#57 |
Drives: ‘22 CWP BRZ LTD 6MT
Anyone found what could be causing the buzzing above 4000 RPM? Wonder if the fake sound speaker is making some piece in the dash rattle as it gets louder? Maybe if anyone has unplugged that and noticed a difference it could give us some info
#58 |
Drives: 2022 BRZ
I have no weird noise above 4k rpm, the fake engine sound is coded out.
#59 |
Drives: 22 BRZ limited
I don't know what noise you mean. You could unplug your engine noisemaker and see if you still hear it. It takes less than a minute to do so. I no longer have that speaker.
#60 | |
It’s a buzzing a few others noted, only present above 4k RPM and it sounds like it’s coming from behind the right hand side of the dash almost immediately to the right of the display. It’s a subtle buzzing that isn’t otherwise present. It’ll be there about 70% of the time. |
#61 |
Drives: Subaru BRZ
It could be 'depreciation', it makes all kinds of noises... I recall when I got my car, I was hearing all sorts of stuff, and then discovered a less restrictive exhaust pipe with a UEL...
| The Following User Says Thank You to JD001 For This Useful Post: | bcj (01-01-2022) |
#62 | |
Drives: Mini
#63 |
#64 | |
Drives: 2022 BRZ Ignition Red
#65 |
Drives: 2022 BRZ WRB
Easiest way to test that is to unplug the sound control unit on the end cap of the dash. Drive it for a few days and try to replicate the sound. If someone who has it already disconnected can replicate the noise then we know it's not the speaker.
#66 | |
Drives: 2022 Subaru BRZ
#67 |
Drives: 2022 Subaru BRZ Limited 6MT
Is anyone experiencing the 'crickets' sound after fully warmed up at idle? It started happening in my 2022 BRZ Limited 6MT at around 500 miles. I'm in SoCal so 91 octane max, I've tried all major brands of gas including Shell and Costco.
#68 | |
Drives: 22 BRZ Limited
Not sure if it's the same sound, but I get what I'd call a higher pitched "whoop whoop whoop" sound. It almost sounds like the Jetson's car or something. Seems to be rev dependent, and interestingly only seems to happen when it's really cold outside (regardless of engine temp, with or without HVAC on). I can hear this more clearly inside the car rather than outside. If it's not the same sound, especially if yours is more audible with the hood raised, it might just be the high pressure fuel pump. I think that's pretty common from what I've been reading. |
#69 |
Drives: 2022 BRZ
Is it coming from overhead? Press on the headliner to see if it goes away. If thats it, its your map light console. The clips probably need to be replaced or engaged better.
#70 |
Drives: Subaru BRZ
My new frustration is i located the seat squeak. It's the connection for the seat belt buckle. Depending on how I sit, it's just squeak city.
| Anyone not buying to avoid early issues like 1st gen FRS? | stocktc1 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 203 | 09-23-2021 10:11 PM |
| Buying an early build in the fall, but some issues with these cars are worrying me... | RyMi | BRZ First-Gen (2012+) — General Topics | 34 | 02-27-2019 09:56 PM |
| New 2014s still have early issues? Prospective buyer | Lord09 | Issues | Warranty | Recalls / TSB | 25 | 06-14-2014 05:42 AM |
| Early problems - speaker rasp and long turnover | Hawaiian | Issues | Warranty | Recalls / TSB | 44 | 08-30-2013 05:39 PM |
| Initial Issues / Problems | JDMSushi | AUSTRALIA | 56 | 09-30-2012 11:21 PM |
