well. 4 Hz is a deliberate hyperbole, right? That would be a high-downforce car, no?)
Because titanium. |
#67 | |
Rocket Surgeon
Drives: PSM GGA OMG
![]() A car like that would eventually cause organ damage if you used it on the street for any length of time. |
#68 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
i love learning things. thanks old greg.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
#69 | |
Here are two pics of our garage...can't seem to find any more and it's late and I just got back from PRI. We'll do an MTV style cribs video soon. ![]() ![]() ![]() - Andrew |
#70 |
Kuruma Otaku
Le bump...
Is there a formula for determining a spring's 'fitted' rate? (The one based on the mounting angle, not wheel rate which is the leverage thing.)
Because titanium. |
| D-4S Thread | WingsofWar | Engine, Exhaust, Transmission | 85 | 03-31-2020 04:25 PM |
| AZ bs thread | sfwg | Southwest | 185 | 09-11-2012 03:11 AM |
| Intoxicated thread | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 46 | 04-27-2012 07:17 PM |
| The Diet Thread | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 126 | 06-14-2011 05:47 AM |
| The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 11:35 AM |
