Old 02-17-2019, 03:31 PM   #57
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
Originally Posted by Antonovich View Post
No rubbing in the back that I can see. And there's only 2 spots up front where it's rubbing, that I can see: small spot on the front bottom liner, I think I can get that with a heat gun. Another is the Rally Armor mudflaps, or more specifically, the bottom inside portion of the bracket. I'll definitely do some cutting and grinding.
As far as LCA's in the back, the lift kit I bought came with extra 1-inch spacers for the whole subframe, so I'm not sure LCA's are even necessary. This is what I got: Spacers
The knocking sound, my theory is that because the struts now sit 2 inches lower, the end-links push the sway bar lower and it's making contact with the steering shafts. I've ordered shorter end-links, see if that fixes the problem.
Will take more pics when I install the end-links, do some trimming, and get a wash.
IIRC They both had rally armor flaps and both had to remove the front ones due to rubbing. So that may be the issue.
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
Old 02-19-2019, 04:35 AM   #58
Antonovich
Drives: '13 BRZ, 04 rust bucket Suburban
So I'm thinking instead of cutting the bumper and grinding the rear of the fender, what if I try to fold them over instead. For the bumper, since it's pretty much just plastic, would heating it with a heat gun and folding over work? For the fender, I'm thinking of taking a hammer to it and folding it inside the body work. Then simply re-drilling the holes for the fender liner. Because if I cut the bumper and grind the fender, how would I attach the fender liner. I definitely don't want to daily this car with no liners!
Antonovich is offline   Reply With Quote
The Following User Says Thank You to Antonovich For This Useful Post:
TeutonicShift89 (02-21-2019)
Old 04-09-2019, 11:12 PM   #59
scottman
scottman's Avatar
Drives: 13 mt fr-s
So.
Updates?
scottman is offline   Reply With Quote
Old 04-10-2019, 11:00 PM   #60
TeutonicShift89
I think @JazzleSAURUS mentioned in an earlier post that he had made some customer fender liners for @LiftedBRZ.
I wonder if the Leh Keen Project Safari 911's are running customer fender liners as well?
Old 04-11-2019, 10:46 AM   #61
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
New mounting points, sheets of PU, push pins. They are less sophisticated than the OEM ones, but do what they can. The widebody is not included.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 05-27-2019, 06:27 PM   #62
timandytimandy
Wanna-be
timandytimandy's Avatar
Drives: 2013 Firestorm FR-S
So what are the limitations of the stock arms? Looking at a 1” or 1.5” strut spacers but don’t want to get aftermarket arms or drop the subframe.
timandytimandy is offline   Reply With Quote
Old 06-24-2019, 02:52 PM   #63
scottman
scottman's Avatar
Drives: 13 mt fr-s
Finally snapped a couple.
15x7+48 MR501-VT's, 205/75/R15 front and 215/75 rear.
The Following 5 Users Say Thank You to scottman For This Useful Post:
bcj (06-28-2019), JD001 (11-04-2019), Lorico (08-26-2019), Spankopotomous (04-06-2021), TeutonicShift89 (06-27-2019)
Old 06-27-2019, 10:21 PM   #64
Jkosmo
Drives: 2013 BRZ G2 Rally Car
Couple pictures from Southern Ohio Forest Rally this year.
Check out our FB page for BRZ Rally Updates
https://www.facebook.com/OddBirdRacing/
Jkosmo is offline   Reply With Quote
The Following 4 Users Say Thank You to Jkosmo For This Useful Post:
bcj (06-28-2019), BigTuna (06-28-2019), Clutch Dog (06-27-2019), TeutonicShift89 (06-29-2019)
Old 06-27-2019, 10:29 PM   #65
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
this brings me joy
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
Old 06-28-2019, 08:59 AM   #66
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Ugh, I had planned on going to the SOFR but something else came up that weekend. Looks like a blast.
BigTuna is offline   Reply With Quote
Old 08-02-2019, 06:53 PM   #67
TeutonicShift89
Found these under an All Japan Rally heading I believe. Looks like 15'' gravel spec rally wheels but they are clearly doing some tarmac as well in the photos.
I still keep going back to the idea of the 15'' wheels with an all season tire for just hoonish street/forest road fun.
Any ideas about potential road tires?
Old 08-27-2019, 07:07 AM   #68
scottman
scottman's Avatar
Drives: 13 mt fr-s
I use Firestone Destination A/T's.
But I also do mostly gravel.
They've been good.
Old 08-27-2019, 05:17 PM   #69
Jkosmo
Here's a few pics from our weekend up in Minnesota @ Ojibwe Forests Rally.
The Following 2 Users Say Thank You to Jkosmo For This Useful Post:
BigTuna (08-28-2019), TeutonicShift89 (09-05-2019)
Old 08-27-2019, 05:50 PM   #70
Lorico
Drives: 2015 FRS
not rally, just wanted to share the beef mode
Lorico is offline   Reply With Quote
The Following 2 Users Say Thank You to Lorico For This Useful Post:
FLIPDADY (02-04-2020), S84kam (08-27-2019)
WORLD RALLY BLUE BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 1269 10-25-2025 02:27 PM
Rally GT86 - The Little Car That Could - Lots of rally video and photos! Circuit Motorsports Tracking / Autocross / HPDE / Drifting 48 10-12-2020 04:32 PM
BRZ/FRS VIS Carbon Fiber oem style hood and AMS style trunk. BNIB. js0uth Exterior Parts (Aero, Lighting, Etc.) 76 12-03-2014 05:37 PM
86 Farm Style (Rally Test?) [Video] BenArmstrong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 81 04-10-2014 02:39 AM
Akio Toyoda Drives the 86 Rally Style (Dirt and Snow) nate89 Scion FR-S / Toyota 86 GT86 General Forum 3 02-10-2012 12:22 AM
