#57 | |
Drives: '23 BRZ
Hotshoe driver in a shared car that I have handily beaten in years past with the owner driving. Excuse list available on request...
#58 |
Drives: '23 BRZ
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | DocWalt (11-02-2022), x808drifter (10-21-2022) |
#59 |
Drives: 2022 BRZ sport-tech
Good point. I wonder if the RTV found has been in there for the past 73k miles or a recent addition (dislodged recently). In light of this, I think the KillerB pre-filter for the Gen2 car is certainly a good item to have if it ever makes it to production. And i am still of the opinion that the redesigned pick up in the FA24 is Suby's way of working around this RTV problem.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#60 | |
I’m not an ardent oil cooler advocate (think it can help if designed properly), but worth noting that Oscar Jackson Jr. seems to be a big proponent of them. Granted his company sells them but they also tear these engines apart regularly so they can see how the bearings are holding up in extended track/race usage.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | ZDan (10-20-2022) |
#61 |
30 minute maintenance
Drives: My18 wrxsti
Apart from the obvious ,correct oil level, quality oil of the correct viscosity is the main ingredient.
#62 | |
Drives: '23 BRZ Limited
The NC is just a shortened RX-8. Brakes/hubs/swaybars from the RX-8 all bolt right up.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | ZDan (10-20-2022) |
#63 | |
Drives: '22 BRZ
#64 | |
#65 | |
Drives: 2022 GR86
Surely that would generate more heat. Anyhow, let's get back to the topic of oil cooling of 86s :P
Follow the build thread for my GR86!
#66 |
Drives: '22 BRZ
Not sure where the info about the ND is coming from, they don't really overheat on track unless you're in a draft pack. There are upgrades available to keep temps down but it is in no way a requirement. They also don't need all sorts of brake upgrades, though the slow idiots on the FB groups are convinced you need a BBK to even think about going to a track.
Back to the 86 though... Any sort of extended track use should probably still use an oil cooler to extend service intervals and use higher viscosity oil. Stock cooler seems "fine" with just 5w30 like the first gen with the same cooler.
#67 | |
Drives: #337 2017 Toyota 86
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
#68 | |
Drives: '22 BRZ
There's no oil temperature sensor on the ND Miata, ND1 or ND2. They will definitely pull power when they get high engine coolant temps, but all of our local ND track guys are on stock radiator and have been maintaining <215F coolant temps. One guy now has a vented hood and his coolant temps are <205F even on 100 degree days.
#69 | |
#70 | |
They never did any of those things for the 3 previous generations.
| FS: NJ/NYC OEM (Forester) oil cooler/oil cooler connector | Joon525 | Engine, Exhaust, Bolt-Ons | 3 | 09-20-2019 06:00 PM |
| SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge | tws98 | Engine, Exhaust, Bolt-Ons | 0 | 05-28-2019 11:50 PM |
| AT Trans Cooler: Performance cooler vs Standard | Faulkner | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 04-30-2018 12:34 PM |
| WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler | TheMedakaBox | Northern California | 4 | 08-09-2017 11:16 PM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 06:46 PM |
