Old 12-10-2024, 07:16 PM   #57
JIM THEO
Drives: BRZ 2018
Originally Posted by Prodigalson View Post
Hey Jim,
Can you clarify if you install 4 tS uppers and 4 lower tS stoppers? And 4 of the longer STI bolts?
Thanks!
-Jason
If my memory serves me right only the two lower stoppers on the front bushes of rear subframe, as per the 2015 BRZ tS, and 4 longer bolts.
But I have to check it in order to be sure
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
Prodigalson (12-10-2024)
Old 12-11-2024, 05:02 AM   #58
JIM THEO
Drives: BRZ 2018
Originally Posted by nikitopo
There were some reviews in the past that the fronts do most of the work, but I'm thinking now that it is best to install all 4
Originally Posted by gpvecchi
You can fit 3 stoppers, the lower are not compatible on the back
What 3 stoppers you mean there are 4 bushings, I installed only the 2 front lower stoppers @rear subframe.
Do you guys believe if I replace them with all 4 upper stoppers the result will be better, did you try it?
The Following 2 Users Say Thank You to JIM THEO For This Useful Post:
Prodigalson (12-11-2024)
Sold 86TOYO2k17 Transmission and Driveline 9 03-28-2020 03:00 PM
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-14-2018 12:24 PM
FS: SuperPro subframe inserts & LCA inner bushings xn7485 Brakes, Suspension, Chassis 1 09-13-2017 04:23 AM
whiteline rear subframe inserts charged86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-18-2013 10:20 PM
