Old 01-18-2016, 01:43 AM   #6805
sam69
Drives: GT 86
What was the maximum boost you got out of it ?
I see 12+ with the 69mm pulley .
sam69 is offline   Reply With Quote
Old 01-19-2016, 10:47 PM   #6806
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
I was roughly 12-12.5 with the 69mm pulley.
Dyno-chart from 93 gas.
Was backed off a little at the top end due to some top-in knock being introduced.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 01-20-2016, 03:19 PM   #6807
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
aaaannnd just like that I'm joining the group with stage 2+delicious flex fuel setup!
Probably be installing on Saturday night! Woohoo!!!
Old 01-20-2016, 04:26 PM   #6808
smudge
Drives: Supercharged GT86
Originally Posted by Harro View Post
So boost levels - Has anyone got a boost curve for the 210 - I've done a search but found nothing.
I've recently had a dyno run and got a boost curve out of it - to say I'm disappointed would be the understatement of the century - but I would like to see some other boost curves before I start flinging shit.
On the 69mm pulley I was seeing exactly 1bar of boost
smudge is offline   Reply With Quote
Old 01-20-2016, 07:22 PM   #6809
Kodename47
Kodename47's Avatar
Drives: UK GT86
Apologies, meant to post this earlier for you, 75mm and 70mm pulley:
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-21-2016, 05:02 PM   #6810
BRZ_F
BRZ_F's Avatar
Drives: 2013 WRB BRZ
Hello all!
I'll most likely be purchasing a used intercooled innovate 210 supercharger for my 2013 BRZ within the next few weeks and looking to go with Moto-East for remote tuning.
I'm in between using the stock 75mm or the raseng 72.5mm pulley for engine/blower longevity. I'll be looking to get a 91 and e85 tune (In LA Propel provide e85 which is consistently above e80).
My only mods are a Gruppe-S UEL header and a K&N drop in air filter. I want to stay on the stock clutch.
Can anyone provide me with approximate numbers for whp and torque that I would be making on 91 and e85 with either pulley.
Thanks!
BRZ_F is offline   Reply With Quote
Old 01-21-2016, 10:27 PM   #6811
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by BRZ_F View Post
Hello all!
Thanks!
Here are the rough numbers on each sized pulley for the 210 and 335 kit and what upgrades are recommended.
https://docs.google.com/spreadsheets...it?usp=sharing
stockysnail is offline   Reply With Quote
The Following 3 Users Say Thank You to stockysnail For This Useful Post:
brybot (03-04-2016), BRZ_F (01-21-2016), Chad86 (01-22-2016)
Old 01-22-2016, 10:21 PM   #6812
jwvand02
Drives: 2013 SWP BRZ Limited
How are you measuring boost? Is the MAP sensor in the logs an accurate way to do so?
jwvand02 is offline   Reply With Quote
Old 01-23-2016, 12:09 AM   #6813
Rifle
Rifle's Avatar
Hello all!
Thanks!
If you're using just e85, go with a 69mm pulley to take full advantage of the timing gains. Sounds like 91 is the best you can get, find a 70mm pulley which can run 91/e85 with the most timing (takes full advantage of all the boost). According to Mike from Moto east when he dynoed my car, with a 69mm pulley you can expect 255-260 with 93 (my results), 275-280 with water meth, 290-295 with e85. Expect less with a bigger pulley
295WHP/220TQ
The Following 2 Users Say Thank You to Rifle For This Useful Post:
brybot (03-09-2016), BRZ_F (01-23-2016)
Old 01-23-2016, 12:10 AM   #6814
Rifle
Rifle's Avatar
That's a pretty good guide. Don't know who's list that is, but with 93 and 69mm pulley I made 260/210 basically.
295WHP/220TQ
Old 01-23-2016, 12:12 AM   #6815
sam69
Drives: GT 86
Measuring boost direct from the manifold to a good quality digital gauge.
There should be a small nipple down under the intake plenum after the TB which is capped off so you can tap straight onto that.
Old 01-23-2016, 01:28 PM   #6816
stockysnail
Just the tip
I made it based on info from my own kit, Moto East's 335 kit, and other posters that posted about their own kits. I'll add the 69mm pulley to the list with your numbers.
Old 01-23-2016, 01:43 PM   #6817
Rifle
Rifle's Avatar
Yeah. It was 256/211 exactly. Dyno tuned from Moto East.
295WHP/220TQ
The Following User Says Thank You to Rifle For This Useful Post:
stockysnail (01-23-2016)
Old 01-27-2016, 12:51 AM   #6818
Snyperiflex
Snyperiflex's Avatar
Drives: Scion FR-S Release Series 1.0
I'm planning on picking up a used kit next week, have a question
The previous owner put roughly 1k miles on the kit before he lost a rod, he said it happened because of the tune. He then got the engine built and is now running with the 335 unit.
Thoughts on what I should double-check anyways on the kit, given this information? He had said the tuner could not figure out what was going on with his poor idle (all the info I have about what happened)
210 with intercooler
Snyperiflex is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
