Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
#57 | |
The Dictater
Drives: '13 Red Scion FRS
![]() In rolling motion, you have two types of velocity, translational and angular. Angular is always perpendicular to the radius, while translational is a constant in the direction of travel. To get the velocity of any point on the wheel, you add both of these velocities together. First, break down the angular velocity into it's horizontal and vertical components. This is typically done through basic trigonometry, but to spare you the math we will look at 4 easy points to visualize. At the bottom of the wheel is as negative (backwards) as it is going to get. At this point all of the angular velocity is horizontal. At the top of the wheel it is as positive (forwards) as it is going to get, again the velocity is 100% horizontal. At the front and the back (relative to the car) of the wheel, the horizontal velocity is 0, meaning those points are traveling vertically. Don't believe me? Have someone swing a weight on a string and watch it from the side. Knowing that, the best chance for a rock to be flung straight back is if it were flung from the bottom of the wheel right? However, we know that the bottom of the wheel, in contact with the ground, has to be moving at the same speed as the ground, otherwise it would be slipping. Which means that the bottom of the wheel must be moving at a horizontal velocity of 0kph. As discussed before, the bottom of the wheel is the most negative angular velocity you can have. So if the point of the wheel with the most negative angular velocity is traveling at an total (angular+translational) velocity of 0, then all other points on that wheel must have a positive total velocity. Therefore something which at one point matches the actual velocity of the wheel and is then thrown off can only be going forward or remain stationary.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following 5 Users Say Thank You to Spuds For This Useful Post: | blsfrs (05-12-2023), JD001 (05-16-2023), NoHaveMSG (05-12-2023), Ultramaroon (05-12-2023), WNDSRFR (05-12-2023) |
#58 | |
The Dictater
The Following 2 Users Say Thank You to Spuds For This Useful Post: | blsfrs (05-12-2023), Ultramaroon (05-12-2023) |
#59 | |
Drives: Subaru BRZ
#60 | |
Drives: Subaru BRZ
#61 |
Here is a novel idea, you know some times a part can do more than one function.
#62 | |
Drives: FR-S,GTI
Take it easy, it's just a rubber flap. |
#63 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
So at 60mph does mud/roks fling down the skirts/sills off the tires OR is the mud travelling vertically and the sills are hitting the mud at 60mph. Similar impact but one is the mud/rocks moving the other is the car.
Wait until my Flex capacitor hits 88
The Following User Says Thank You to gen3v8 For This Useful Post: | blsfrs (05-12-2023) |
#64 | |
Drives: Subaru BRZ
https://www.ft86club.com/forums/show...&postcount=859 |
The Following User Says Thank You to JD001 For This Useful Post: | blsfrs (05-12-2023) |
#65 | |
Drives: Crapcan
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#66 |
Drives: Subaru BRZ
Noooo... Stopped myself from popping the question as I felt a bit stupid asking... However, once the dust (or the rocks) have settled I will ask.. I am planning another trip to Fensport to get the poly bushes installed..
The Following 4 Users Say Thank You to JD001 For This Useful Post: |
#67 |
Master Collaborator
My old lady just calls it "...that flappy thing down there...".
The Following 4 Users Say Thank You to FR-S2GT86 For This Useful Post: |
#68 |
helmholtz resonator
Drives: '15 ultramarine
The Following 4 Users Say Thank You to Sapphireho For This Useful Post: |
#69 | ||
Proud of BOXER
Drives: Subaru Boxer
#70 |
Drives: 2023 brz limited 6mt red
It’s actually a tuna sandwich with crust
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
The Following 4 Users Say Thank You to vindiesel For This Useful Post: |
Stupid question but... | Raven240 | Software Tuning | 2 | 04-21-2015 11:15 AM |
Sorry, stupid EL vs. UEL question... | Tromatic | Engine, Exhaust, Transmission | 63 | 06-08-2014 07:03 PM |
stupid question about brz | andrewmay9 | BRZ First-Gen (2012+) -- General Topics | 55 | 05-17-2014 03:10 AM |
Really stupid question regarding oil | hansthegerman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 10-08-2013 07:56 AM |
Stupid Question | Canibuz | Engine, Exhaust, Transmission | 24 | 03-05-2012 09:50 AM |
