Old 02-25-2018, 12:30 AM   #57
DIY
DIY's Avatar
Drives: BRZ, WRX
I have finished welding the top of the roll cage now. I was having some difficulty getting flashed with bright light when doing the final welds.
Turns out that because I was looking through gaps trying to get the last few welds that sometimes I was blocking the sensor on my auto-darkening helmet. Another rookie mistake I guess.
After I had finished I quickly ran over all the welds with a wire brush so they would be super clean for painting. I also wiped the whole thing down with some wax & grease remover.
Finally I gave the whole top part of the roll cage a coat of weld through primer so I don't have to worry about it rusting any more.
I ran out of argon today so I will have to go pick up a new bottle when the shops are open. Then I can get the cage back up into position and push on.
DIY is offline   Reply With Quote
The Following 3 Users Say Thank You to DIY For This Useful Post:
Ash_89 (03-01-2021), BigFatFlip (02-26-2018), Irace86.2.0 (09-15-2018)
Old 02-26-2018, 02:20 PM   #58
redlined600
redlined600's Avatar
Drives: Fr-s
Thanks for sharing! I love seeing builds involving actual fabrication.
Old 02-26-2018, 03:09 PM   #59
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Love the updates. Keep on sharing!
Old 02-26-2018, 04:58 PM   #60
DIY
DIY's Avatar
Drives: BRZ, WRX
Thanks guys, I appreciate your support.
Old 02-26-2018, 06:56 PM   #61
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
this is super cool! What do you do for a living that enables you to be so adept at fabrication?
Surok is offline   Reply With Quote
Old 02-26-2018, 08:37 PM   #62
DIY
DIY's Avatar
Drives: BRZ, WRX
When I left school I did a trade making signs, it was called signwriting but it was more like sign manufacture. I used to run the flat bed router to cut out large letters and I also did a lot of the spray painting. Toward the end of my 4 years I was heavily involved in the installation side of things. We did everything from small corporate signs in building foyers to large scale shopping centers, Sydney Airport etc.
I then went back to school at a technical college as a mature age student, following that I did a chemistry degree and now have a masters in scientific research. I work in a material science and engineering research position now and specialize in the use of electron microscopes and focused ion beam.
The Following 4 Users Say Thank You to DIY For This Useful Post:
Ash_89 (03-01-2021), new2subaru (02-26-2018), Surok (02-26-2018), Trust86 (04-01-2018)
Old 02-26-2018, 08:44 PM   #63
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
very handy! i really look forward to seeing you run this car when complete.
it is a great chassis and works well with a lot of power.
The Following User Says Thank You to Surok For This Useful Post:
DIY (02-26-2018)
Old 03-07-2018, 03:52 AM   #64
DIY
DIY's Avatar
Drives: BRZ, WRX
I got a bit done on Sunday and again today. The roll cage is now permanently attached to the chassis, all the tubes are completely welded and I have primed everything to prevent surface rust.
I will leave the door bars and main hoop diagonal off for now for easy access whilst I am building the rear suspension cradle.
Ash_89 (03-01-2021), BigFatFlip (03-07-2018), Irace86.2.0 (09-15-2018)
Old 03-07-2018, 02:57 PM   #65
BigFatFlip
BigFatFlip's Avatar
Sweet progress! Now that cage is mostly done, what's next?
Old 03-07-2018, 05:17 PM   #66
DIY
DIY's Avatar
Drives: BRZ, WRX
The roll cage now gives me a solid foundation for attaching the tubular rear suspension cradle I designed and did FEA on last year. So I will remove the welding jig and start building the main trapezium shaped part which all the control arms bolt to on the bench inside the jig. Once that is done I will bolt it back in the rear frame rails and start attaching tubes from it up to the main hoop of the roll cage. Once those tubes are in place I can remove the jig.
The photo below is my mock up of the rear end which will give you some idea of what it will look like.
I plan on having 2 - 3 bolt hole options for the control arms to attach so I can adjust the ride height without affecting the suspension geometry. I need to do a bit more thinking about the lowest position before I start fabrication.
Ash_89 (03-01-2021), BigFatFlip (03-07-2018), Irace86.2.0 (09-15-2018), Lococholo84 (03-07-2018)
Old 03-07-2018, 05:54 PM   #67
mhiscott
Drives: 2013 FRS
Loving the progress - been watching for a while. Did you take any pictures before you took the body panels off the shell? The origin of the car fascinates me.
mhiscott is offline   Reply With Quote
Old 03-07-2018, 07:07 PM   #68
DIY
DIY's Avatar
Drives: BRZ, WRX
This photo is the day I picked the car up, it had been sitting on a farm paddock under a tarpaulin in QLD for about a year as the importer ran out of space at there warehouse. It was a 12 hour drive each way for me to go get it but I took the family with me and we made a holiday out of the trip.
It came with doors, fenders, boot and bonnet only. I have since bought a front and rear bumper.
Old 03-07-2018, 08:14 PM   #69
mhiscott
Drives: 2013 FRS
Cool stuff that's great! Did the subframes come with it too or did you pick up the rear one used for mockup seperately?
It's great that a chassis never destined for use will see the track!
Edit! Nevermind I see you mentioned early on you needed to source the subframes.
Keep the updates coming!
Old 03-07-2018, 08:36 PM   #70
DIY
DIY's Avatar
Drives: BRZ, WRX
So far I have had to buy both front and rear subframes with control arms and hubs, front and rear bumpers, rear diff, tail lights and I also picked up some rear brembos as they were going cheap. I will probably buy some front brembos too as they should be good enough given the car will be pretty light when done.
