Old 03-06-2017, 12:33 AM   #659
zeal86
zeal86's Avatar
Drives:
More progress...
2nd mock-up panel cut and bent from a portion of the .177 thick ABS sheet... no cracking... I was happy about that. Minor adjustment noted.
Mock-up of hinge with 2nd template...
A view of the full 2nd template... I made note of some minor changes and I believe I will be bending the ABS in the next couple of days.
Clamping down the hinge into place...
Reinforcing the underside of the hinge...
Most of the holes drilled...Clecos in place... Mock-up panel also in place...
Holes countersunk...
Everything is coming together nicely... I'm pretty pumped!
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
civicdrivr (03-08-2017), frsvr4 (03-07-2017)
Old 03-06-2017, 08:37 PM   #660
zeal86
zeal86's Avatar
Drives:
Drilled out and countersunk my holes... originally I was going to put the panel on the outside of the hinge but that will not allow the door to lay flat when open... it shouldn't change my previous fitment too much.
before...
After...
Old 03-07-2017, 12:16 AM   #661
zeal86
zeal86's Avatar
Drives:
I received the new Aluminum Coolant Overflow Tank from Mishimoto tonight! Man this thing is pretty! If you have ever seen my engine bay you'd understand why I can gets so excited about such a simple part. The OEM overflow tank is so out of place in my engine bay...it will only get worse as the white plastic yellows over time. Cant wait to install it!
MJones_RB (04-20-2017), weederr33 (03-07-2017)
Old 03-08-2017, 12:49 AM   #662
zeal86
zeal86's Avatar
Drives:
More progress...
Old 03-08-2017, 10:18 PM   #663
zeal86
zeal86's Avatar
Drives:
Drilling the holes for the seat back panel so I can check my angles...
Old 03-09-2017, 07:57 PM   #664
zeal86
zeal86's Avatar
Drives:
Fitment is really good! I still have a few things to adjust and secure but I'm feeling good about what will be the final product...
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
JT.86 (03-09-2017), kravi (03-10-2017), new2subaru (03-11-2017)
Old 03-10-2017, 10:39 PM   #665
zeal86
zeal86's Avatar
Drives:
Another full view...
Formed foam support for the center of the panels...
I'm going to fab a bracket from this template so I can keep the rear supports from moving (mainly forward).
The Following User Says Thank You to zeal86 For This Useful Post:
olsonpg (03-11-2017)
Old 03-11-2017, 11:43 PM   #666
zeal86
zeal86's Avatar
Drives:
I found my fabric today! I had to drive 2.5 hours round trip to pick out up though. It is a suede but looks very close to the OEM alcantara. I would call it a 90-93% match.
Since I am installing Bride seats, the only alcantara in my interior to compare it against is located on my dash so the slight difference will not be easily discernable.
I did find a vinyl that looked a lot like the factory leather in color and texture but I wanted more contrast... so I stayed with the suede. I also purchased some batting.
Old 03-13-2017, 02:52 PM   #667
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by zeal86 View Post
Yeah, it looks really close
Old 03-13-2017, 02:56 PM   #668
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Your attention to detail knows no bounds.
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Kami Speed (03-13-2017), zeal86 (03-13-2017)
Old 03-13-2017, 03:26 PM   #669
arkanist
Drives: 2016 BRZ Limited, Stock
The man lives up to his name.
arkanist is offline   Reply With Quote
The Following User Says Thank You to arkanist For This Useful Post:
zeal86 (03-13-2017)
Old 03-13-2017, 04:23 PM   #670
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
I can attest to this statement.
Kami Speed is offline   Reply With Quote
The Following User Says Thank You to Kami Speed For This Useful Post:
zeal86 (03-13-2017)
Old 03-14-2017, 12:24 AM   #671
zeal86
zeal86's Avatar
Drives:
I added a stabilizing bracket to my rear supports. They were solid from middle down but had some flex back to front on the top side... especially in the forward direction.
I want everything to fit securely with little to no slop so I fabricated a bracket from a template I made. I will most likely integrate the template into my rear support template so that it is all one piece.
Documenting my angles for my write-up later...
Bracket riveted on. Maybe four rivets were too many but it's not going to hurt anything...
Installed... rock solid from middle out which addressed my concern...
ajaxthebetter (04-05-2017)
Old 03-14-2017, 11:01 AM   #672
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Holy sh*t! I love your ride and your attention to detail!
Sent from my SAMSUNG-SM-G930A using Tapatalk
FRS13_ is offline   Reply With Quote
The Following User Says Thank You to FRS13_ For This Useful Post:
zeal86 (03-14-2017)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
