Old 01-27-2016, 12:19 AM   #6819
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by Snyperiflex View Post
I'm planning on picking up a used kit next week, have a question
The previous owner put roughly 1k miles on the kit before he lost a rod, he said it happened because of the tune. He then got the engine built and is now running with the 335 unit.
Thoughts on what I should double-check anyways on the kit, given this information? He had said the tuner could not figure out what was going on with his poor idle (all the info I have about what happened)
210 with intercooler
Can you get your tuner / shop to look at it?
I'd trust the experts.
I like driving!
86 South Africa is offline   Reply With Quote
Old 01-27-2016, 12:43 AM   #6820
Snyperiflex
Snyperiflex's Avatar
Drives: Scion FR-S Release Series 1.0
Hmm I'm going install it myself get it remote tuned by Moto-East. I don't know of any shops that have experience with this kit here
Just looking for pointers on what I should be looking out for with a kit that has blown an engine before (although tune is everything)
Snyperiflex is offline   Reply With Quote
Old 01-27-2016, 01:05 AM   #6821
86 South Africa
Ah! Well that makes it a bit harder... But the tune is definitely a major consideration!
I guess it'll be like buying a second hand car... Check for abnormal wear where you can see it (and check it hasn't been opened up - bolts/scratch marks etc. some clown locally here opened his up and destroyed the laminova core!)
I like driving!
Old 01-28-2016, 01:53 AM   #6822
Aaronimoe
Does anybody have pictures of the blower and manifold separated?
Aaronimoe is offline   Reply With Quote
Old 01-28-2016, 06:47 AM   #6823
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Best one I've got :/
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-28-2016, 08:02 AM   #6824
Aaronimoe
Thank you sir! any tips for taking it off? I want to send one in for a rebuild and am trying to figure out if its as easy as I think it would be.. have you ever taken off the side with the pulley?
If you have anymore pictures Ill take as many as I can get. preferably the underside of the blower, and the TB and pulley side as well.
Aaroncim@gmail.com is my email if it makes it easier.
Old 01-28-2016, 08:09 AM   #6825
Aaronimoe
Is anybody running a 335 on a stock motor?
What are peoples thoughts on running a downtuned 335 on an otherwise stock engine? I would imagine since your running the 335 at a relatively low workload that it should be relatively safe compared to a 210. Would there just be too much torque? please I need all the insight I can get.
I've found a really good deal on a 335 but I only want as much power as an intercooler 210 would provide.
Old 01-28-2016, 09:14 AM   #6826
Dream20b
Y u do dis?
not worth it
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 01-28-2016, 09:51 AM   #6827
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
@moto-mike had previously ran it on their shop car on a non built motor. You have to go oversized pulley to run less boost. There's a spreadsheet a few pages back that will show you what boost levels you can hit the 210/335. For reference, I have the 210 intercooler and basically capped it out at 12psi with a 69mm pulley. Made 256/211.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 01-28-2016, 10:51 AM   #6828
Aaronimoe
Originally Posted by Dream20b View Post
not worth it
Are you referring to the rebuild? could you please elaborate and show me what I may not be considering?
Does anyone have any experience getting a blower rebuilt by BBM?
Old 01-28-2016, 05:20 PM   #6829
Lux
I have running 335 on the stock motor with an 85mm pulley. I only have 3k miles on the supercharge and 72k on the car. The tune is from moto east and runs e85. The fuel and exhaust system has also been upgraded to support the 335. The car is also an auto.
The car is a lot more fun but the stock tires wont stop screaming��. I do plan on building up the motor in a few years unless it lets go before that.
Lux is offline   Reply With Quote
Old 01-28-2016, 05:43 PM   #6830
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Based on my spread sheet I linked earlier, upgrading the 70mm 210 kit to the 85mm 335 kit will give you about 45 more whp or so. This is running off the stock engine, before upgrading internals. There is a lot more left in the 335 supercharger and could go much smaller on the pulley than the 85mm. 210 to 335 is about $2600 before the money you'll get back from selling the 210 back to whoever, so it's not a bad deal considering what you can do later with the 335 vs not being able to go any further with the 210.
If I didn't already have one and was looking to buy one new, I'd get the 335+ kit for the small amount more compared to the 210.
stockysnail is offline   Reply With Quote
Old 01-28-2016, 07:20 PM   #6831
Dream20b
Y u do dis?
Power per dollar on this kit is best spent elsewhere. I have a 210 kit running ~ 280 RWHP and 12.8@110 in the 1/4 mile on 400 treadwear all seasons. If you're not going to build the motor you'll gain about 55-60 WHP and you'll have to upgrade clutch, fueling, etc especially if you want to run e85..
@smudge
Dat Hot Lava Doe
Old 01-28-2016, 07:50 PM   #6832
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
My 335 build is going to be up and running by April at the latest.
Stock engine, 85mm pulley and Moto-East tune. Other components and info are listed on my build thread.
Chad86 is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
