Old 03-14-2016, 07:18 PM   #6931
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by Iamwu View Post
Hmm I'll go and check its diameter.
@ StockySnails, let me know how that blue belt works out for ya.
Blue belt fit better than the non blue. It's just a little tighter, perhaps because it doesn't flex as much? The non-blue tends to only last about 6 months before it starts squeaking a little. Hopefully the blue resists the squawk.
Check my build thread for a picture. Too bad it's not a red belt to match the rest of my car.
stockysnail is offline   Reply With Quote
Old 03-14-2016, 08:09 PM   #6932
Dream20b
Y u do dis?
My 335 update:
so far so good, need to put the belt on, buy a set of Fuel Injectors, a Fuel Pump, and get it Dyno Tuned.
Please ignore the hose going off to the right of the engine bay.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 03-15-2016, 09:22 AM   #6933
Rich196
Drives: GT86
Do any of you used your sprintex 210 for track days? If so what kind of peak IATS are you seeing after a few laps, and what are doing to control them?
Rich196 is offline   Reply With Quote
Old 03-15-2016, 01:14 PM   #6934
stockysnail
Just the tip
I use my at the track a few times a year. I'm not sure what my post blower intake temps are however since I don't have any monitoring on it. My oil is nice and cool with the oil cooler however as I have a Scangauge monitoring it. My catch can picks up a little more blow by at the track vs the street but nothing bad.
Old 03-15-2016, 01:19 PM   #6935
Kodename47
Kodename47's Avatar
Drives: UK GT86
Very few people have the IAT kit like ours. Did you get any data at Donny on the P3? I'm also keen to know.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-15-2016, 07:04 PM   #6936
Docmattic
Drives: GT 86
I've had the 210 installed for three months now. Soon to buy an oil cooler. Just reading your posts here, do you need a catch can with this kit if only a street car?
Also, what oil are you guys running?
Cheers,
Nick.
Docmattic is offline   Reply With Quote
Old 03-17-2016, 03:29 PM   #6937
jwvand02
Drives: 2013 SWP BRZ Limited
Originally Posted by Dream20b View Post
My 335 update:
Does the 335 bolt directly to the same manifold as the 210?
jwvand02 is offline   Reply With Quote
Old 03-17-2016, 03:32 PM   #6938
jwvand02
Originally Posted by Chad86 View Post
With my 335 install coming soon, I have a few questions.
First I assume my shop should already know this, but I will just mention it to them ahead of time. If I understand correctly, after install, the tune must be flashed to the car prior to the first startup with the supercharger installed.
How soon will I need new brakes running approx. 300hp? Is it unsafe to be running the stock brakes with this much power? I heard the stock clutch is good up to 350hp.
My oil change is scheduled soon. Is it necessary to chang out the oil when installing an oil cooler?
Coilovers have been purchased for upgraded suspenion. I just have to decide on the right set of rims and tires for my setup.
The clutch is really more torque limited. It will typically hold around 250wtq, which you should be surpassing with the 335.
It's not a guarantee as some people have made it farther with it, but mine is definitely not holding up at something closer to 235wtq. It slips at speed if I give it much gas in higher gears.
Old 03-17-2016, 03:35 PM   #6939
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
yes
Old 03-17-2016, 03:46 PM   #6940
Dream20b
Y u do dis?
Originally Posted by Shutter View Post
yes
mmmhmmm.
Dat Hot Lava Doe
Old 03-17-2016, 03:51 PM   #6941
continuecrushing
@Dream20b get an oil cooler on that thing!
Old 03-17-2016, 04:20 PM   #6942
Dream20b
Y u do dis?
I'm out of money. that's coming later.
Dat Hot Lava Doe
Old 03-17-2016, 04:53 PM   #6943
continuecrushing
no worries, just make sure its the first thing!
I was gonna wait for a while myself, then I saw 220F cruising temps on freeway, and 264F during a short canyon run on my 210 kit with no cooler (and that was in low 70ish temps outside/ambient).
Haven't pushed the car since I installed the cooler, but on freeway I sit at 185-190F now, since its been installed.
Old 03-18-2016, 02:51 PM   #6944
Dream20b
Y u do dis?
We're running exclusively e85 on this setup to help keep engine temps down.
Dat Hot Lava Doe
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
