#673 | |
Drives: 2022 BRZ Limited
I don't recall the rules since I never attended any NASA event with a convertible (only with the BRZ) but most TT cars had full cage vs HPDE cars which makes sense
| The Following User Says Thank You to glamcem For This Useful Post: | brzaapi (08-26-2015) |
#674 | |
#675 |
Drives: 2010 MS3
Damn, that all new TT looks horrible.
#676 | |
Drives: '23 BRZ Limited
Lack of decent roll bar setup is part of the reason I ditched my NC and got the BRZ.......... |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | glamcem (08-26-2015) |
#677 |
I hear you .. to be honest, I initially didn't really care for the rollover protection as much but after seeing a few crash videos they completely changed my mind
| The Following User Says Thank You to glamcem For This Useful Post: | OkieSnuffBox (08-26-2015) |
#678 | |
Drives: 2019 MX-5 RF GT-S, 2002 Miata LS
![]() On an NC/ND, the top folds differently, and you can't use the same design without removing the soft top. So you see designs like the Petty bar or the removable rear bracing from the trunk linked above. As far as safety for street use, check out the picture above, and tell me if you think the passenger is safe from hitting their head on the bar. The bar in the picture does have the recommended high-density foam padding, but that's not enough to protect your head in a rear-end collision. You're supposed to wear a helmet or install a seat with a high enough back to protect your head. This is still, IMO, the twins' biggest advantage if you want your car to serve double duty as a track toy and daily driver. My personal solution is to keep my NB when I buy an ND next year.
| The Following 2 Users Say Thank You to Entroper For This Useful Post: | DarkSunrise (08-27-2015), glamcem (08-27-2015) |
#679 | |
![]() douple hoop bar on my NC miata was a lot more street-friendly but it was also more expensive than "Hard Dog", also need to add, it's dramatically cheaper to mod an NA or NB compared to an NC Miata, not sure how the ND will be..too bad the new ND doesn't have a special motor like the NC but instead comes with a mass produced low-revving Mazda 3 engine :/ this would be my favorite mod if I ever go back to Miata ![]() http://www.bbrgti.com/product_detail...e=18&model=531
| The Following User Says Thank You to glamcem For This Useful Post: | Entroper (08-27-2015) |
#680 |
NC used the MZR engine, which was also the mass-produced Mazda3 engine at the time. The NC2 added forged rods and crank, but the Skyactiv engine has those in the Mazda3 already.
The ND version of the Skyactiv has been tuned for 91 octane. The torque peak is marginally higher, and the throttle response is significantly improved, especially in the low range. There was an interview somewhere with Dave Coleman where he explained that part of the reason for DBW throttle delay is to control detonation from snapping the throttle open too quickly. EDIT: There's a really good and thorough review of the Skyactiv tech here: http://www.motoiq.com/MagazineArticl...echnology.aspx |
| The Following User Says Thank You to Entroper For This Useful Post: | strat61caster (08-27-2015) |
#681 |
Drives: 2015 AOZORA EDITION
The answer is always miata
Sent from my SM-N910W8 using Tapatalk |
#682 |
Another track, another test, another result:
MX-5 still wins, but by less than an eye blink this time. Pretty cool side by side with a little bit more detailed commentary on how the laps were different. |
#683 |
Only happy when it rains.
Drives: series.blue
That was a fun review to watch, someone that gets these cars aren't all about the quickest lap times.
#684 |
Drives: Porsche Cayman, Audi A3
#685 | |
The ND Miata as spec'd in that video seems to be good value. About 2000 GBP cheaper than the GT86, but comes with the torsen limited slip. I wonder if it's the equivalent of the US club spec but at a relatively lower cost.
2022 BRZ Build 2013 FR-S Build |
#686 |
Drives: Red Toaster(Dodge Nitro)
I mostly lurk, still don't own an 86...
| 4th gen ND Mazda MX-5 Miata | Dark | Other Vehicles & General Automotive Discussions | 1392 | 12-16-2021 02:09 PM |
| Twins vs 2016 Miata (ND body style) will be revealed in 15 minutes | glamcem | FR-S / BRZ vs.... | 56 | 09-13-2014 07:11 PM |
| 2016 mazda miata (MX5) reveal 9 PM EST | Ernie L | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-03-2014 09:41 PM |
| Motor Trend Car of the Year... | Dorb | BRZ First-Gen (2012+) — General Topics | 1 | 11-13-2012 08:33 AM |
