#57 |
Kuruma Otaku
Because titanium. |
#58 |
4G63 & Rotary
I for one have no interest in an ALS or SAS in any of my FI cars as it severely reduces the durability of the turbo and exhast manifold.
The OEM SAS on the Evo's are highly nerfed versions of the true ALS systems, the main bottleneck being the narrow diameter on the banjo bolts that can be bored out to increase air flow. "It's the "Secondary Air-injection System." It's that squiggly alloy tube running from a solenoid valve connected to the tube near the intake plenum to two ports at the top of the exhaust manifold. It's also the basis for the RalliArt Anti-lag System. In rallying it's used to reduce turbo lag between gear-shifts. I don't know how much residual benefit is derived from it without full-blown Anti-lag activated in the ECU. It also "leans out the exhaust gas for emissions purposes" as you said. So you can delete it if you want... but why worry?"
#59 |
4G63 & Rotary
The Evo 1-3 didn't have ALS or SAS, but the Evo 2-3 had Post Combustion Control System, which was the precursor to the SAS in the later Evo's.
[Edit] This is a pretty cool read. Toyota had the Toyota Combustion Control System, pretty neat. http://www.oocities.org/hflancia/bangbangALSsystem.htm How the turbo Anti-Lag System works Bang-bang (also known as ALS which stands for Anti-Lag System) is an engine management technique that allows to minimize the turbo lag time. As you might be aware of, turbochargers display what is known as lag time which is the time needed for the turbine to reach its full throttle from an intermediate rotational speed state. The duration of a turbocharger's lag depends on many factors among which its inertia, airflow efficiency, back pressure, etc. The problem is partly dealt with by fitting a turbo dump valve, which acts each time the driver lifts his foot from the throttle. The dump valve will evacuate the pressurized air coming out of the turbocharger while the inlet manifold is closed thus allowing not to stall the turbine and avoiding possible damage to its bearings. In racecars it is very common to fit oversized turbochargers in order to be able to produce enough boost pressure and assure a sufficient engine output. Big turbochargers display significant amounts of lag due to their increased inertia. In these cases the dump valve is insufficient to allow the turbocharger not to loose too much speed when the driver lifts off. Additionally rally cars hold a turbo restrictor, which is regulated by the FIA. One of the restrictor' effects is to increase lag time. This is why in racing cars, and most specifically in rally cars where torque and engine availability are critical factors, most applications use anti-lag systems. During lag time the engine is much less responsive and its output well below nominal. To counter the effect of turbo lag time drivers used to anticipate the engine's reactions by accelerating well before they would have in a non-turbo car. Others have used a technique, introduced by the German driver Walter Röhrl, known as "left foot braking" where the driver uses his left foot to brake the car while his right foot accelerates to keep the turbocharger in optimal load. ALS was a simple idea but relatively difficult to implement. To the best of my knowledge Toyota Team Europe were the first to use it in racing (Toyota's implementation is known as Toyota Combustion Control System while Mitsubishi call the system Post Combustion Control System). How ALS works While the ignition timing is altered with 40° or more of delay the intake air and fuel supply is made richer when the driver lifts his foot from the gas pedal. This results in air and/fuel mixture that keeps getting in the combustion chambers when the driver no longer accelerates. The ignition being delayed, the air/fuel mixture reaches the exhaust tubes mostly unburned. The exhaust temperature being extremely high the unburned fuel explodes at the contact of the exhaust tubes. Luckily the turbo sits right there and the explosion keeps it turning (otherwise it would slow down since its intake, the exhaust gases, is cut-off). The effect is vastly lower response times with some downsides: A quick rise of the turbo's temperature (which jumps from ~800°C to the 1100°C+ region) whenever the system is activated A huge stress on the exhaust manifold and pipes (mounted on a street car a bang-bang system would destroy the exhaust system within 50-100 km) The explosions which occur in the exhaust tubes generate important flames which, sometimes, can be seen at the end of the exhaust tube The the bang-bang system got its name from the loud explosion noises one hears whenever the driver lifts his right foot. Depending on the implementation, ALS systems are more or less aggressive. While the systems mounted in Toyota and Mitsubishi racing cars are relatively smooth and noiseless those fitted in Ford and Subaru cars are much more noisy. Most racing implementations have user selectable anti-lag settings depending on the terrain, usually three settings can be selected by the driver going from moderate to very aggressive. |
#60 | |
Site Moderator
Drives: ichi 86 Project
But you wanna count it as ALS then your statement is true. Absolutely. I was only talking about engine, but you wanna go into suspension, chassis, & other stuffs, WRC car vs stock one, I'll be more than willing to debate |
#61 |
Drives: Lexus IS-F
#62 |
Drives: Lexus IS-F
#63 |
4G63 & Rotary
Wiki'd
In relation to motorsport governed by the FIA, Group A referred to a set of regulations providing production-derived vehicles for outright competition. In contrast to the short-lived Group B and Group C, the Group A referred to production-derived vehicles limited in terms of power, weight, allowed technology and overall cost. Group A was aimed at ensuring a large number of privately-owned entries in races. Group A was introduced by the FIA in 1982 to replace the outgoing Group 2 as "modified touring cars", while Group N would replace Group 1 as "standard touring cars". Homologation To qualify for approval, a minimum of 2500 cars of the competing model had to be built in one year, out of 25,000 for the entire range of the model (e.g.: 2500 Subaru Impreza WRX, out of 25,000 Subaru Impreza). Up to 1991, the requirement was a minimum of 5000 cars in one year, without regards to the entire range, but the FIA allowed "Evolution" models to be homologated with a minimum of 500 cars (e.g.: BMW M3 Sport Evo, Mercedes-Benz W201 Evo). Rules also required some of the interior panels to be retained, e.g. interior door panels and dashboard. However, not all manufacturers who built 500 such models sold them all, some stripped the majority of them to rebuild them as stock models or used them to allow teams to use modified parts. One such example of this was Volvo with the 240 Turbo in 1985. After they had produced 500 such models, Volvo stripped 477 cars of their competition equipment and sold them as standard 240 turbo roadcars. As a result, after FISA's failed attempt at finding an "Evolution" car in any European countries, Volvo were forced to reveal the names of all 500 "evo" owners to be permitted to compete. The other example was Ford, after selling off their entire RS500 stocks, they read the rulebooks and found themselves that rather than using either the Sierra Cosworths or the RS500s, they could use the body of the basic 3-door Sierra, which Ford was discontinuing, and use their Evolution equipment on them. Nowadays, these cars are treated as any other model in the range. |
#64 |
Kuruma Otaku
They need to bring back strict homologation rules.
ie if Ford wants to use a 1.6L turbo AWD Fiesta with anti lag and sequential trans, in WRC, they have to make at least 2500 of them! ![]() That would instantly make the Fiesta interesting to me.
Because titanium. |
#65 |
Site Moderator
Add to that, Group A Rally allowed modification. As long as parts were sold to the public (ridiculously expensive)... which allowed ridiculous modification on engine, suspension, exterior parts.
#66 | |
Drives: Lexus IS-F
If you're saying rally cars have nothing in common with road cars, I think you're sorely mistaken. But hey, that's just me.
#67 |
#68 | |
Adventure Enthusiast
I wish that car came here in the states.
"I say why do you care what other people think about you when driving your car, why can't you just enjoy it for what it is and have fun with that?" - Carlos Lago, Motor Trend |
#69 |
Drives: Lexus IS-F
#70 | |||
Drives: 2010 Evo X MR-T
in terms of turbo tech? yeah. pretty much... rally teams rebuild their engines how many times? Quote:
both. the FT is lighter so it wont need as much hp to make it go, BUT that doesnt change anything about the tq curve, area under curve, etc. Last edited by madfast; 08-30-2011 at 02:06 AM. |
| Initial D | cyde01 | Off-Topic Lounge [WARNING: NO POLITICS] | 122 | 11-21-2012 02:05 AM |
| Panda FT-86 Initial D style | andyroo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 28 | 03-13-2011 03:38 AM |
| Rumor of the day | Kids Heart | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 01-18-2011 10:09 AM |
| Ae86 roll cage in initial d? | CyberFormula | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 03-14-2010 12:23 AM |
