Old 12-27-2015, 12:17 PM   #6749
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
So my build has been quite interesting. I've put on the blower, thought I spun a bearing - turns out it was a pre-o2 sensor exhaust leaking causing the o2 sensors to lean out (no codes).. just dumped fuel into the oil and caused a bad knock. Pull the blower off, drained the oil, (still thinking it was a spun bearing at this point), and it worked fine with stock tune. No knock, no issues. Ran it for a week just to make sure. And then, there was no issues. Changed the oil again, just to make sure. Put the blow back on, loaded a safer tune (less timing), and have run it with a different header (flange wasn't decked correctly on the first - causing the leak). Car runs great. I'm using a 69mm pulley, which is probably causing me to overspin the blower a bit on the top end, but the power gains were good. With 93 Pump gas, I ran a 256/211 HP/TQ.
Now for some W/M...
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 12-28-2015, 05:44 PM   #6750
Harro
Drives: 2014 Toyota 86
Has anyone used the Motul Gear 300 LS 75W90
https://www.motul.com/au/en/products...r-300-ls-75w90
to replace the supercharger oil?
VI looks very close - and viscosity at 40 Degrees C and 100 Degrees C are similar. The addition of friction modifiers in the motul may be of concern, but I can't see it being a bad thing...
Any opinions?
Harro is offline   Reply With Quote
Old 12-28-2015, 05:45 PM   #6751
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Any opinions?
I use the non-LS version and it works great in the supercharger. I use it in my diff as well as the LS isn't needed in our diff according to many experts on here.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
Harro (12-28-2015)
Old 12-28-2015, 06:59 PM   #6752
Harro
I run the LS version in my diff as I have the type mechanical diff from TRD - without it the clutches in the diff seize up.
There is a difference in Viscosity between the two - the non-LS is closer to the Redline stuff at 40 & 100 degrees C and the viscosity index is much higher on the Gear 300 - maybe a change is in order.
Do you find you need to top it up a fair amount? The stuff I had in there from sprintex mysteriously disappeared - I don't want that happening again...
Old 12-28-2015, 08:34 PM   #6753
stockysnail
Just the tip
I need to top it off every other month or so. Once the time comes to change it completely in about 4k miles, I'll be trying out this stuff from JB Performance instead as someone raved about it.
http://jonbondperformance.com/index....&products_id=1
Old 12-28-2015, 10:15 PM   #6754
Harro
Brilliant, that's the same stuff I'll be using - ordered it yesterday. By the time it gets downunder the Motul should just about be gone again
The Following User Says Thank You to Harro For This Useful Post:
stockysnail (12-28-2015)
Old 12-29-2015, 01:37 AM   #6755
Rifle
Rifle's Avatar
Two things: one, my charger has about 1.7k on her now. What fluid should I buy when I fill it?
Two, have a buddy who has a locked up 210. Ran with low/no oil and the screws binded. Anyone know of a solution and/or rebuild kit/service?
Thanks!
295WHP/220TQ
Old 12-29-2015, 02:20 AM   #6756
stockysnail
Just the tip
Thanks!
Call Sprintex USA
(855) 591-2778
info@sprintexusa.com
Use the oil I posted a couple posts up.
Old 12-29-2015, 03:55 AM   #6757
azynneo
any update on the 210+ blower / trade ins cost blah blah?
azynneo is offline   Reply With Quote
Old 01-02-2016, 01:33 AM   #6758
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Soooooo....whatever happened to the guy who was having his 210 rebuilt/ rotors coated by the Jon Bond supercharger dude?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-04-2016, 09:40 PM   #6759
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
I'm not sure about the rebuild guy. I'll have to ask.
The plus blowers are here and moving out the door. There is no trade-in option. We refer to these as the "SPS" blower.
SprintexUSA is offline   Reply With Quote
Old 01-04-2016, 10:25 PM   #6760
CK_Bladesmith
Drives: Raven FR-S
Do you have a link and or price on the sps blower? Thanks
Old 01-04-2016, 10:39 PM   #6761
SprintexUSA
Drives: 2014 FT86
Full kit prices:
$6,290--335 race kit with SPS blower
$5,295--210 street kit with SPS blower
Old 01-04-2016, 11:30 PM   #6762
Rifle
Rifle's Avatar
If you can check on the rebuild. Appears it was just run low on oil, heated up, and caused the secondary screw (non pulley) to bind. Flat spotted the screw, can see it from the intercooler opening at the bottom. I can only assume the case is a bit chewed, but we haven't opened it up yet.
295WHP/220TQ
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
