Old 05-31-2019, 08:12 AM   #57
tomm.brz
Drives: brz 2017 hksv2
i do 4 times, slow and smooth, 3 seconds to go down, hold 2 seconds, go back 3 seconds, hold w seconds and repeat, 4 times
never ever ever had a single problem with throttle in the 594 reflashes i did in my ecu lol
Old 05-31-2019, 09:47 AM   #58
ermax
ermax's Avatar
I do it with my left foot. I herd that adds 10hp.
Old 05-31-2019, 01:18 PM   #59
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Relevant?
https://www.86worx.com/max-orido-thr...ontroller.html
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 05-31-2019, 02:24 PM   #60
Mase123y
Drives: 2018 BRZ
Originally Posted by Kodename47 View Post
No, Pedal dance is for the VSC. I've seen a few ways to reset the pedal/throttle learning, but the general theory is:
-Have car ignition on but engine not running
-Press accelerator pedal fully a few times
-Start car and idle car for ~1 min (if warm, this can take seconds rather than 1 min)
It doesn't all have to be at once. The accelerator pedal pushing allows the ECU to get max/min values for the pedal sensor and throttle position sensors. Idling allows it to set up the idle airflow. That's all there is to it. 5/10/25 pushes of the pedal I've seen mentioned. I'm not sure why it matters. I do 10, 8 quick with 2 that I hold as hard as I can to finish. Never had an issue.
Is it better to do this after you flash the ECU? Or does it still work without?
Mase123y is offline   Reply With Quote
Old 05-31-2019, 02:49 PM   #61
tomm.brz
reset dtc and do it
Old 09-10-2019, 07:43 AM   #62
FR_STEEZ
Drives: 2017 toyota 86
Originally Posted by Viper8 View Post
The throttle deadband zone (no engine response) from no throttle input to approx 1/4-1/2" of throttle input annoys me too. @steve99 or @shiv - Is it possible to tune the ECU with OFT so that fuel will begin to be fed to the engine earlier at less throttle input (shorten the deadband)?
Has anybody fixed this problem. I absolutely hate that I still have a partial dead throttle. I can see on the oft that it’s picking up my inputs but the motor isn’t reving.
FR_STEEZ is offline   Reply With Quote
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Throttle delay after OpenFlash Kody Software Tuning 34 02-25-2020 03:44 PM
Throttle response delay jay07631 Engine, Exhaust, Transmission 12 07-09-2013 09:41 PM
