Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-26-2011, 03:13 PM | #57 |
Drives: '06 AM V8V Coupe
Oh shite never knew about that. I guess I learned something new today.
Then...dry sump? Is that a possibility? The engine in the FR-S is very low...this car has a lower CoG than a Porsche Cayman but with a lighter engine, which means they were pretty clever about placement. A Porsche Cayman has DS though so... OH and this reminds me, I wonder how Valvematic engines get along without DS, as there isn't ever a manifold vacuum, and not nearly enough flow at low speeds. I suppose all BMW cars are dry sump? M series run it for sure, and every new non-M series is Valvetronic equipped. Last edited by serialk11r; 09-26-2011 at 03:39 PM. |
09-26-2011, 04:22 PM | #58 |
Rocket Surgeon
Drives: PSM GGA OMG
Not at this sort of price point, and it wouldn't really reduce the amount of oil vapor in the crankcase anyway.
And on the topic of CG height, there is very little improvement to be had from a dry sump system on most engines. Production car engines have rather large diameter clutches and flywheels that limit the height of the engine once the oil pan is no longer the limiting factor. And on a flat engine you also have to consider the exhaust manifolds as well. A dry sump is all about maintaining adequate oil pressure under sustained high g cornering. Lateral acceleration causes the oil in a wet sump to slosh to the side of the oil pan, potentially allowing the oil pickup to feed air to the oil pump (causing very bad things to happen to your crankshaft and rod bearings). This is especially an issue on a horizontally opposed engine, as oil will tend to pool in one of the cylinder heads during a turn. This will cause the level of oil in the sump to continually fall, making a loss of oil pressure more and more likely the longer you maintain a high-g turn. More than a few Subaru engines have been killed this way. |
09-26-2011, 07:46 PM | #59 |
Drives: Honda Fit
The oil-air separator and catch can go before the pressurized part of the system? Is that correct?
09-26-2011, 10:55 PM | #60 |
Drives: 1999 Toyota Solara/ 2012 FR-S?
The catch can connects between the PCV valve and the intake tract.
Pressure pushes the vapor out of the crankcase through the PCV valve, then into the catch can, where the vapor drops out. The clean air flows out of the catch can into the intake tract. |
09-26-2011, 11:30 PM | #61 |
Drives: Honda Fit
Right. But the D-4S is a pressurized system. The fuel rail is pressurized.
09-27-2011, 12:10 AM | #62 | |
There's a positive net flow of air into the engine, so this still works. And regarding dry sump, what do people do when they want to track a car with a wet sump? |
09-27-2011, 12:25 AM | #63 |
Fuel pressure has no baring on the pressure in the crankcase which is caused by blow-by.
In any fuel injection system (multiport, direct or otherwise) the fuel is pressurized to feed the injector. The injector is nothing more than an electronic valve with a nozzle. The direct injectors run on higher fuel pressure levels so that the fuel can be injected into the pressurized cylinder. Also the higher pressure makes for better atomization of the fuel. The only thing that pressurizes the crankcase is the blow-by gases. The PCV system doesn't compete with the fuel pressure in the fuel rails. |
09-27-2011, 10:45 AM | #64 | |
Drives: Scion FRS
On Most tracks you don't have turns with enough G's for long enough time for you to run out of oil in the pan. Just make sure you aren't at the minimum oil level and you will be fine. If your concerned you can do any of the following 1. Get an oil pressure gauge, and keep an eye on it (warning light is a good idea). 2. Baffle the oil pan, with trap doors so oil doesn't leave the pan in high Gs(Toyota/Subaru will do this, but that doesn't mean it can't be done better) 3. Add an oil accumulator, so we have some more time before you stop getting oil sprayed.(less then $300) 4. Dry Sump (more like $3000) |
09-27-2011, 03:29 PM | #65 | |
Kuruma Otaku
* That is actually what the 'S' stands for.
Because titanium. |
09-27-2011, 04:42 PM | #66 |
Drives: Honda Fit
^^^ Dimman, I don't understand.
09-27-2011, 04:48 PM | #67 |
Hot Dog
Drives: quicker than arghx7
He's trying to reiterate the point I made yesterday in saying that the port injectors keep the carbon build-up to a minimum while retaining the benefits of the direct injection setup.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
09-27-2011, 06:22 PM | #68 | |
Drives: Honda Fit
Point taken. But on a car that both the manufacturers and the buyers hope will have the sh*t flogged out of it, what sense does that make? I've read that WFO and high-revving will increase carbon build-up. I'm not buyin' this car to run it down to the market for a loaf of bread. If you know what I mean. Thanks. |
09-27-2011, 06:27 PM | #69 |
That is a good point, if you're always driving it at WOT then the direct injectors will be used most of the time, giving more opportunity for buildup.
But you're not always going to floor the gas, at least I hope you wouldn't be for the safety of the people around you on the road, and that's when the port injectors "wash" your intake valves So at the very worst, it won't be as bad as a typical VW GDI system. |
09-27-2011, 06:35 PM | #70 | |
Drives: Honda Fit
Ah! Now I get you! Thank you, sir! |
Similar Threads | ||||
Photographer's thread | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 1199 | 05-24-2024 03:11 PM |
Intoxicated thread | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 46 | 04-27-2012 07:17 PM |
Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 12:44 AM |
The Diet Thread | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 126 | 06-14-2011 05:47 AM |
Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
