Old 09-20-2013, 12:08 PM   #57
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by OICU812 View Post
No worries at all. Will be installing my WL one soon I've had a good feel for what the Perrin one does and should be interesting to see,feel differences.
If you bore out whitelines hole bigger you can fit both products
Sent from my Galaxy Nexus using Tapatalk 2
Old 09-20-2013, 01:34 PM   #58
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Definetly won't do that lol. I'm trying to reduce the nvh hence why removing Perrin for white line and stock T is what I'm going to try next.
Old 09-20-2013, 02:11 PM   #59
zc06_kisstherain
Drives: SWP BRZ
me neither. i thought about having 2 together but i choosed whiteline.
Old 09-20-2013, 10:51 PM   #60
Salgts86
Drives: tornado Grey Manuel
Looking at em both I'd prefer Whiteline over the perrin... surface area it makes sense to go for whiteline... But I liked your comment on using both by enlarging the whiteline Bolt hole?
ps how do you thank a poster for there comment? ZC06
Salgts86 is offline   Reply With Quote
Old 12-01-2013, 01:54 AM   #61
Yruyur
Yruyur's Avatar
Great DIY. Did mine today. Took some close ups of the before and after for others to see what this kit accomplishes.
I love the feel. When going over a speedbump or in a low gear cruising the shifter isn't moving all over the place anymore.
This is the same when pushing it hard. Just feels like the transmission is where you thought it was when shifting lol.
Yes you do hear the transmission in a low gear going through a parking lot. Up to speed it does not feel to be any more noise or vibration.
Old 01-13-2014, 10:34 PM   #62
swift996
swift996's Avatar
Any chance you could do without removing the front-pipe? I was in there doing the Perrin rear shift mount and it looks like there might be enough room to wiggle it out but not sure. I have an aftermarket front-pipe so maybe there's more open room around it.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-13-2014, 10:37 PM   #63
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
my brother helped me do the install this past weekend. he was able to shimmy it into place without removing the front pipe at all.
phanguy is offline   Reply With Quote
Old 01-13-2014, 11:24 PM   #64
twag4
Drives: frs
i put mine in without removing the mount at all. you only need to remove the nut from the bolt that extends through the center of the bushing. use a jack to gently raise the transmission just enough to slide the bushing in. took me all of 10 minutes to install. there is a write up on it in one of these threads
twag4 is offline   Reply With Quote
Old 01-14-2014, 01:34 AM   #65
OICU812
Just a dude
OICU812's Avatar
I've got the STI one in hand now, I'll install and compare against the WL in spring for nvh etc...
Has anyone else compare the STI to other inserts??
Old 02-19-2014, 04:27 PM   #66
RSConsulting
Drives: 14 BRZLtd 6MT-12 Pilot EX-L
First post - been lurking for a couple of weeks.
Thanks for the writeup.
Was able to do this without removing the front pipe (though the rear pipe was out for an cat-back swap - prior to putting in the Innovate Blower this weekend).
Helps to have access to a lift (LOL).
Did the shifter bushing also while I was up there anyways (Kartboy on both).
Learned a lot of great techniques in my lurkdom here. Will be uber-helpful in future mods.
Rick
RSConsulting is offline   Reply With Quote
Old 05-16-2015, 10:56 PM   #67
Stikrazy
Drives: BRZ Limited Dark Metallic Grey
WhiteLine Positive Shift Kit for the FR-S and BRZ
I installed this along with the Perrin T-bolt, I used a dremel and enlarged the hole on the whiteline piece so they would work together. The combined noise and vibration is ridiculous. You feel everything and now my dash vibrates as well. Sitting at the lights you press in the clutch some of the noise and vibration goes away. Let the clutch back out in neutral and all kinds of noise is detectable.
Yes the shifting is way more solid, but to the point like there is metal bushings.
Any advice on this matter??
Stikrazy is offline   Reply With Quote
Old 05-16-2015, 11:06 PM   #68
gramicci101
Off Topic
I would suggest that it's the Perrin bolt causing most of the NVH. I have the Whiteline bushing by itself and the most I got was some extra gear whine at low speeds.
Old 05-17-2015, 12:01 AM   #69
08stiguy
08stiguy's Avatar
Drives:
Best money spent so far 👍🏻
08stiguy is offline   Reply With Quote
Old 05-17-2015, 12:03 AM   #70
08stiguy
08stiguy's Avatar
Drives:
Originally Posted by 08stiguy View Post
Attachment 109786
Best money spent so far 👍🏻 don't upgrade anything if you don't plan on using the car to its fullest advantage. While I track the car, NVH is the last thing on my mind.
bushing, diy, positive shift kit, whiteline
Subaru Dealer Whitelist (positive experiences, truthful dealings) Deslock BRZ First-Gen (2012+) — General Topics 285 05-15-2023 05:35 PM
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 07:45 PM
IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! 10k Redline Brakes, Suspension, Chassis 6 10-16-2012 05:32 PM
which one is positive and negative frs Scion FR-S / Toyota 86 GT86 General Forum 1 08-04-2012 10:42 PM
Speaker wiring. Positive or negative?? |-Goku-| Electronics | Audio | NAV | Infotainment 9 07-28-2012 10:24 PM
