Old 09-22-2020, 07:52 PM   #57
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by Joveen View Post
Are the seal oem? Where did you buy them? Also wgat is OCV? How hard would it be on the daily with the exedy stage 2? The build is really coming togethe quite nicely my man.
Sent from my SM-N960U using Tapatalk
Thank you Jovi!
The seals are oem, yes. I got the from Subaru parts wholesale.com
OCV is the oil control valve- mine were super rust covered and gross. I don't know how it will be to daily on the stage 2, I drove a wrx that had a 6 puck and got used to it. This should be less harsh than a traditional 6 puck. I don't have a first hand account of what it'll be like with a lightweight flywheel and lightweight crank pulley, so I'm going to find out for myself! The carbon fiber driveshaft should help make it smoother
I'll attach a photo of the OCVs. The are at the 4 corners of your timing/front cover
The Following User Says Thank You to DarkPira7e For This Useful Post:
Joveen (09-22-2020)
Old 09-22-2020, 08:07 PM   #58
Joveen
Joveen's Avatar
Drives: Bone stock
Carbon ddriveshaft with light weight pulley? I thought that adding the two was not good combo? I usually see fluidampr as the recommended with a light weight driveshaft. Either way when you get the clutch going let me know.
Joveen is offline   Reply With Quote
Old 09-22-2020, 09:00 PM   #59
DarkPira7e
DarkPira7e's Avatar
Yeah the fluidampr is recommended. I will probably end up with one,but I want to see how the car revs and drives with lightweight EVERYTHING! What is life but a chance to try and learn things?
I'll keep you in the loop with the clutch
Joveen (09-22-2020)
Old 09-23-2020, 05:03 PM   #60
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Shit, I would have shipped you my LWP for free, it is a paperweight on my desk.
Old 09-23-2020, 05:34 PM   #61
DarkPira7e
DarkPira7e's Avatar
I can't take something for free, but what would you want for it? If you're actually interested in getting rid of it-
Old 09-23-2020, 05:37 PM   #62
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can have it. I don't feel good about selling it since I consider them snake oil. It came on my car when I bought it 5 years ago so I have no money invested in it. Just PM me your address. It is the Perrin LCP.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkPira7e (09-23-2020), Joveen (09-23-2020)
Old 09-23-2020, 05:47 PM   #63
Joveen
Joveen's Avatar
Drives: Bone stock
Send it to me if that's the case. I'm itching for a new mod while parts are waiting to be purchased.
Old 09-23-2020, 05:59 PM   #64
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Maybe next time. I already processed the shipping.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Joveen (09-23-2020)
Old 09-23-2020, 06:11 PM   #65
Joveen
Joveen's Avatar
Drives: Bone stock
RATS!!
Old 09-27-2020, 01:02 PM   #66
DarkPira7e
DarkPira7e's Avatar
Most of the stuff is here! Everything is basically as expected- injectors look like injectors, fumoto valve looks nice, used clutch and flywheel are used.
BUT
what I want to draw attention to are the following-
Mishimoto fan shroud
Quite a bit thinner than the factory shroud, yay! The plastic the fans are protected by seems sturdy, I was expecting weak flimsy stuff, so that's a bonus. Sleeving on the wiring is done nice, blah blah.
The welds though. Yuck. Every weld looks incomplete or has pinholes. It's no wonder some people have issues with their radiators (specifically why I am not going with an aftermarket rad until I see a cooling issue)
STI transmission mount
I am quite surprised how close this is to bring a solid poly mount. This has quite a bit more fill compared to stock than I was expecting, I have no doubt that this will be exactly what I'm hoping for. I added photos comparing it with my stock mount, I couldn't unwedge my insert so just use it as a way of seeing how much open space there is by comparison.
Radium Engineering fuel rail set
Wow. I was extremely impressed with their catch cans and decided I would use them for anything I could- the rails are nothing less than incredible. The fuel lines and -an fittings provided are beautifully done, the deburring on the edges is perfect, nothing sharp at all. All bolts/adapters are included and packaged well.
I cannot wait to have all of these parts working together, and hopefully for a very long time. I also got my 4 OCVs in. They are from a totaled 2019wrx, $90 shipped with the revised part number? Hell yeah.
Bonus photo- got the throwing wheel cleaned up. Might make a new soup mug for winter. Lost access to the kiln so I'll need to get creative
Old 09-27-2020, 07:53 PM   #67
Joveen
Joveen's Avatar
Drives: Bone stock
Seems like the perrin lockdown bushing can work with sti mount. . Can't wait to see this buttoned up. I'm going with the mishimoto fans as well. Im no electrical guy and I rather have plug and play. Plus the mishimoto sponsorship is cheap. If I need a rad I'm going with CSF.
I thought you bought the South Bend Stage 3? Or was it the Exedy stage 2?
Old 09-27-2020, 09:00 PM   #68
DarkPira7e
DarkPira7e's Avatar
I got the stage 2, yup! I agree with plug and play, should keep things simple. I've had Koyo radiators before and am loyal to them. I'm still on the fence about running the stage 2
Old 09-27-2020, 09:24 PM   #69
DarkPira7e
DarkPira7e's Avatar
Fidanza lightweight flywheel vs stock! Yucky
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
Dzmitry (10-05-2020), jflogerzi (09-30-2020), mrg666 (10-03-2020)
Old 10-04-2020, 12:10 PM   #70
DarkPira7e
DarkPira7e's Avatar
Put it back in the garage, too many leaves and acorns for it to be outside anymore.
Was nice to just sit in it- can't wait for this thing to drive!
brz, frs, iag, jdl, turbo
Joel's BRZ - Low Budget Time Attack Build DIY Member's Car Journals 403 11-19-2024 08:39 PM
Cxracing turbo problem Kalebhall Forced Induction 10 11-16-2017 08:57 AM
Tony's Budget Turbo Build glorydays Member's Car Journals 22 01-26-2015 12:02 AM
My boosted build...on a budget PineappleFriedRice Member's Car Journals 95 08-17-2014 10:29 PM
Aznsky's budget STX build Aznsky Tracking / Autocross / HPDE / Drifting 13 05-12-2014 09:44 AM
