#57 | |
Rust bucket enthusiast
It's called tuning because you're adjusting with a goal in mind; just that most people tune to make the most power, where Mike has tuned for safety and the torque curve that yields him comfort on track
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#58 | |
Drives: Q5 + BRZ + M796
The TVS 1320 is listed on Eaton's website as ideal for 3.0-4.5L engines. My wife's Audi Q5 uses the same Eaton TVS1320, and it is a 3.0L V6. Cosworth uses the TVS 900 on the FA20. The point is the supercharger is relatively large for this platform and really doesn't hit its stride until higher boost levels. While torque does slightly drop off, the hp continues to rise to redline. Below is a Harrop kit on E85 at a bar of boost. ![]() https://www.eaton.com/us/en-us/catal...tvs-r1320.html The JRSC is as you know a centrifugal supercharger, so it'll be building more on the top end. If you get the C38 or don't max out the C30 then it should pull to redline and not drop off. The C30 is at 96% of max on the high boost pulley. See below. ![]() For this A90 Supra example, the stock turbo is small, so torque rises very fast and then it falls off, as the turbo is likely restricting the engine. Lots of torque down low, but not a whole lot of peak horsepower. In fact, peak hp is less than peak torque. Add a larger turbo in the next graph, and we get some rpm delay before torque hits due to boost threshold and the torque curve looks more flat with a power curve that pulls more to redline. Now, peak horsepower is more than torque. Add an even larger turbo and the boost threshold is significant, so the curve starts looking like a JRSC curve where torque takes time to ramp up, and it would look even more like one if they didn't limit boost there. I don't know what Mike is doing, but it is entirely possible to design a system where the turbo makes peak torque down low, but falls off, such that it hits the same peak boost of 9psi as a supercharger, but it does 9 psi at 4k vs 7k, so the supercharger has the same or even more peak horsepower because they are making more torque at higher rpms, yet the turbo might have more area under the curve, especially down low. ![]()
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | Calum (12-22-2020), DarkPira7e (12-22-2020) |
#59 | |
That Guy
Drives: 2013 asphalt FRS MT
#60 | |
That Guy
Why did you spend so much money/time/fabrication to get more air through a huge intercooler instead of upgrading to a larger and/or more efficient turbo? |
#61 | |
2013 Series 10 FRS #553
#62 | |
Enabling more power and/or efficiency is just a matter of swapping on a larger turbo, but why? I can't use any of that extra efficiency/overhead without going back into constantly-breaking-transmissions territory. I don't care to total my car with a CD009 swap, and don't care to swap in a PPG gearset. If I just want more power, there are other more powerful cars I can drive. At the end of the day, I went turbo because I wanted to prove that a turbo setup can be done reliably. It just so happens a supercharger can put out just as much power at roughly half the cost. Modern superchargers are far more efficient than I think you may give them credit for. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#63 | |
Weight Weenie
Drives: 15 FR-S
I think people will be parroting this for some time to come. |
| The Following User Says Thank You to new2subaru For This Useful Post: | Irace86.2.0 (12-22-2020) |
#64 | |
Drives: 2017 toyota 86
Finished that last statement for you. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | DarkPira7e (12-22-2020) |
#65 | |
I should mention, 5 of the 7 transmissions i shredded died on the street, not on track. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Irace86.2.0 (12-22-2020) |
#66 | |
#67 | |
I'm trying to wrap my head around how a small turbo could be so small as to max out on boost, but not choke the engine while naturally creating a ramp up without a boost controller. Are you using drive-by-wire to limit throttle input?
#68 | |
Specifically a GReddy T518Z The FMIC doesn't cause any boost drop; the Garrett FMIC actually increased flow. The turbo has a giant hot side, with a relatively small cold side. Your picture above isn't too far off from the actual size of the cold side. I think most folks have a good idea of the size of the OEM throttle body diameter. Use that as a frame of reference compared to the turbo. In particular, look at the outlet size of the turbo. It's smaller than the outlet of a Rotrex C30-94. https://www.instagram.com/p/BbYKuqwhwzB/ |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#69 | |
Sometimes I look at one of my 9B turbos I have on a shelf from my VR4 and suddenly everything looks like it should be sucking rags off of nearby shelves.
#70 |
pessimistic skeptic
Rods could have bent if the transmission had not failed first, especially if you had no proper cooling.
| WTB Turbocharged BRZ | scoobyy | Want-To-Buy Requests | 0 | 08-28-2016 02:02 PM |
| TWINCHARGED (Supercharged & Turbocharged) Widebody "WTF-86" 86/FRS *MASSIVE* build :D | WTF | Member's Car Journals | 224 | 08-18-2016 10:39 PM |
| Looking for a turbocharged FRS | malandrin2011 | Cars for Sale/Trade | 16 | 03-21-2015 03:49 PM |
| Supercharged GT 86/FR-S/86 vs. Turbocharged BRZ | switchlanez | Scion FR-S / Toyota 86 GT86 General Forum | 61 | 12-20-2011 12:16 PM |
