Old 07-03-2016, 10:05 PM   #57
humfrz
Originally Posted by guybo View Post
I was at a car show this morning doing a 3 point turn to get into a spot and stalled out when I shifted from R to 3rd instead of 1st. THAT'S embarrassing
On this car, first gear is in the upper left corner .......
humfrz
Old 07-03-2016, 10:19 PM   #58
strat61caster
strat61caster's Avatar
Originally Posted by RichardsFRS View Post
The car is easy to stall. I did it a few times when I got it. My wife stalled it the other day but she hadn't driven it in a while. The nature of the clutch in this car makes it very stallable. Just read all the replies if people.who stalled out and Humfs stalling it after driving manual for 65 years (damn I'm old but I haven't been in earth for 65 years) lol
I stalled it going to lunch on Thursday, I've put just under 50,000 miles on my car.
ineedyourdiddly
Old 07-04-2016, 07:51 AM   #59
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
That was only maybe the 3rd time I have stalled it, but it was the worst place to do it with a bunch of people around at a car show with over 300 cars. I was nervous because there was one Mustang that was eyeing up the crowd.
The Following 4 Users Say Thank You to guybo For This Useful Post:
gramicci101 (07-04-2016), krayzie (07-05-2016), NWFRS (07-05-2016), shellslinger (07-04-2016)
Old 07-04-2016, 11:05 PM   #60
Natheria
Overlord
Natheria's Avatar
Drives: SWP 13 BRZ, 94 Miata
I actually own both a BRZ, and an NA miata, and i can tell you from my experience that i believe you were a little spoiled. The miata (and mazda in general) is known for having one of the best feeling shifters of any car. I've also driven several other miatas and mazda 3's and it's pretty consistent. It actually took me a while to get used to other cars after my miata. At the end of the day, while the twins might feel a little different than what you are used to, they still have one of the better feeling clutch/shifter combos of most cars and it takes time to get used to it.
I can tell you that making adjustments to the clutch pedal did help quite a bit for me, both the pedal height adjustment along with the pedal spring delete (I'm actually planning on trying out the MTEC clutch spring).
Having said this, you will still need to get used to the different pedal feel. Keep in mind that because of how the clutch pedal is designed around the spring, it makes it harder not to treat it like an on/off switch. Don't do that. Remember that a clutch is progressive, and the 86's engagment is a little shorter. When you have a shorter engagement than another car you have to drag out that engagement a little more than you are used to. The moment that you feel more force from the pedal pushing back at you, that is where you want to actually slow down your pedal travel to get smoother shifts. The spring will try to work against that and takes a bit of leg work.
All this is meant as tips. Manual is easy to pick up, but hard to master. It took me a solid year of driving the same manual car before i could say i was really comfortable with driving it, and you will still get a little better even after that if you keep learning always at the forefront of your mind. The moment you think you are comfortable with shifting and stop learning, is the day you stop getting better.
"FR-S or BRZ, it doesn't really matter, they're the same to me. It's a matter of choice, like mass effect, but then the thought of boxer engines make my mass erect!" -The Roman
Natheria is offline   Reply With Quote
Old 07-05-2016, 12:28 AM   #61
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
It's okay man I stalled mine in the middle of a street festival last month with everybody looking at me in the middle of a tight intersection while trying to make a 3 point turn, as I was too busy trying to figure out how to navigate out of the side streets with cars parked on both sides.
krayzie is offline   Reply With Quote
Old 07-05-2016, 04:14 AM   #62
humfrz
Originally Posted by Norville Rogers View Post
That's reverse on mine.
First is in the upper left hand corner .....(no lifting with fingers allowed..... ).
humfrz
Old 07-06-2016, 09:32 AM   #63
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
One thing I hate about this car with push start is that. If I stall in the middle of the road, I always fuck up the starting up part by pushing that push start one too many time....🌭
Old 07-06-2016, 11:59 AM   #64
Peaty
Scooby***s Guy
Peaty's Avatar
Drives: 2019 Impreza Sport - MT
Careful ........ that top down experience can be addictive .........
humfrz
I have an NB Miata (1999) and a 2016 BRZ a few months old. I was going to sell the Miata but I just can't bring myself to do it. I love my BRZ I really do, but the Miata so fun to drive and the shifting is way more intuitive and smooth. I'm still getting use to the shifting on the BRZ, it's my first 6-speed but I'm sure before long it will become more natural. It's still pretty new to me. I have to look into the clutch spring mod that sounds like a good idea from everything I've read.
Peaty is offline   Reply With Quote
The Following User Says Thank You to Peaty For This Useful Post:
humfrz (07-06-2016)
Old 07-06-2016, 12:21 PM   #65
gramicci101
Off Topic
Also look into better fluid and MTEC shift springs. It makes such a huge difference in shifter feel.
The Following User Says Thank You to gramicci101 For This Useful Post:
Peaty (07-06-2016)
coasting, jerky, miata, noob, upshift
Driving around. Chen Northwest 27 02-05-2014 11:47 PM
The Joy of Driving Be-Are-Zee BRZ First-Gen (2012+) — General Topics 17 07-21-2013 09:45 AM
Driving section - actually driving the things somewhere bcj Site Announcements / Questions / Issues 6 04-08-2013 12:28 PM
Driving in the wet Turdinator AUSTRALIA 47 11-28-2012 04:23 AM
Driving too much! F3dzo Scion FR-S / Toyota 86 GT86 General Forum 15 07-15-2012 02:14 AM
