Old 11-30-2018, 01:56 PM   #57
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by churchx View Post
It's also possible, that while insufficient gains NA, but improved on forced induction, as reason "not taking off". Well, we can only wait for data, until then it's just guessing game.
It that their test configuration? A F/I motor? I missed that part...that really wraps it up for me, then.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 11-30-2018, 01:59 PM   #58
venturaII
venturaII's Avatar
Originally Posted by Lantanafrs2 View Post
Some people will spend the money to have most power available na. Cost/gains won't make sense but that hasn't stopped anyone yet
True, but like I said, those people are pretty rare and at the pointy end of performance where 4-5 horsepower might make the difference between podium and non-podium finishes. In those very rare cases, it will certainly be worth the expense.
Old 11-30-2018, 02:08 PM   #59
gtengr
Drives: 2017 BRZ
I think it's worth mentioning that the ITB testing is being done with an intake manifold and runner length that may or may not be optimized in shape and length. ITB's make it easier to test different runner properties, so the conclusions may change down the road as more experimentation is done.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
CSG Mike (11-30-2018)
Old 11-30-2018, 02:16 PM   #60
churchx
churchx's Avatar
Drives: 2014 GT86
We don't know that part yet. It's just blogged text without useful extra information. So nothing changes in addition that we just need to keep waiting for actual results/more detailed nfo to be released . Are there gains? Are there gains on NA? Or with FI only? Are gains of reasonable price/performancy? Nothing known yet. I mentioned FI only in way that i'm sure that both CSG & DT worked a lot with both misc FI & NA setups in past.
Old 11-30-2018, 02:24 PM   #61
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
im hoping this is for NA. If your FI you can always just add more boost or getting a bigger turbo ect for more power.
Even if its only 10hp/tq through the powerband over an Ace350 setup would be good enough to take my money. 10 hp/tq to the wheel goes a long way in my setup where my car is down to 2400lbs
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Old 11-30-2018, 03:19 PM   #62
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
You can easily beat 91 tuned turbo twins and some 300hp cars. Trust me, i know. Lol
Dr. BRZ is offline   Reply With Quote
The Following User Says Thank You to Dr. BRZ For This Useful Post:
SuperTom (11-30-2018)
Old 11-30-2018, 03:25 PM   #63
RayRay88
Drives: 2017 86 860 Special Edition
If people are calculating HP/$, they should just move on. These will likely cost a cheap turbo kit all said and done.
If you're looking to maximize your current NA setup and/or looking for the best throttle response and breathing on the intake side then I suggest you stay tuned for an official response from delicious tuning.
There are a lot of people jumping to conclusions here with out a lick of info.
RayRay88 is offline   Reply With Quote
The Following 2 Users Say Thank You to RayRay88 For This Useful Post:
CSG Mike (11-30-2018), mistople (11-30-2018)
Old 11-30-2018, 03:54 PM   #64
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The RB26DETT motor in the Skyline GTR had ITBs, so it is reasonable to conclude that ITBs are beneficial on FI applications too, but probably for throttle response. I believe there would be gains on FI applications if the stock TB is a point of restriction on top of the improvements to throttle response.
I have a Harrop kit, so I follow Harrop's 86. They have a 2.L stroked/built motor running a TVS 1320 Harrop SC on E85 at 400+whp. I should preface the following by saying that this isn't definitive evidence that a larger TB is necessary, but nevertheless, you can see below that they went beyond their normal kit by making an accessory pulley system, so they could run a larger TB. This suggests that a larger TB would be beneficial in higher horsepower FI applications. By inference, ITBs would also be beneficial.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 11-30-2018, 04:32 PM   #65
ITB's may have gains, but the primary reason is always throttle response.
RayRay88 (11-30-2018)
Old 11-30-2018, 04:33 PM   #66
After NA testing is concluded, my ITBs will be going onto my GReddy turbo car.
The ITBs are mine, and on loan to CSG/DT so they can play with it NA.
It'll be a while, as there's talk of getting different sized trumpets to see what can be done without a manifold as well.
The Following 13 Users Say Thank You to CSG Mike For This Useful Post:
cyde01 (12-02-2018), fatoni (11-30-2018), gtengr (11-30-2018), Iceman (12-01-2018), Irace86.2.0 (11-30-2018), johl (11-30-2018), Lantanafrs2 (11-30-2018), new2subaru (11-30-2018), RayRay88 (11-30-2018), rennlistuser3 (12-20-2020), SuperTom (11-30-2018), whataboutbob (11-30-2018), Williampreza (11-30-2018)
Old 11-30-2018, 05:09 PM   #67
Lantanafrs2
Drives: 2013 frs red
Given the sticker price they should be at least close out of the box imo
Old 11-30-2018, 05:40 PM   #68
Dr. BRZ
Dr. BRZ's Avatar
In 3 years, the price will be down to $1500
Old 11-30-2018, 05:49 PM   #69
Lantanafrs2
If f.i. kits come down in price as well...
Old 11-30-2018, 05:52 PM   #70
Irace86.2.0
I was just calculating things for fun. The stock 65mm throttle body has a cross sectional area of 3318 mm^2. Running 48mm throttle bodies (x4) would be a cross sectional area of 7238 mm^2, so more than double. This would be a rough equivalent of running a single 96mm throttle body, which is bigger than most muscle cars (the Hellcat is 92mm).
Obviously the intake pipes reduce the potential diameter, but it means there is plenty of size to these ITBs for big power numbers.
Last edited by Irace86.2.0; 11-30-2018 at 08:17 PM. Reason: added rough for clarity
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
Delicious Tuning RallySTI User/Vendor/Sponsor Reviews, Feedback, Comments 2 12-02-2017 05:19 PM
Delicious Tuning needs your help! DeliciousTuning Off-Topic Lounge [WARNING: NO POLITICS] 0 08-14-2017 09:33 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
