Old 10-06-2022, 03:59 PM   #57
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
this is definitely something i need do too.. just trying to find the exact spot and cleaning is the annoyance.
Decimus is offline   Reply With Quote
Old 11-07-2022, 01:38 AM   #58
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Hmmmmm... It appears my valve cover and/or timing cover is leaking in roughly the same place and getting bad enough to smear the underside of my car. I think it might actually be the valve cover gasket that is leaking.
Option 1: Order the permatex, spray away, and make my life easy.
Option 2: Pull the engine to perform a somewhat difficult operation because I like to torture myself to "do it right"?
Option 3: Try to fix it the right way in the engine bay because I really hate sanity?
Anything I missed?
I should probably update this with what I did. I used the spray, but I haven't been underneath it yet to check how well it worked. I will say that spray acts like super glue. If it gets on you you have about 10 seconds to get it off or you are going to be wearing it for a while. Eye and hand protection is absolutely necessary, and don't wear any fabric sleeves you want to take off afterwards. It will get everywhere.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 04-13-2023, 11:23 PM   #59
Spuds
The Dictater
Spuds's Avatar
Updating this with results. Spray was somewhat effective, but does not stop the leak. The good news is my car has a new stalactite. This is after maybe a hundred miles or so
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 4 04-03-2018 04:06 PM
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 5 12-16-2017 04:19 PM
Timing Cover Oil Leak Keenercarguy Issues | Warranty | Recalls / TSB 66 05-31-2016 12:59 AM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 09:31 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 07:25 PM
