Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-15-2012, 11:53 PM   #57
Panman
Panman's Avatar
Drives: 86 GTS
Originally Posted by Nafe View Post
I know what track is and where it is measured from
Here is the detailed calculator I sued
http://gti-vr6.net/library/engine/Sc...ldiameters.htm
I didn't write the software, just entered the details
I rechecked the placard on the wheels (which I have here with me Work Emotion CR-Kai happy to post photo of placard if requested.) 18x7.5 +48.
According to the calculator you used it's actually 22mm increase in track which either way is legal (I went in and entered the details).
I apologise if it seemed I was taking sides - an error on my part.
At this point I bow out of the conversation between yourself and coyote.
Panman is offline   Reply With Quote
Old 07-16-2012, 12:02 AM   #58
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
I worked it out with the 17x17.5 +45 you gave above, Yes the +48 will decrease the track difference.
Didn't think you were taking sides man, just linking to the calculator I had used
Nafe is offline   Reply With Quote
Old 07-16-2012, 12:17 AM   #59
Panman
Panman's Avatar
Drives: 86 GTS
Didn't think youw ere taking sides man, jsut linking to the calculator I had sued
Got it - wanted to make sure I corrected my mistake so everyone was on the same page. I didn't want to add fuel to the discussion
To summarise, according to the calculator with:
18x7.5 +48 and 225/40 18" = 22mm increase in track width.
With documented proof.... (Placard attached).
Old 07-16-2012, 12:22 AM   #60
Nafe
Nafe's Avatar
Sweet, too easy dude
Old 07-16-2012, 01:48 AM   #61
nix
nix's Avatar
Drives: AVO BRZ
Can you two stop measuring your twats, thread is for helping others about legalities.
nix is offline   Reply With Quote
Old 07-16-2012, 01:51 AM   #62
Panman
Panman's Avatar
Drives: 86 GTS
All I know is I'm legal
Old 07-16-2012, 02:00 AM   #63
coyote
coyote's Avatar
Drives: Slowly
Hey, I simply corrected an error ... then bowed out when someone went on a rant. The error needed correcting, as it's important.
I'll state again, for the purpose of testing legality in Qld, a +45 offset will result in a 6mm increase in track, which is legal.
Of course there'll be a small increase in the scrub radius, but that won't have the kind of detrimental effects that offsets of +30 or less may be prone to.
coyote is offline   Reply With Quote
Old 07-16-2012, 03:18 AM   #64
Z86
Drives: 86 GTS Auto in Pegasus White
Is this calculator correct?
If I put in the same details for both wheels it shows track diff as 0 which it should.
Then if I change one tyre by 10mm (so 215 to 225) it says the track changes by 0.39 of an inch.
That sounds wrong to me. The tyres simply get wider but the centre of the tyre doesn't move at all.
Or do I not get it?
Z86 is offline   Reply With Quote
Old 07-16-2012, 03:47 AM   #65
Panman
Panman's Avatar
Drives: 86 GTS
Or do I not get it?
I think you are correct, and the calculator makes the same "assumption" I originally did - Outside of Tyre vs. Centre of Tyre so overall "Track" changes, but not by the definition the QLD government uses which is where the centre of the tyre is in relation to the centre of the car.
Either way the electrons on the interwebz are providing lots of argument fodder and I'm legal.
Old 07-16-2012, 04:11 AM   #66
Z86
Yeah its pretty crazy - the way I see it is going from +48 to +38 is moving the centre of the wheel out by 10mm on each wheel - so total track change is 20mm - regardless of the width of the wheel.
Old 07-16-2012, 04:53 AM   #67
Panman
Panman's Avatar
Drives: 86 GTS
But I don't have a twat.
If I did I'd rather have a 6mm one than a 22mm one though
The Following User Says Thank You to Panman For This Useful Post:
nix (12-02-2012)
Old 12-02-2012, 08:36 PM   #68
giraffee
giraffee's Avatar
Drives: Slowly
Sorry if this is an obvious question, but on the placard of a GT, would it say 16x6.5 or 17x7 (GTS spec)?
giraffee is offline   Reply With Quote
Old 12-02-2012, 09:01 PM   #69
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Both cars would have the GT tyre size i imagine.
Surok is offline   Reply With Quote
Old 12-02-2012, 10:07 PM   #70
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by JDMSushi View Post
Handy info;
AFAIK, the standard wheel fitment on 86's seems to be 17x7.5 +48 for the GTS model.
According to Toyota au website rims are 17x7. Has that changed?
This is my favourite offset calculator:
http://www.rimsntires.com/specs.jsp
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 04:07 PM
[FYI] Street Legal Info Calidrifter Southern California 7 06-29-2012 03:02 PM
Forgestar wheels, great wheels at great prices!!!! IslandImportPerformance Wheels and Tires 0 06-15-2012 06:03 PM
Max legal interest rate? UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 40 03-12-2012 02:50 PM
O.Z. Wheels Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 02-28-2012 04:21 AM
