Old 09-29-2012, 10:44 AM   #57
simplicityinsound
simplicityinsound's Avatar
Drives: 2010 Subaru LGT
FWIW, this is the connects2 kit for the Toyota IQ from UK:
http://shop.audioimages.co.uk/connects2-ct24ty25-double-frame-toyota-2009-pr-5485.html
simplicityinsound is offline   Reply With Quote
Old 09-29-2012, 04:09 PM   #58
DekaMori
DekaMori's Avatar
Drives: RWD
Hmm,, after removing the dashkit, noticed this as well, can't figure out the model# or anything... Like seriously, shouldn't be anything to hide, no?
@PrimeMotoring - hope you get back to me ASAP, and provide some resolution!
DekaMori is offline   Reply With Quote
Old 09-29-2012, 05:46 PM   #59
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
That's poor form if true. Interested in seeing the results.
kmbkk is offline   Reply With Quote
Old 09-29-2012, 06:13 PM   #60
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Here is what I sent to DekaMori as it as applies to anyone reading this thread
"Hey I spoke to Enfig about whats up with the part number being grinded off as I saw these on the Prelim kits (which you got both) and they will be like that due to the manufacturer they get it from. The kits are NOT Connects2 but its a possibility Connects2 is using the same manufacturer to make their kits.
As far as the fit goes with your specific radio you can send the kit back even if it is modified and give you a full refund. I want to make sure everyone is happy with the product we provide. I apologize for the late response as I along with the rest of the shop is down in Maryland for a show.
Mike"
Enfig had the product for me and I have been helping out with development for it. The part number grinding off thing may be on all the prelim kits as Enfig wants to protect their internal model number used with the manufacturer. They reassure me it is NOT a Connects2 kit however Connects2 may be using the same manufacturer for their kit. If anyone has or has not given me deposit on kit and has any more questions please put them up here and I'll keep an eye out and respond to them as quickly as possible.
PrimeMotoring is offline   Reply With Quote
Old 09-29-2012, 06:16 PM   #61
PrimeMotoring
By the way one thing I can recommend with this or ANY iso mounted kit is you can open up the hole a slight bit in one of the brackets so that it can bolt in a little bit more tilted to line up better. Some modifications may be required due to different radio styles, it is in its nature a tight fitting kit for aesthetic reasons.
Old 09-29-2012, 08:59 PM   #62
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Great response, thanks for the update!
Old 09-29-2012, 10:24 PM   #63
simplicityinsound
Prime, can you provide a video of an actual unit bolted to the car already with the oem brackets, and then this kit sliding right ontop and snapping into place?
the issue i saw with it was, most aftermarket double din HUs, when bolted in place with the stock brackets, will protrude a certain amount, and how this kit sits, when located onto the oem bezel, to me at least from my experience is too deep to fit over the chasis extrusions of most DD headunits. if you get one with a super fat face, such as some alpines, this may work, but i really would like to see an actual video of a unit located via the brackets and then this being snapped into place.
the other thing i noticed was that if this kit was designed for the FR-S and not the IQ kit from UK, then they didnt do the tabs right because four or six of the tabs hit directly onto little tabs on the back of the bezel opening, preventing a perfect snap in of the kit, in order for this kit to snap in perfectly, the tabs needs to be spaced differently. but even after trimming of those tabs, the depth issue still remained.
as far as being a different design and origin than the connects2 IQ kit, i have a contact in the UK with connects2, i am sure we can figure it out, but it just looks really similar and in my experience with thousands of dash kits, i have yet to see two kits meant to be different look so similar. From my perspective, i dont think connects2 or enfig makes the kit, or owns the rights to this kit, i am fairly sure though, that hte connects2 kit was out quite a few months ago.
my main concern is whether or not this is the same kit as the IQ kit (be it connects2 or xxx or yyy brand)design. how does it differ from the IQ kit?
perhaps a side by side shot of the IQ kit with this kit for comparison purposes?
again, this is purely MY opinion in working with the kit, but really would like to see some more proof of the fitment, as if it can indeed work for other headunits with fixed face, then i would not hesitate to recommed it if the little bugs can be worked out...and infact use it in my future installs...but i would like to clarification for sure
b
Old 10-12-2012, 06:01 PM   #64
2forme
Prime, I paid for this two weeks ago. I haven't heard from you or received anything. I've tried PMing you without response. What's going on? I have gaping holes in my dash....
Old 10-12-2012, 11:55 PM   #65
LD
Drives: 2013 Scion FR-S Raven
I want to buy one asap. I have been trying to fill those in and not having much success, this would be great.
LD is offline   Reply With Quote
Old 10-13-2012, 12:44 AM   #66
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
What about this kit?
http://www.ft86club.com/forums/showthread.php?t=18102
JoeBoxer is offline   Reply With Quote
Old 10-13-2012, 02:20 AM   #67
simplicityinsound
thats waht i used in the second FR-S build ultramarine
Old 10-16-2012, 08:33 AM   #68
2forme
Still no word on these things. I think I might rescind my payment and grab something else. It's clear these are backed up for some unknown reason.
Old 10-16-2012, 11:14 AM   #69
simplicityinsound
which headunit do you have? you may wanna read dekanori's post about the fitment issues he experienced?
Old 10-16-2012, 11:15 AM   #70
2forme
http://www.ft86club.com/forums/showthread.php?t=19872
Best double-din on currently on the market? Hanakuso Electronics | Audio | NAV | Infotainment 15 05-29-2013 01:58 AM
sorry double post LS13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-29-2012 02:42 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
Double U T F...is this for real? Hawk77FT AUSTRALIA 20 07-14-2012 05:21 PM
Warning - Double Orders thermobox Off-Topic Lounge [WARNING: NO POLITICS] 4 03-02-2012 10:55 AM
