Old 01-01-2017, 02:17 PM   #57
celek
Resident Gear Head
celek's Avatar
Originally Posted by SPCorBUST View Post
Is there any reason to update to a closed deck sub 500hp?
Not really 500 HP is about the limit before sleeves start to wiggle causing head gasket failure under extreme abuse
Originally Posted by Irace86 View Post
Adding to that...
Maybe I missed the answer that was said already, but why do this? Is this stronger than sleeves, for different setups than sleeves, necessary for certain hp goals, the weak link in this motor?
Stock sleeves have held to 800 HP but they will wiggle see above quote
Not saying it's the only reason, but besides supporting higher horsepower I've heard that sleeves have a tendency to drop.
Sent from my SM-G925T using Tapatalk
Stock or after market?
Stock will not drop, aftermarket sleeves only drop when improperly installed, commonly with an epoxy or glue that shrinks, you are not supposed to do that as the liquid adhesive creates an air pocket and and holds the sleeve up then it drops.
Is the combustion chamber a weak point?
I have seen stock sleeves exceed 750 WHP, as stated above partially 500-600 they start to wiggle causing gasket failure. Closed deck will fix the wiggle. But find a transmission to support it is the real problem here
celek is offline   Reply With Quote
So UPS dropped this off today xwd Forced Induction 48 08-12-2014 10:06 PM
6/23/14 - Could the Subaru BRZ Be Dropped Entirely? 468Power Scion FR-S / Toyota 86 GT86 General Forum 33 06-25-2014 10:14 AM
Dropped TheseColorsDontRun Mid-Atlantic 0 02-28-2014 08:23 PM
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-25-2014 10:46 AM
86FEST Video just dropped Nivek BRZ Photos, Videos, Wallpapers, Gallery Forum 5 06-30-2013 03:24 PM
