Old 12-28-2017, 11:06 AM   #57
scottman
scottman's Avatar
Drives: 13 mt fr-s
Originally Posted by nickdd6237 View Post
Not any time soon as I just bought the BRZ a week ago.
This was my favourite part.
Drive the car, and do way, way more research.
scottman is offline   Reply With Quote
Old 12-28-2017, 11:28 AM   #58
nickdd6237
Drives: 09 vw gti
Originally Posted by DarkPira7e View Post
If you don't want to listen to the experience of a forum, why not just ask this in the comments section of YouTube videos you watch? Seriously, we're of the function to help guide you, not perpetuate the nonsense (usually) that spreads cancerously to cause a higher tally of blown engines. Will an eBay everything work? Yes. Will it be less expensive? No. Cost of admission is not your total expense; cheap parts WILL BREAK MUCH MORE OFTEN, and will cause more damage when they go. Would you rather replace the ebay turbo 5 times a year, or a quality turbo once every 5-10 years?
When the expensive turbo does go, you'll likely have to have the seals in the turbo replaced. When the cheap turbo goes, you'll be replacing whatever else it breaks with its catastrophic failure. Do you see what we're playing at here? The expensive part is not the initial buy in. You may want to roll your eyes at every forum post on the internet, by that one guy with a 3641 post count and a smug avatar, that advises "Do it right the first time". There's a reason there's one of them for every 50 10 post eBay warriors; because doing it right gives them the time to post. EBay warriors are out trying to fix their car still.
Its my car so I can choose to put whatever Brand Name parts I want. If I choose to go all ebay Chinese parts thats my decision. I'm not asking for suggestions for what turbos are good. Never once did I say I was going with cheap Ebay parts. However I did say I was on a budget.
nickdd6237 is offline   Reply With Quote
Old 12-28-2017, 11:37 AM   #59
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
My apologies, I must have misunderstood this post. Best of luck.
The Following User Says Thank You to DarkPira7e For This Useful Post:
arkanist (01-15-2018)
Old 12-28-2017, 11:41 AM   #60
nickdd6237
Drives: 09 vw gti
They are the same turbo. I wanted input on the differnt sizes.
Old 12-28-2017, 11:44 AM   #61
DarkPira7e
DarkPira7e's Avatar
Exactly, I misunderstood. I can't help you, so I'm saying best of luck! Relax sir.
Old 12-28-2017, 12:20 PM   #62
Timmy_Jones
Spun
Drives: 17' Focus RS
I would buy a header, springs and new tires. Just enjoy the car.
Timmy_Jones is offline   Reply With Quote
Old 12-28-2017, 12:27 PM   #63
FRS Justin
Drives: 2013 Asphalt FRS
I would consider a ED S/C if I were you, its in your budget makes the power you want and comes with a warranty. CSG MIKE can help you on that
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Barefootdan (12-28-2017)
Old 12-28-2017, 01:17 PM   #64
jasonojordan
Drives: 2013 satin white brz limited
Literally the title of his thread (Want to turbo my BRZ...Ideas?) then gets upset when people recommend he stay away from certain parts/brands....This thread will be short lived.
I blew the motor/turbo on my wrx years back. Tried the ebay route. Turbo costed similar to what you want to pay for what you wanna get. Was DOA could not hold boost at all due to a being poorly manufactured.
There are tons of reputable companies out there that will simply work with you on the kit if your only concerns are budget and no internal WG.
Good luck with this thread and your attitude.
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
Tcoat (01-02-2018)
Old 12-29-2017, 12:18 AM   #65
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
if there is any part of a turbo kit I would go for a name brand on, its the turbo itself.
The Garret GT2860R is slightly more than the turbo you linked. I would go with that. I think your hardest part may be the manifold and shaping that properly, but I think you can buy one from a kit without actually purchasing the kit. Just make sure the flanges on the turbo line up properly You'll have to weld in a bung to your oil pan for drain back. IC and charge piping is a routing issue and then you can select which wastegate and BOV you want.
Basic turbo kit on a budget with a good, tried and true turbo, and not the ones you linked earlier.
mjanmohammad is offline   Reply With Quote
Old 12-29-2017, 02:55 AM   #66
nickdd6237
Drives: 09 vw gti
Thanks. Im going to go witb the Maps manifold kit and the Full Blown stg1 intecooler kit. Still might stick to this turbo as ive read others having positive results woth them. The company also sells Borg Warner turbos.
Also i will be buying a pre tapped oil pan.
Old 12-29-2017, 07:55 AM   #67
But those are the parts you are askign for opinions on.
arkanist (01-15-2018), Logikal Reazon (01-14-2018)
Old 12-29-2017, 10:39 AM   #68
Amputechture
Drives: 2014 BRZ
Are you certain that the MAP performance manifold will position the turbo in such a way that the FBM cold side components will line up and fit properly? I suppose that you can always get different shaped couplers and cut them to size if needed....but I don't see the point in piecing together a kit.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
FRS Justin (01-03-2018)
Old 12-29-2017, 10:47 AM   #69
nickdd6237
Drives: 09 vw gti
Size wise
Old 12-29-2017, 10:49 AM   #70
nickdd6237
Drives: 09 vw gti
I'm not sure but I just assumed that they were a reputable company and its made for the brz that it should fit without any modifications. What makes people have to cut the crash beam out?
To save money and choose my own parts.
Mod ideas? _anthonygd BRZ First-Gen (2012+) — General Topics 42 09-08-2015 07:28 PM
New Here Need Ideas FRStrent Scion FR-S / Toyota 86 GT86 General Forum 30 07-10-2014 11:22 PM
In Need Of Ideas!! bh7990 Scion FR-S / Toyota 86 GT86 General Forum 28 05-19-2014 01:14 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 10:57 AM
Need ideas for possible (new-to-me) used car suprachica79 Other Vehicles & General Automotive Discussions 66 02-20-2012 07:42 PM
