Old 04-23-2021, 06:28 PM   #57
Lantanafrs2
Drives: 2013 frs red
Some people will say that the k24 is the best 4 banger ever made. Can't verify that but it would be a major upgrade over the fa20 for sure.
Old 04-23-2021, 06:58 PM   #58
Decep
Drives: 2013 FR-S Series 10
Damn.
You plan to engine swap every time you do your annual smog? You crazy man you crazy.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 04-23-2021, 08:00 PM   #59
Originally Posted by Decep View Post
Damn.
Out of curiosity, how does that work in CA?
Old 04-23-2021, 09:01 PM   #60
Decep
As far as i know it'd have to be same year engine or newer, with obviously all the emissions equipment.
RCE SS-1 Coilovers
Corsa Catback
Old 04-24-2021, 12:47 AM   #61
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Damn.
It would be biennial starting this year, but no. The car may be registered in a smog exempt area of California.
Old 04-24-2021, 01:01 AM   #62
Irace86.2.0
Are you guys ready for the horror show?
But before we see some pics, the good: the supercharger is intact without a scratch on it! The coolant pipe blocked the rod that broke through the block, so much so, that the water pipe cracked in half! One of the supercharger connectors took a direct hit and shattered, so that will need replacing.
Old 04-24-2021, 01:07 AM   #63
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by TommyW View Post
I got the IAG
Why did you go with IAG and not a stock motor? Did you have oiling issues?
Old 04-24-2021, 01:12 AM   #64
Irace86.2.0
Here is the water pipe, the pieces of the block and the piston end of the rod. You can see the bend in the block bolt from the force of the rod ripping through the block. I can’t wait to get the block apart to see what else is inside. I’m taking tomorrow off, and then I’ll work on it some more on Sunday.
Old 04-24-2021, 01:13 AM   #65
DarkSideFRS
Drives: 2013 pearl white FR-S
Ah. Good ol' Subaru engineering. Gives japanese cars a bad rep
DarkSideFRS is offline   Reply With Quote
Old 04-24-2021, 01:18 AM   #66
PulsarBeeerz
Drives: JRSC BRZ SOLD
Why do you spend time crying about a car you don't have anymore here?
PulsarBeeerz is offline   Reply With Quote
Old 04-24-2021, 01:22 AM   #67
DarkSideFRS
I enjoy seeing these ticking time bombs blow up, which happens a lot
Old 04-24-2021, 01:32 AM   #68
PulsarBeeerz
That's clearly a falsehood if you look at any real data. Why make such an erroneous statement? Wait, finding pleasure in hardships of others is your thing? At the end of the day that is what is happening as the owner has to deal with the situation in front of them. I know this is just a car forum but in all seriousness that isn't a healthy or sustainable mentality. Internal introspection is difficult, but perhaps you should consider it for your well being and those around you.
Old 04-24-2021, 01:35 AM   #69
Irace86.2.0
Well, in Subaru’s defense, the car had more than double the horsepower for quite a while, and I beat on the car, taking it to redline daily. Most manufacturers don’t do much better. They seem like par. Frankly, I was surprised the engine could handle as much power as it did. I expected the tranny to go a long time ago too.
Old 04-24-2021, 09:41 AM   #70
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Because for the extra 1,400 to have a motor that addressed the shortcomings of the stock motor and used much better internals it was an easy decision.
My blown motor was due to the recall
Dustin's UltraMarine FR-S (Engine Blew - LS3 Time) DustinS Member's Car Journals 800 04-13-2024 09:23 AM
Engine Blew, any shop recommendations? tian105 Southern California 11 08-16-2020 11:35 PM
Engine blew on 4psi? Causes? soccerk18 Software Tuning 26 08-10-2019 11:18 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
