Old 10-26-2012, 09:45 PM   #57
PRORICAN
PRORICAN's Avatar
Originally Posted by JPxM0Dz View Post
Yeah it looks like the 3M covers a good majority of the lip, so long as it went onto a clean surface it should be rock solid!
Did you fill in the two holes ?
Not yet, it started to get dark outside so I decided to finish tomorrow. To drill or not to drill? Not sure yet or at least figure out a way to cover the holes.
PRORICAN is offline   Reply With Quote
Old 10-26-2012, 09:48 PM   #58
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Can you take a closeup shot of the included pins ?
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-26-2012, 09:53 PM   #59
PRORICAN
PRORICAN's Avatar
Here you go...
The Following User Says Thank You to PRORICAN For This Useful Post:
JPxM0Dz (10-26-2012)
Old 10-26-2012, 09:55 PM   #60
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Here you go...
Ok thanks! That's what I thought, so basically drill the hole just big enough for the push pins to lock into the hole
2URGSE
Old 10-26-2012, 10:00 PM   #61
jkonquer
Drives: 2005 Subaru STI
Yeah dont drill hole for that little thing. It probably does nothing. Just cut it up and cover the holes
jkonquer is offline   Reply With Quote
Old 10-26-2012, 10:06 PM   #62
PRORICAN
PRORICAN's Avatar
Ok thanks! That's what I thought, so basically drill the hole just big enough for the pin to lock into the hole
Yup!
Yeah if I drill holes I might as well put bolts in, that way it'll be worth it so Im leaning towards just covering the holes like you're saying.
Old 10-26-2012, 10:07 PM   #63
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I installed mine earlier this week. The industrial grade 3M tape should be more than sufficient to hold this piece in place. Properly prepping the contact surface of the spoiler with a degreaser (like alcohol) will ensure full adhesion. I chopped the pins so that they are tall enough to bite and lock into the thickness of the rubber flap but short enough to clear the stock spoiler. It's a better finish than just leaving the holes exposed (where dirt would otherwise collect).
Edit: This is the same rubber material and 3M tape used on the rubber skirt flap that attaches to the STI front lip and I didn't even drill that in either; it's staying on with just 3M tape and has scraped against pavement a few times a month, withstood 80mph 1+ hrs freeway driving head on, car washes/rain, and it's still on there strong.
The Following User Says Thank You to switchlanez For This Useful Post:
chanomatik (12-20-2012)
Old 10-26-2012, 10:09 PM   #64
cantaloupe
Drives: brz
Can we get some distant shots of the back? Thanks!
cantaloupe is offline   Reply With Quote
Old 10-26-2012, 10:10 PM   #65
PRORICAN
PRORICAN's Avatar
I prepped the surface with alcohol so I should be good. After install I tried to move it and is on there pretty strong.
Old 10-26-2012, 10:11 PM   #66
jmah88
Drives: 2013 SUBARU SWP BRZ
Looks good! Cant wait to get mine now!
jmah88 is offline   Reply With Quote
The Following User Says Thank You to jmah88 For This Useful Post:
PRORICAN (10-26-2012)
Old 10-26-2012, 10:13 PM   #67
PRORICAN
PRORICAN's Avatar
This is all I have right now. Ill take more pics tomorrow after I install the HTA front lip.
The Following 2 Users Say Thank You to PRORICAN For This Useful Post:
charged86 (06-08-2013), finch1750 (10-30-2012)
Old 10-26-2012, 10:17 PM   #68
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Lookin' good! Did you powder coat the stock rims or plasti dip ?
2URGSE
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Old 10-26-2012, 10:19 PM   #69
PRORICAN
PRORICAN's Avatar
Plastidip
Old 10-28-2012, 08:35 PM   #70
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I got mine on Friday and I have no idea how to properly install it since the included instructions are in Japanese. Do you have to remove the spoiler from the trunk lid and take it apart? Any trimming? I need help translating the instructions or some installation pics please.
APR Wing? track_warrior Cosmetic Modification (Interior/Exterior/Lighting) 14 03-06-2013 03:36 PM
Varis FRS Wing for FRS/BRZ vividracing Cosmetic Modification (Interior/Exterior/Lighting) 31 02-01-2013 05:17 AM
GT-R style wing quik1987 Cosmetic Modification (Interior/Exterior/Lighting) 16 11-12-2012 03:56 AM
i like the gt86/brz wing. pr086 Scion FR-S / Toyota 86 GT86 General Forum 24 08-15-2012 05:12 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 07:11 PM
