#673 |
Cool, that's what I figured, just wanted to clarify.
#674 |
#675 |
#676 | |
- andy |
#677 | |
Going to 400 lb springs might require a revalve in the front. In the end you spend a decent amount of money but it would be an awesome set up. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | mokinbird87 (01-21-2014) |
#678 | |
BOXER FR
Drives: WRB BRZ Limited
I have a pretty close friend in Bilstein.. I may ask for some help from their department to see what I can come up with...
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
| The Following 2 Users Say Thank You to mokinbird87 For This Useful Post: | CSG Mike (01-21-2014), Racecomp Engineering (01-21-2014) |
#679 | |
Assuming I've got stickier tires on, what swaybar upgrades / configurations do you specifically recommend to keep balanced handling? All of the aftermarkets I have seen offer varying degrees of stiffness increase over the stock setup. So, should I be looking at front only, or front and back, and if so do I want to increase the stiffness of the front more in comparison to the back? Any recommendations as to specific components would be appreciated as well. |
#680 | |
For swaybars you're going to want bigger front and rear. I do prefer increasing the stiffness a little more up front, especially with an FRS. I recommend our RCE swaybars for most uses except cars with very stiff coilovers. They'd fit the bill nicely for you. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | jvincent (01-23-2014) |
#681 |
Thanks guys.
#682 |
Question about handling. On coilovers, RCE Tarmac 0's specifically, last thread on the front is how low I am (1.3" or so), with 18X9.5's with 245/35's, how can I increase my grip a bit more? I've seen an occasional low trac light when taking some corners hard. Almost feels like I get some slip, could be the tires (Continental ExtremeContact DW's) I've got more of a daily drive camber at 0 in front and -1 in the rear but I will be changing that.
I've got 16MM whiteline bolts to install for the front coils, and SPC LCA's for adjusting the rear already installed. I intend on doing -2 or -2.5 in front and about -1.5 in the rear with 0 toe up front, 1/16 toe-in rear for straight line. What would you suggest I do if my main goal is for grip? Are my wheels/tires too wide? Should I also consider sway bars since I'm on stock? Just looking to improve my handling even further and push my aftermarket parts. Goal being more street friendly with the possibility of seeing a track maybe a few times. For braking, I wanted to know if Stoptech's are good DD pads. Currently using the Hawk's Ceramics and I get a slight squeak on one of the pads. I've got Goodridge SS lines and Motul 5.1 fluid ready to swap in as well. Other brake pad suggestions are welcome as long as they don't kill my street/daily driving. The balance of low dust and good bite seems almost impossible without a tradeoff. |
#683 | |
Braking friction (mu) and dust are almost always inversely related. If you want a street pad with some increased bite and heat capacity, I'd recommend a Carbotech AX6 or Project Mu B-force. Both dust slightly more than stock pads, but offer significantly improved capabilities. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | FR-S Matt (01-23-2014) |
#684 | |
You should be able to get at least -2.0 up front without plates since the front strut is slotted. I run stoptech street pads on my Mini. They're an improvement over the Hawks. Not super aggressive but a good street pad. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | FR-S Matt (01-23-2014) |
#685 | |
| The Following User Says Thank You to FR-S Matt For This Useful Post: | Racecomp Engineering (01-23-2014) |
#686 |
That Guy
Drives: 2013 asphalt FRS MT
Will the GTWORX struts be the same as the B8? What are the differences between the B* and B6? Would there be any point in running the B6 with RCE yellows?
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
