#57 |
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
Following...
I work at Soin hospital here in Beavercreek and heard about this car through your wife. Hyped to see all of this work done in such a short time. Recently purchased a 2013 FR-S and I am highly considering a swap once my boxer blows up. It's a constant fight between LS and 2JZ. |
#58 |
I Love custom Turbo kits
Drives: Limited BRZ
#59 |
What alternator bracket and alternator are you using? Corvette spacing for serpentine belt and balancer?
#60 | |
Drives: LS Swapped Scion FRS = 440HP
Dont remember which alternator bracket, its the third one I've bought, its works for multiple spacing setups depending on spacers used. I had make a rod-end style tensioner from below. A/C is holley mini-sanderson unit.
#61 | |
Installed the clutch master cylinder: ![]() Process: ![]() ![]() ![]() ![]()
| The Following User Says Thank You to spitsnaugle For This Useful Post: | DustinS (10-08-2018) |
#62 |
That looks perfect!
#63 |
Located the reservoir between the shock tower and brake booster.
Used a mityvac to bleed the system through the reservoir, took a few attempts but worked fine. Used a shorter russell 18" straight 3AN to 90* 3AN line, perfect length with a touch to spare. Noting this in my parts list first post. ![]() ![]() Wide shot of the near-complete engine bay: ![]() Need to figure out where/how to mount an inline thermostat around here:
| The Following 3 Users Say Thank You to spitsnaugle For This Useful Post: |
#64 |
Drives: 2013 LS3 FRS, 3000GT VR4, MKV Supra
Came out great. Let's reconvene and tweak the design so we can get some made for the community!
If anyone reading this wants to see something different with the adapter plate, let Joel or I know so we can get something that will work for everyone! |
| The Following User Says Thank You to VR4EVER For This Useful Post: | Axis2011KR (12-11-2018) |
#65 |
Got the idle smoothed out a bit, tidied up wires, started re-assembling the interior.
Waiting on a quote from a local drive shaft shop that can do a 5 day turnaround vs the driveshaft shop's four weeks. I provided a Strange Engineering chromoly slip yoke for the trans with 1350 spicer joints, they found a flange for the rear dif using 1310 spicer joints, and should be getting back with me today for the rest of the 3" aluminum shaft. Meanwhile, enjoy the ear candy below, though this thing needs a tune: [ame]https://www.youtube.com/watch?v=CR2dQ0D1sr0[/ame] |
#66 |
Local shop is working on the drive shaft. Should be done in two days from now.
![]() ![]() If anyone needs rear diff flange dimensions for the stock diff are Bolts are 60mm apart, or 85mm diagonal = 3.346" Bolt Circle Diameter OD is 103mm OD. Got my radiator lines sorted: ![]() Finished up the wiring around the fuse box. I am using an Meziere electric water pump, I added a terminal and fuse in the box and hid the wiring along the factory loom. Flipped my throttle body upside down, was having hood clearance issues:
| The Following User Says Thank You to spitsnaugle For This Useful Post: | Sportsguy83 (10-15-2018) |
#67 |
Picked up the driveshaft. Got the radiator filled up. Went to install the driveshaft and realized this spot interferes with the U joint.
![]() So I'll be dropping the exhaust tomorrow and cutting that out. Only other remaining to-do's: Vacuum Lines Install lightweight battery (waiting on it to arrive) |
| The Following 2 Users Say Thank You to spitsnaugle For This Useful Post: | Sportsguy83 (10-17-2018), Zer0 (10-17-2018) |
#68 |
Drives: 2017 WR BLUE BRZ
Whatch the other bolts in the tunnel too, parking brake etc.
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | Sportsguy83 (10-17-2018) |
#69 |
Drives: 2013 FRS Whiteout
Let me know, I'll put them on our site to sell
#70 |
I’m interested too for the master bracket.
| Tags |
| cx racing, ls swap, ls2, pure automotive |
| 2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP | ILLSMOQ | Engine Swaps | 172 | 11-24-2022 08:01 PM |
| LS2 swap by KAB Customs with Pure Automotive Motec | Sportsguy83 | Engine Swaps | 254 | 10-17-2018 01:45 PM |
| Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 12:10 PM |
| Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Engine, Exhaust, Transmission | 23 | 05-15-2016 05:21 PM |
| Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 9 | 01-31-2013 02:03 AM |
