Old 04-16-2017, 04:57 PM   #57
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by Izzyboost1 View Post
Hope this helps. If u can't read anything just ask. Tech tip was no longer on tis, so I had to take crude pics of printed version . Enjoy.
Sent from my SM-G900V using Tapatalk
Hank you so much for your help, we will be pulling down and doing the timing over again.
Thanks again for your time and effort
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 04-16-2017, 04:58 PM   #58
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by GsxrMe View Post
Balls.... well kris your going to be a pro at the engine pulling procedure.
Bro, u know
Old 04-16-2017, 05:08 PM   #59
Izzyboost1
Drives: 93 supra turbo auto 13 frs turbo 6
I pulled my cover in the car . 2 hrs to get it off. Hardest part was getting sealant cleaned off. New razor blades and 1 1/2" paint scraper. Do not use wizzie wheel. That stuff is much more difficult to work with than the toyota black fipg I'm used to working with. Pay attention to crank angle on bank 2 when removing tensioner. It's the one that counts. Good luck friend.
Izzyboost1 is offline   Reply With Quote
The Following User Says Thank You to Izzyboost1 For This Useful Post:
Kris86 (04-16-2017)
Old 04-16-2017, 06:34 PM   #60
FRS Justin
Drives: 2013 Asphalt FRS
Here is a tip for dealing with the cray strong sealant. Apply some paint stripper to the sealant and it will soften up and scape right off.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Kris86 (04-16-2017)
Old 04-16-2017, 07:58 PM   #61
Izzyboost1
Cool. Good idea. Thanks for sharing.
Kris86 (04-16-2017)
Old 04-19-2017, 10:07 PM   #62
Izzyboost1
Qurious as to how your cars progress is coming .
Kris86 (04-23-2017)
Old 04-23-2017, 10:31 AM   #63
Kris86
Kris86's Avatar
Drives: RHD Gt86
Bro, not sure how to thank you and everyone who helped me enough
We pulled off the front cover to go over the timing from scratch and the mechanic made a mistake and it was indeed 1 tooth off by the crank gear section
Now I just have some codes coming up that I'm trying to iron out
P0354 - ignition coil #4
P0352 - ignition coil #2
P0203 - injector #3
P0201 -injector # 1
P0230 - fuel pump primary circuit ( I can hear the pump turn on still when I turn my ignition on )
The Following User Says Thank You to Kris86 For This Useful Post:
Kodename47 (04-23-2017)
Old 04-23-2017, 05:37 PM   #64
Izzyboost1
Possible ground left off. I will try to dig into those codes a little more tommorrow.
Kris86 (04-23-2017)
Old 04-23-2017, 07:57 PM   #65
Kris86
Kris86's Avatar
Drives: RHD Gt86
That was the first thing we back checked, all is secured tightly
Old 04-30-2017, 05:10 PM   #66
Izzyboost1
What did u come up with.
Old 05-13-2017, 08:35 AM   #67
MJferg
Drives: Raven black FRS
Been dealing with some similar issues with my engine build... Crankshaft correlation faults to bank 2 intake and exhaust camshaft reference. Had no idea there was a bulletin for it. Hopefully this can help resolve my issue as well
MJferg is offline   Reply With Quote
Old 08-25-2017, 04:28 PM   #68
Kris86
Kris86's Avatar
Drives: RHD Gt86
My mechanic said The car was off timing by one tooth
AVCS - Intake and Exhaust Timing Kodename47 Software Tuning 274 02-28-2021 12:39 PM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 04:12 AM
AVCS tuning Turdinator Software Tuning 9 11-24-2015 02:31 PM
P000A AVCS check engline light? cookiesowns Issues | Warranty | Recalls / TSB 4 10-24-2015 02:48 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 04:01 PM
