#57 |
Drives: 2022 GR86
Found GTS G 709 on http://gtswheels.com/gallery/
According to this page on Fitment Industries, these are 18x8.0 +35 in the front
#58 |
Drives: 06 Exige, 17 BRZ PP
My Enkei TS-V just came in. 17x8 ET45
Good news, they fit over the Brembos. (and they look amazing!) ![]() Bad news: its by only this much. Actually less clearance than the stock wheels, which I didnt think was possible ![]() ![]() thoughts? For track use is this not enough clearance? |
#59 |
Drives: 2022 GR86
#60 |
You can add Enkei PF01 17x8 ET35 to fits
https://www.ft86club.com/forums/show...5&postcount=54 thanks to @atomicalex |
#61 |
Drives: 2018 Subaru BRZ Limited with PP
I never measured it, but the pictures are a little more deceiving in that matter. There is actually quite a bit of clearance between the rim and caliper, certainly more than the OEM PP wheels provide. Once I get the wheels officially on, I will update.
#62 |
Drives: 2022 GR86
#63 |
Drives: 2017 BRZ PP
Would you even need extended studs for such a small spacer? I was under the impression that 3mm and smaller is fine without them.
#64 |
Drives: 18 BRZ tS, 27 GRMN 86
I dont have the wheels anymore.
Here is the old pic http://www.ft86club.com/forums/showp...&postcount=414 |
#65 |
Damn that's crazy...
Drives: 2015 BRZ
Did you end up mounting them? Could you get pictures if so? Thank you. I'm considering the TS-V. They look really good, but yet to see them on a twin.
#66 |
Drives: 2022 GR86
Noticed that we've just reached 50 black lines (i.e. no known problems) in the list, woo-hoo!
Thanks everyone who contributed and keep them coming. |
#67 |
Drives: 2017 BRZ
I have the Konig Hypergram 17x8 +40 and I would say technically they do fit. The rubber cap on the bleed valve comes incredibly close though. I put on a 3mm spacer on the front just to be safe.
#68 |
Drives: 2017 BRZ Limited PP
Does anyone know if the Konig Rennform 18x8.0+40 will clear the brembos? The question was asked in the following thread, but no answer yet.
https://www.ft86club.com/forums/showthread.php?t=108308 |
#69 | |
Drives: 2022 GR86
Goodwin previously said it won't fit, but now we have a better idea by how much. |
#70 |
Drives: 17 BRZ
The Apex Arc-8 Wheels do fit over the Brembos but interfere with the stock suspension of PP BrZ. When mounted with 245/40r17 Bridgestone Potenza RE71Rs.
| Tags |
| brz, performance package, wheels |
| Finding wheels to clear brembos | jojosbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-13-2018 08:46 AM |
| Performance package Brembos | Ernest72 | Want-To-Buy Requests | 2 | 07-14-2018 08:06 AM |
| Performance Package Brembos Freezing to Wheels? | texastwurkt3am | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-23-2018 08:31 AM |
| What pads fit the Performance Package Brembos? | mistople | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-03-2018 05:15 PM |
