Old 03-04-2016, 03:35 PM   #6889
tegunulgener
tegunulgener's Avatar
Drives: Dark Side
Fingers crossed and good luck mate.
Sent from my HTC One M9 using Tapatalk
tegunulgener is offline   Reply With Quote
Old 03-05-2016, 01:42 AM   #6890
Pekingduck
Drives: 4 wheels
Originally Posted by COO86L View Post
Okay peeps, having a bit of an ish at the moment.
Under load in 3rd and 4th gear mostly, between 3k and 5k there is a bit of hesitation. There doesn't appear to be any knock from what I could see. I switched back to stock ROM and it was the same/worse.
Is this something in the tune or have I got some form of leak? I've checked everywhere and all bolts are tight, don't appear to be any obvious gaps under manifold. Fuel likes are free and loosey goosey so not pinched.
Any ideas?
69mm pulley, intercooled, stock MAP sensor and intake and MAF, Tomei UEL and over pipe, stock front pipe and catback.
Mine was the same also with base tune 69mm and after with delicious tune the car ran great.
e
Pekingduck is offline   Reply With Quote
Old 03-05-2016, 02:32 AM   #6891
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
e
Okay that's a relief. It felt like it was more in the tune, like it was fuel starvation or something because it isn't throwing codes and can't hear any ping. It's started happening extremely bad at the moment.
Hopefully getting EcuTek tune from a US Master Tuner next week. Don't trust the ones in Aus enough.
COO86L is offline   Reply With Quote
Old 03-05-2016, 06:09 AM   #6892
steve99
You wont hear knock or pinging unless its extremly bad, you need to log
IAM
FLKC
FBKC
Old 03-06-2016, 12:23 AM   #6893
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
Finally my 335 install is scheduled for April 26. Does anyone know how Sprintex is faring against the new Edelbrock supercharger?
If my engine ever blows, I might consider this or a straight 2JZ swap.
I hope to be in good hands with Moto-East's 335 tune.
[ame="https://www.youtube.com/watch?v=TGpY-oncQUo"]EKanoo Racing 2013 Toyota 86 2JZ - Presented by Emil Frey featured on Vova.ch - YouTube[/ame]
Chad86 is offline   Reply With Quote
Old 03-07-2016, 02:09 AM   #6894
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Anyone know where I can get a MAP plate with a nipple so I can run a boost gauge tube to it? The bolt on the rear of the sprintex stripped when I tried to remove it.
OR
If you don't know where to get a plate with a nipple, perhaps help instruct me on how to drill a hole in one and what to do to get a nipple on it. I don't really know anything about welding or metal work so I have not idea how to do it myself if I buy a new plate.
stockysnail is offline   Reply With Quote
Old 03-07-2016, 10:29 AM   #6895
sam69
Drives: GT 86
Take the plate off and drill and tap it for a small barb fitting something similar to one of these , http://www.ebay.com.au/sch/i.html?_f...tting&_sacat=0
You should be able to buy the right tap from any good hardware or tool shop and search you tube for some hints on choosing the right size drill bit for the tap .
It's not that hard so take your time and do a bit of research and you'll be fine
Also what's the highest intake air temp has anyone seen with the Sprintex 210 intercooled setup as I'm installing a IAT and just wondering what to expect .
Have seen someone say they got 69 c on the dyno but do these things get any hotter than that ??
sam69 is offline   Reply With Quote
Old 03-07-2016, 11:42 AM   #6896
Kodename47
Kodename47's Avatar
Drives: UK GT86
I can get over 60C doing street pulls but I haven't seen much over 65C although I haven't really had extended periods of hard driving.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
sam69 (03-07-2016)
Old 03-07-2016, 03:39 PM   #6897
Dream20b
Y u do dis?
I'm installing a 335 Kit (thanks smudge) and I've got one hose I cannot figure out where it goes- it comes off the bottom back of the supercharger by the intercooler plate and its about, 3 feet in length and about 1/4in or 3/8in in interior diameter. does anyone know where this goes? I'll get pics in a second.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 03-07-2016, 07:38 PM   #6898
Iamwu
Drives: 86
Does anyone have clearance issues with the supercharger belt touching the bottom of the hood ? My hood looks pretty marred up from it; and could possibly be why I've snapped a couple belts already.
Iamwu is offline   Reply With Quote
Old 03-07-2016, 10:35 PM   #6899
sam69
Drives: GT 86
What was the ambient air temp if you know or can remember when you saw that Kodename ?
Hoping someone that's tracked their car in warmer condition might have some figures/ data .
Old 03-08-2016, 01:04 AM   #6900
Chad86
Chad86's Avatar
Drives: Toyota GT86
I hope you removed the hood liner.
The Following User Says Thank You to Chad86 For This Useful Post:
Rifle (03-08-2016)
Old 03-08-2016, 01:06 AM   #6901
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
3 FT... so roughly 900mm.. 3/8... that's the hose that runs from the throttle body to the back of the engine block for coolant, no?
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 03-08-2016, 03:40 AM   #6902
Kodename47
Kodename47's Avatar
Drives: UK GT86
Ambient: 7C
Ambient: 17C
Ambient: 25C
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
ajc209 (03-08-2016), sam69 (03-08-2016)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
