#57 | |
#59 | |
However, just for the OP's information, the lowest recorded temperature in Anchorage was -42 degrees F. It's my understanding that a fully charged, lead acid battery, won't freeze unless the temperature gets below -76 degrees F. My brother has lived in Anchorage for the past 20 years an never has hooked up any of his vehicles to a battery tender. DANG! This 2 hour late start school day is giving me waaaaay too much free time ..... ![]() humfrz |
#60 |
Drives: Firestorm red FRS 2015
Bad snow cleanup early this morning in Michigan. Got to really test out how well my FRS handled in higher snow with older winter tires... I slipped and slid a fair amount. But only used the snow setting in my sub, otherwise just regular AT. Creeped to work at 30mph... just have to be careful.
#61 | |
Sittin' Sideways
Drives: 2016 Toyota FR-S
-O/D
2016 FR-S, Hot Lava |
#62 | |
Sittin' Sideways
-O/D
#63 |
Drives: 2016 Scion FRS Release Series 2.0
I live in Anchorage too. I daily my FRS and haven't had any problems with it at all in the snow/ice. Traction control does seem to come on a lot and it is jarring. I driven with it off and it's fine too. But with such conditions the main thing is just to be careful, slow down when needed and not drive stupidly. I swear every other day on my drive to/from work I was seeing a car in the center divide or on the side of the road while I was just cruising along.
I know there are a bunch of other guys who daily their 86s in the winter too cause I see them here and there and talked with a couple of them after seeing each other. Anyways I use the Hakka 8 studded tires on my car since Blizzaks weren't that much cheaper while the Nokians seem to be highly regarded. |
| The Following User Says Thank You to Razgriz For This Useful Post: | Tcoat (01-11-2017) |
#64 | |
As a battalion motor officer (an additional duty) for a mechanized infantry battalion in Germany for 2 years, never hooked any of the 100+ vehicles to a tender. Do you know ( @Tcoat knows), how strong a battery it takes to turn over a M-60 tank engine, when it's 0 degree F outside ..... ?? And where would we have plugged in the battery tender ..... ?? I lived in CT and MO for 14 years ..... no battery tender needed. Maybe they just don't make-em (batteries) like they used to ..... ![]() However, a battery tender sure won't hurt anything ...... humfrz Last edited by humfrz; 01-11-2017 at 02:49 AM. |
#65 |
Sittin' Sideways
http://www.6speedonline.com/forums/9...tely-dead.html
This is why I bother. No, it's not a concern across all cars, obviously, just a very poor engineering decision on the part of Porsche (and even worse in the mid to late 90s (my vehicle's era) because those did not have a positive post in the fuse box), so if the battery goes completely dead and you don't have something like the lighter adapter on a battery maintainer to backfeed some power into the car, you're not getting at your battery to jump start it, much less replace it if it's toast. Until owning that car, never had to deal with batteries dying in the winter or any other time of year, either, other than when they've just finally had it and croak naturally. Now I just don't take a chance with letting any of my vehicles sit for long periods of time without getting some charging attention, especially that one. Some caution really can't hurt anything but your electric bill, maybe.
-O/D
| The Following User Says Thank You to Overdrive For This Useful Post: | humfrz (01-11-2017) |
#66 | |
New here!
Drives: 2013 FRS 10 Series
#67 |
New here!
@Razgriz are you using the stock wheels? or using 16 inch steel wheels? One more thumbs up for the Hakkas! Thanks for the advise. I am new to Anchorage, so local info would be helpful.
#68 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | flyboy (01-11-2017) |
#69 | |
New here!
Copied
#70 |
| Another newbie, another mod list (Suggestions wanted!) | MitchEv | Engine, Exhaust, Transmission | 6 | 04-29-2016 10:58 PM |
| Newbie needs... | Salemate | Canada Classifieds | 10 | 12-23-2015 04:07 PM |
| snow....starting to like snow! | brzr | CANADA | 19 | 01-23-2014 01:10 PM |
| Newbie | Toyota 20v | AFRICA | 6 | 01-18-2014 05:32 PM |
| Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires | stockysnail | Northwest | 36 | 12-19-2013 02:12 PM |
