Old 08-11-2019, 08:49 PM   #57
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
OK, So Project 7 is complete and passed state inspection last Thursday!
Back to Project 6 that got pulled out of storage last Sunday...
Project 6: - Update 2:
Finally getting this one underway, moved it to my garage last Saturday, washed it, removed all the damaged parts and got to repairing and modding this one for track duty. Pics added
Replaced broken engine fuse box case
Replacing belt tensioner and an idler that took a hit
Replaced radiator supports and upper core support
Installed repaired seat belts, installed reset airbag module and removed aftermarket stereo wiring, put most of interior back together
Installed Jackson Racing radiator/oil cooler combo along with new A/C Condensor and new fan shroud
Installed headlights, bumper beam and radiator air ducting
Installed fenders and hood to align everything! Hood will have to get painted...
Have new A/C hose on order as well as a MAF and a few other minor parts to complete the assembly, also need to get the hood and front bumper to the paint shop. Will get to installing the Essex Sprint AP Racing Front brakes, the Racecomp Engineering Tarmac II coil overs and the JDL header, over-pipe and front pipe sometime this week hopefully!
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 08-15-2019, 09:11 PM   #58
Opie
Opie's Avatar
Pictures added! Bumper & hood dropped off at body shop yesterday, hope to have back on Saturday for final assembly and track prep including: Fluid changes (oil, transmission, differential and brake), Racecomp Engineering Tarmac II Coilover install, JDL Header, Over pipe and Front pipe install, Essex Sprint AP Racing Front Brake kit install and more!
First track outing set for September 6th at Sebring!
2023 GR Cup Car
Old 08-17-2019, 07:49 PM   #59
Opie
Opie's Avatar
Project 6 - Update 3:
So spent Friday night and a couple hours today finishing this one up. Sorry for the lack of pictures, but Dave-Ror should be adding a few shortly, we wanted to get this one done and admittedly took very few pictures.
Last night installed a JDL Header, Over-pipe and front pipe. Today installed a set of Racecomp Engineering RCE Tarmac 2 Clubsport Coilovers W/ OE MOUNTS and an Essex Designed AP Racing Competition Sprint Brake Kit with Ferrodo pads with AP Racing Radi-CAL R2 brake fluid and Spiegler Stainless Steel Brake Lines.
We then installed the freshly painted hood and front bumper, threw on a set of Motegi 17x8 wheels I had sitting around that cleared the brakes and took in out for a shakedown! This will be a very fun and capable track car for our friend!
2023 GR Cup Car
Old 08-17-2019, 08:33 PM   #60
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
If you have any advice on convincing your wife why you should have a 4th car as an Opie-special track car, I am listening.
Nice job guys!
dowroa is offline   Reply With Quote
Old 08-25-2019, 08:01 PM   #61
Opie
Opie's Avatar
Project 6 went to it's new home today. Will be on track at Sebring in 2 weeks.
Final Build Sheet:
2014 Subaru BRZ Limited 6MT
JDL UnEqual Length Header
JDL Over Pipe / Front Pipe Combo
Jackson Racing Dual Radiator/Oil Cooler
Essex Designed AP Racing Competition Sprint Front Brake Kit
Ferodo DS1.11 Pads (Front)
Project Mu Pads (Rear)
Racecomp Engineering Tarmac 2 Clubsport Coilovers w/ OE Mounts
17"x8" Motegi Racing Wheels (Street)
17"x9" Apex Racing Wheels (Track)
AP Racing Radi-CAL R2 Brake Fluid
Redline 75W90 Synthetic Gear Lube (Trans & Diff)
Mobil 1 5W30 Synthetic Engine Oil
2023 GR Cup Car
Old 08-26-2019, 08:58 PM   #62
Opie
Opie's Avatar
dowroa - we work on cars, not wives. Wives are much more complex
Project 6 delivered to it's new home
2023 GR Cup Car
Old 10-15-2019, 10:34 PM   #63
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Project # 8.. I think? is on the way. Pics when it arrives assuming I'm in the state.
Project #3 (my silver 2015) might be up for sale in a few months when this latest one is done.
Decided to go a bit more hard core so this new one won't be made legal for street use which should save a couple grand that I can put into speed parts instead.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-22-2019, 09:12 PM   #64
Opie
Opie's Avatar
Since Dave-RoR was out of state...I met the driver to deliver this...
Probably the best purchase yet.
2013 Scion FR-S, 6MT, 27,900 Miles, stock except for a TRD cat-back
Damage was listed as mechanical (primary) and hail (secondary), this thing literally has no body damage except for 3 small dings in the hood, the engine has the intake manifold removed (it's in the passenger seat) and the A/C compressor is missing, also found some cut wires going to the fuel pump. The interior is complete, all airbags are intact.
Interested to see what is wrong with the engine...
My theory is that the dealer that did the valve spring recall less than 200 miles ago did something wrong and grenaded the motor then the car was likely totaled by their garage liability insurance.
Car is out of Nebraska if anyone knows the real backstory.
2023 GR Cup Car
Old 11-01-2019, 09:42 AM   #65
Opie
Opie's Avatar
Project 7 - Sold!
Project 8 - Dave-Ror picked up a used engine for it...and is searching out upgrades to install along with the engine. Headers & full exhaust, upgraded clutch, etc.
2023 GR Cup Car
Old 11-03-2019, 12:29 PM   #66
Lonewolf
Lonewolf's Avatar
Drives: Moped
One of my favorite threads on here!
Old 11-08-2019, 08:45 AM   #67
Opie
Opie's Avatar
New spark plugs & updated engine harness purchased, it will be helpful installing the 2015 engine into this 2013 and retaining the updated coil packs. Also, since the purchased motor is out of an A/T car we will need to transfer/remove a couple of parts; vacuum pump, water crossover pipe, etc.
Anybody got an A/C delete pulley for sale?
2023 GR Cup Car
Old 11-10-2019, 06:16 PM   #68
Opie
Opie's Avatar
Some pics of Project 8 - Dave's new track build
Started on the replacement motor today...
Installed updated Subaru engine harness to retain the 2015 coil packs and benefit from the improved shielding and grounding.
Removed the AT parts; vacuum pump & oil line, transmission cooler lines, etc.
Installed new spark plugs and got it ready to hopefully drop in the red FR-S next weekend to get it running.
2023 GR Cup Car
Old 11-11-2019, 10:10 AM   #69
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Assuming the AC delete arrives in time.. you know once I order it
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-11-2019, 10:27 AM   #70
ka-titties
Drives: 2013 BRZ Limited 6MT
This is a highly entertaining thread. I'm glad I stopped in to see what's up.
I hope y'all keep it going!
ka-titties is offline   Reply With Quote
RIP Dave Mirra STV3 Off-Topic Lounge [WARNING: NO POLITICS] 13 02-05-2016 02:00 PM
Dave-ROR: I know you want this rice_classic Tracking / Autocross / HPDE / Drifting 1 01-02-2014 10:15 PM
Sebring with Dave-ROR LDadrenaline Tracking / Autocross / HPDE / Drifting 9 11-13-2012 10:55 PM
Opie's BRZ thread Opie Member's Car Journals 6 09-25-2012 08:05 AM
