Old 05-28-2019, 02:02 PM   #57
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
Originally Posted by James H View Post
Appears the OP has conveniently overlooked the fact that he paid a much lower price for a salvage title car over a road worthy used car. That is the exact reason why there is a price difference. When one buys a salvage title car, it comes with the understanding that you take the risk of whether you can make it run with less cost thrown in than what you normally paid for a used one. Can't have it both ways.
I made the mistake of buying a salvage Chevy Z71 2004 that was from the rust belt. It was still a good deal, though. I did have to replace all the brake lines because they rusted out. Cost $850. But I got the truck for about $6k less than non-salvage. I've had it about 7 years now.
LotsaMiles is offline   Reply With Quote
Old 05-28-2019, 02:07 PM   #58
aemravan
Originally Posted by ermax View Post
Or get a Tactrix cable for $170 and flash a tune with that. Also E85 will do wonders even if all else is stock.
I'll have to look into this.. as you can tell I'm very new to this platform and there isn't enough time in the day to try and quickly catch up on a few years of aftermarket support for these cars..
I'm assuming I'll just need to source the tune from the web somewhere to be able to flash it via the tactrix cable instead of being a plug-&-play software flash of the OFT?
aemravan is offline   Reply With Quote
Old 05-28-2019, 07:08 PM   #59
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by aemravan View Post
Thanks for the input fellas.
After giving it some thought you are right on the springs and titanium retainers. The car definitely won't be turbo in the foreseeable future so no need to waste money on something like that.
What I did decide that I am going to do is:
- decide on air filter system (still doing some research to see what the best bang for the buck is)
- greddy axle back titanium tip muffler delete
- OFT stage 1 tune (looking to see if i can find a used tablet for around 350ish)
- and POSSIBLY some UEL headers with a cat. < this is going to be the pricey portion but I think it will do it wonders for the future in case we decide to play with some E85
now to return from the fantasy land and actually pick up the dang car so I can start making the repairs it ACTUALLY needs...
Best bang is probably a K&N drop in. If I had to pick something "more" it'd be the TRD air box, because it's a huuuuuge enclosed panel filter and the outlet tube is closely matched to the original so it doesn't tweak the maf signal as much as other aftermarket intakes.
The Following User Says Thank You to RZNT4R For This Useful Post:
aemravan (05-29-2019)
Old 05-29-2019, 11:23 AM   #60
aemravan
Thanks man! The TRD route sounds like the way to go.
I just picked up the car from the dealer this morning and its back in the driveway, so looking forward to starting the tear down process here in the next week or so
Also decided im probably going to skip the header upgrade and just do a cat-back exhaust.. the price was starting to look a little much for everything i wanted (UEL catted headers, axle-back muffler delete exhaust, air filter, OFT) it was nearing north of $2k, and im looking to try and keep it around $1300-1500 for upgrades on top of the 500 i'll need to rebuild.
Old 05-29-2019, 09:01 PM   #61
RZNT4R
Here's some intake testing I ran across.
https://dsportmag.com/the-tech/scion...programed-ecu/
Old 05-29-2019, 09:24 PM   #62
aemravan
You're a life saver ! With so man options for this platform that helps a whole lot. Hopefully their results are trustworthy but I'm more than likely going to go with the takeda momentum filter judging by their results they obtained.
Sent from my SM-N950U using Tapatalk
2013 Scion FR-S Valve Spring Replacement Recall Aussie Northern California 29 06-22-2020 02:51 AM
Scion FRS AT 2013-16 Recall 16V-075 Lokutus Issues | Warranty | Recalls / TSB 2 03-25-2016 10:22 PM
Scion fr-s recall 2016 Romanov Issues | Warranty | Recalls / TSB 63 02-10-2016 02:54 PM
Open recall on Scion FRS. mugen79 Issues | Warranty | Recalls / TSB 7 01-12-2013 09:23 PM
