Old 03-08-2016, 08:06 AM   #6903
Dream20b
Y u do dis?
Originally Posted by Rifle View Post
3 FT... so roughly 900mm.. 3/8... that's the hose that runs from the throttle body to the back of the engine block for coolant, no?
it could be closer to 4 ft, but I didn't unplug the hose to the coolant and nothing spilled out of the engine on install so either I have no coolant in the engine or that's not the right hose.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 03-08-2016, 09:14 AM   #6904
Iamwu
Drives: 86
Originally Posted by Chad86 View Post
I hope you removed the hood liner.
Yeah hood liner has been removed.. Sounds like I'm the only one encountering this issue. Perhaps my engine mounts are shot?
Iamwu is offline   Reply With Quote
Old 03-08-2016, 09:50 AM   #6905
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
What size pulley are you running?
CarzCarzCarz is offline   Reply With Quote
Old 03-08-2016, 11:20 AM   #6906
tegunulgener
tegunulgener's Avatar
Drives: Dark Side
By any chance, did you hit to speed bump? It might bend the protection cover under... just a guess of course.
Sent from my HTC One M9 using Tapatalk
tegunulgener is offline   Reply With Quote
Old 03-08-2016, 11:33 AM   #6907
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Kodename47 View Post
I can get over 60C doing street pulls but I haven't seen much over 65C although I haven't really had extended periods of hard driving.
Ambient: 7C
Ambient: 17C
Ambient: 25C
Where are you measuring your IAT's from? the MAF sensor (pre-blower)? or did you install an additional IAT sensor?
Old 03-08-2016, 01:07 PM   #6908
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've always run an IAT sensor on the MAP sensor plate on this kit.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-08-2016, 04:38 PM   #6909
xjohnx
Grip>Slip
xjohnx's Avatar
Gotcha. I thought it was worth differentiating since most others are likely comparing the IAT's as reported by the ECU from the MAF sensor, which is pre-blower and not comparable.
Old 03-08-2016, 06:55 PM   #6910
Dream20b
Y u do dis?
Originally Posted by Dream20b View Post
I'm installing a 335 Kit (thanks smudge) and I've got one hose I cannot figure out where it goes- it comes off the bottom back of the supercharger by the intercooler plate and its about, 3 feet in length and about 1/4in or 3/8in in interior diameter. does anyone know where this goes? I'll get pics in a second.
@SprintexUSA any ideas? 335 Kit.
Also wondering what hose goes to the brass nipple on the center rear of the metal elbow. I've screwed up somewhere and i'm not seeing it. It could be closer to 4 feet.
@smudge
Dat Hot Lava Doe
Old 03-09-2016, 03:55 AM   #6911
sam69
Drives: GT 86
Brass nipple goes to the rear crankcase breather and the plastic one next to it on your pass side goes to the brake booster (our drivers side) if that makes sense.
sam69 is offline   Reply With Quote
The Following User Says Thank You to sam69 For This Useful Post:
Dream20b (03-09-2016)
Old 03-09-2016, 04:04 AM   #6912
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Putting the supercharger back on today. Wish me luck!
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following User Says Thank You to Rifle For This Useful Post:
Old 03-09-2016, 08:38 PM   #6913
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
Finally my 335 install is scheduled for April 26. Does anyone know how Sprintex is faring against the new Edelbrock supercharger?
If my engine ever blows, I might consider this or a straight 2JZ swap.
I hope to be in good hands with Moto-East's 335 tune.
Sprintex is clearly the winner with a Moto-East tune.
I found the Edelbrock specs on their website 242HP 186TQ (I assume this is not 242 @ the wheels)
Sprintex FTW!
Chad86 is offline   Reply With Quote
Old 03-10-2016, 02:20 AM   #6914
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Sprintex FTW!
Yes it's to the wheels and it's using the Carb approved pulley size. If you use a smaller pulley on the Edlebrock it will out perform the 210 Sprintex, and be more in like with the 335 Sprintex. 335 has more potential but the intercooler is the Sprintex's weakness. Edlebrock has a more efficient design. I think the Cosworth intercooler is even better than all of them since the cooling potential seems greater, but the Edlebrock uses a slightly larger supercharger than the cosworth.
stockysnail is offline   Reply With Quote
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
Dream20b (03-10-2016), tegunulgener (03-10-2016)
Old 03-10-2016, 09:50 AM   #6915
Dream20b
Y u do dis?
The hose in question was for a boost gauge. Thanks!
Dat Hot Lava Doe
Old 03-10-2016, 10:34 AM   #6916
Iamwu
Drives: 86
Running a 69mm pulley
My idler pulley is 70mm. For what its worth, the K061010HD (shorter) belt also would not for me whatsoever.. I had to stick with the K061015 belt..
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
