Old 03-12-2013, 10:07 AM   #57
MI FR-S
MI FR-S's Avatar
Drives: Ultramarine FR-S MT
Dealer just replaced rubber seals due to the noise and the old seal being pulled away from the frame.
Still sounds just as loud.
MI FR-S is offline   Reply With Quote
Old 03-15-2013, 01:41 PM   #58
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
My driver side window just started squeaking the other day. I noticed it when I parked to go to work and when I looked down at the window (with it rolled down completely) I noticed the rubber seal (Seal? Weather strip?) was warped slightly and it almost looked like it was sucked down in with the window, so I tried to pry up and loose with my fingers, but it would only budge when I rolled the window up. It doesn't look stuck anymore, but now every time I roll it down or up it squeaks bad.
I'm taking it in for the first oil change tomorrow, guess I'll add the window seal to the list of things to ask about. Crickets and idle miss on cold starts are already on the list.
Nevermore is offline   Reply With Quote
Old 03-15-2013, 01:45 PM   #59
OrbitalEllipses
Drives: Attitude
How's the moisture in the window? I've noticed that after it's all dry outside after a rain, my window squeals like crazy...because there's moisture trapped on the INSIDE of the door panel. Have yet to do/say anything about it because it's one of those things the dealership can't replicate if it's not raining etc.
Old 03-15-2013, 02:04 PM   #60
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
that's exactly what i put in my notes for my upcoming service on wednesday. After it rains and the window drys, if i put the window down and back up, its SOAKED. I can only imagine what kind of rust/deterioration this is leading to. I also get the vertical stripe of water around 2/3 of the way back on both windows even after the rest of it has seemingly dried out
abutterman is offline   Reply With Quote
Old 03-15-2013, 02:06 PM   #61
abutterman
abutterman's Avatar
i was thinking about taking a quick video of it before i bring it in. It's supposed to rain here on monday/tuesday so that'll be just in time. At least then they know what they're looking for
Old 03-15-2013, 02:09 PM   #62
reeves
My windows squeak anytime it's wet.. ever since I bought the car. I wouldn't even trust the dealership to fix it at this point.. I'll wait a while until they have a little more experience with these cars.. maybe towards the end of my warranty period I'll take it in.
reeves is offline   Reply With Quote
Old 03-15-2013, 03:01 PM   #63
OrbitalEllipses
Drives: Attitude
This is EXACTLY what I have.
Old 03-15-2013, 03:15 PM   #64
abutterman
abutterman's Avatar
The water getting trapped in the assembly is most likely causing the freezing issues as well. it snows/rains and water goes inside the door assembly. Then when it's below freezing outside, water turns to ice and window's stuck. I had mine get stuck a couple inches down for 45 minutes while driving with the heat on as high as it can go and had to wait in the parking lot with it until it finally decided to move again.
Old 03-17-2013, 09:19 AM   #65
huertash
huertash's Avatar
Drives: KM4SH FRS
Mine squeaked at the top of the window every time you close the door. Took it tothe dealership and they replaced the whole widow seal. Driver side.
Now is starting in the passenger side
huertash is offline   Reply With Quote
Old 05-08-2013, 01:02 AM   #66
zeroshot9
Drives: 2013 Frs
Originally Posted by TennisHsu View Post
I am experiencing this as well. At first I didn't think to much about the squeek, but upon further investigation found the following:
Drivers side window seem to contact a lot more of the rubber compared to passager side.
This is the view from inside of the car (The gap varies in size, and is a lot larger right after the window meets the seal. Photo was taken after closing the door for a couple of minutes.)
Hoping this doesn't get worse...
I had that problem with the seal went to toyota and they replaced it the next day.
zeroshot9 is offline   Reply With Quote
Old 05-19-2013, 10:51 PM   #67
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by 5hairpins View Post
Mine started this in the rain this weekend. I can see where the rubber on the door sill, right at the curve to the front pillar starts, it pinches the rubber and pulls it away from the door frame.
Mine started to do this after 11 months. I'll be going to the dealer this week. Hopefully, this doesn't keep happening after the warranty is out.
Sigh-on-Rice is offline   Reply With Quote
Old 05-22-2013, 07:57 PM   #68
weedtank
weedtank's Avatar
Drives: Ultramarine
Getting the squeaking too..
weedtank is offline   Reply With Quote
Old 06-07-2013, 12:36 PM   #69
MidnightRunner
MidnightRunner's Avatar
We've had nonstop rain here in south florida for the past week. I've been getting the sqeaking and the rectangular shaped water marks on the window as well. I tore off the door panel today in a fit of rage and snapped these photos. The red arrows show the culprit for those rectangular water marks. Water is getting inside and my window regulator looks a bit rusted as well. I've only had the car for 6 months now! Wtf subaru!
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 06-07-2013, 05:28 PM   #70
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Mine did squeak for like 30 mins, but it automatically went away -- probably seal being too tight or something.
CamryDS is offline   Reply With Quote
Pockmarks on windows? Dang Lad Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 20 09-27-2012 03:52 PM
Remotely lower windows with key fob? Kido1986 BRZ First-Gen (2012+) — General Topics 25 07-16-2012 10:11 PM
Anyone else have problems with their windows after pushing the car too hard? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 9 06-21-2012 11:39 PM
Tinted Windows koolhawk CANADA 20 06-19-2012 07:27 PM
Windows 7 Theme ToyotaObsession Scion FR-S / Toyota 86 GT86 General Forum 0 05-28-2011 03:27 AM
