Old 12-20-2016, 11:42 AM   #57
Originally Posted by LotsaMiles View Post
On a related note. I just watched a youtube video of an FRS on the track with a dash cam. The guy was coming around a left hand corner and downshifted too far. He might as well have pulled the e-brake. The car immediately slid to the left right into the wall.
Soooo easy to do by accident.
Old 12-20-2016, 12:07 PM   #58
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
Yep. When you are doing a lot of shifting, it only takes one bad downshift while in a corner. You could actually see the moment he let out the clutch. the direction of the car instantly changed pretty dramatically. I only do that when I WANT to radically drift sideways.
LotsaMiles is offline   Reply With Quote
The Following User Says Thank You to LotsaMiles For This Useful Post:
Tcoat (12-20-2016)
Old 12-20-2016, 12:17 PM   #59
FX86
link to this video?
Old 12-20-2016, 12:43 PM   #60
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Originally Posted by FX86 View Post
link to this video?
I believe they were referencing this video...
HKz is offline   Reply With Quote
Old 12-21-2016, 09:37 AM   #61
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
have your tried downshifting into 5th then into 4th?
Old 12-23-2016, 01:12 PM   #62
paulca
Drives: Toyota GT86 Coupe Red (UK)
2k rpm is fine for cruising. As said by others it won't take too kindly to accelerating though. I regularly sit in 6th at 40mph+
Also, if you are shifting from 6th @ 2000rpm to 4th, the rev difference is probably 1000rpm at most. Hardly a big deal for the syncros and definately not really needing a blip let alone a ducking double clutch. Some people make me wonder.
As to the original problem. The gearbox is very tight when new and it very sensitive to the alignment of the linkage and the box. I have had mine back from the dealers and each time they touch the linkage or the gearbox it comes back with different resisting gears. Currently 1st and 2nd refuse occasionally.
It will probably sort itself out after 10k miles, if it doesn't try getting a mechanic to realign the linkage or fit a shift kit.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 12-23-2016, 01:27 PM   #63
Funny, I don't drive around doing 2,000 rpms at 40 and have never had an issue with shifting to any gear nor ever had a single repair on a tranny.
Old 12-23-2016, 02:06 PM   #64
paulca
I didn't say it was a repair. First was to identify the dreaded shifter rattle, second was to replace the shifter.
When new the car refused 2nd periodically. After their "identify" work it was refusing 4th. After their replacement it's refusing 1st and 2nd again occasionally. I have had the same thing in multiple cars, if the linkage is not aligned correctly with the box some gears can have issues. Chances are it will loosen up in time after the box settles again.
There is nothing wrong with my gearbox. If there was, it would not be due to driving at 2,000rpm or using the clutch and syncros as intended. In fact if you turn the gear shift indicator on it will tell you to shift at 2,000rpm!
It's not an American hunk of Detroit iron remember, it's a well engineered car.
The Following User Says Thank You to paulca For This Useful Post:
Tcoat (12-23-2016)
Old 12-23-2016, 02:14 PM   #65
humfrz
Oh my ........ where to start ......
I'll just pick on the bolded part. That is "adjustable" ......
Got to go eat ma oatmeal ....
humfrz
Old 12-23-2016, 02:21 PM   #66
paulca
Clearly you never turned it on then. Go read your manual, or maybe this is something only fitted in the civilized world.
Old 12-23-2016, 02:35 PM   #67
humfrz
Oh, maybe I misunderstood.
Are you referring to the indicator that shows what gear your car is in ...... or the indicator that blinks and beeps, indicating when to shift ...... ??
humfrz
Old 12-23-2016, 02:37 PM   #68
paulca
Here you go... You'll see that as he is over 2,000rpm the little ^ light starts flashing pretty much as soon as he gets into each gear. He ignores it in 4th and when he shifts to 5th it tells him to get straight into 6th as he eases off. At what 2100rpm?
From experience it will have me up in 5th or even 6th at 30mph. That's about 1400rpm and the car is absolutely fine. At 1400rpm you can't use much accelerator or it will labour, but if you are holding speed on level road it's absolutely fine. In 1st you can roll along at 4mph at 1500rpm in 6th you can roll along at 30mph.
[ame="https://www.youtube.com/watch?v=qZ6F5mNgO8Q"]2013 BRZ Gear Indicator - YouTube[/ame]
Old 12-23-2016, 02:57 PM   #69
humfrz
Here you go... You'll see that as he is over 2,000rpm the little ^ light starts flashing pretty much as soon as he gets into each gear. .............
I see ...... my misunderstanding; I thought you were referring to the light that comes on when you reach a certain RPM ......
No, I have never turned on the feature that shows what gear the MT is in. I just seem to know what gear it is in by the sound of the engine and speed of the car.
Except, occasionally, when I try to take off in 3rd gear, thinking I'm in 1st gear. My FR-S don't like to do that .....
humfrz
Old 12-23-2016, 03:12 PM   #70
humfrz
Say whaaaaaat ........??
Billy Bob done used that for toilet paper ......
humfrz
Blocking Your TPMS Light DarrenDriven DIY (Do-It-Yourself) Guides 77 03-30-2017 12:18 AM
Dealers wrongly mounted your front plate, blocking airflow Zhangy Scion FR-S / Toyota 86 GT86 General Forum 55 04-20-2015 02:47 AM
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 05:20 PM
Blurring/Blocking Licence Plates in Photos btoast Off-Topic Lounge [WARNING: NO POLITICS] 18 06-10-2014 01:42 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
