Old 10-05-2016, 08:38 PM   #659
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by cf6mech View Post
Wish somebody would make this for our cars......would of saved me a lot of headaches and many days waking up with a sore back......we are not alone with this issue....http://www.bimmerworld.com/Intake-Fu...ation-Kit.html
IIRC, Full Blown had a dual pump setup. I can't find it on their website, but it might be worth talking to them.
I think Moto East has a surge tank setup to mask the problem with high HP cars. In purely guessing here, but wouldn't a 350hp turbo fa20 drink more than a NA LS? BSFC and all of that, I thought the smaller force fed engine would be less efficient...?
Also, I'm sure Element Tuning has some thing to fix the problem. There is no way in hell they haven't faced this issue and found a way to fix it.
Calum is offline
Old 10-05-2016, 08:40 PM   #660
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
Interesting now I need to go find a parking lot and start doing some serious left hand donuts lol.
I wish i could just replace it with a custom cell (not in the trunk)
Sent from my LGLS991 using Tapatalk
C130NAV is offline
Old 10-05-2016, 08:43 PM   #661
C130NAV
C130NAV's Avatar
A pic for your viewing enjoyment
C130NAV is offline
Old 10-05-2016, 11:15 PM   #662
Zer0
Drives: 2015 frs
Originally Posted by Calum View Post
I hope you're alright, man. What kind of car did you lose?
Also, what does Vorshlag do to the transmission?
89 civic hatch with a JDM sir swap.
Vorshlag knows what to tell the shop who builds it. They developed the thing so I wanted to support the shop.
I'm a little stiff. More concerned about a replacement car than my Heath. I know most people see it different I don't.
Zer0 is offline
Old 10-06-2016, 02:13 AM   #663
cf6mech
Drives: FRS Silver LS1 swapped.
Anything burning E85 will definatly need a higher volume, which most of the high borsepower guys are using.
cf6mech is offline
Old 10-06-2016, 07:47 AM   #664
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
I've been chatting with Element on this problem. I'm boosted and around 1/4 tank the cannister set-up doesn't hold enough fuel to sustain boost. They've employed a dual pump setup by installing a pump in the siphon side of the saddle tank to feed into the canister. They use their ECM to control it, but turn it on when the main pump is running.
I've got a spare pump kicking around that I will be putting in wired directly onto the signal for the pump on the other side of the car. This should help keep the cannister charged better at lower fuel volumes.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline
Old 10-06-2016, 03:56 PM   #665
cf6mech
I originally went passenger saddle pump to driver bucket and also return fuel from engine to bucket with of course bucket pump feeding engine......after thinking about it i decided that wasnt the way to go....i was worried about lower fuel levels and cavitation for that pump on the passenger side once the fuel gets lower as its not feeding anything but the bucket.....fuel helps cool the pump and lubricates impellar, runs dry early pump failure....wasnt sure either how the quantity floats would like it either.
So i went to both pumps feeding engine via a T fitting ensuring they alway have fuel to cool ,.....more than enough as no way it will ever need more draw than whats being pumped. Ideally probably this winter im going to install two small hydromats for each pump on both sides....its going to required dropping the tank and a lot of work.https://www.holley.com/products/fuel_systems/hydramat/
cf6mech is offline
Old 10-06-2016, 05:04 PM   #666
RedFR-s
RedFR-s's Avatar
So instead of the passenger feeding the driver's side they both just feed up to the engine? 2 of the stock pumps would give you like a 500LPH+ rate. Definitely won't run out of fuel like that lol. Would you not still have the canister issue at low fuel levels though, or I guess each pump would only pull 1/2 as much and have twice as long to feed the engine...
I'm going to have to look into setting it up like that.
Andy
RedFR-s is offline
Old 10-06-2016, 08:23 PM   #667
wooly35
Drives: 2014 Scion FR-S LS3
so as long as I keep my fuel tank completely full, I'm good. ha ha ha
2014 scion FR-LS3 lol
wooly35 is offline
Old 10-06-2016, 11:34 PM   #668
cf6mech
Single pump will work great till about half a tank.....atleast in my case.
cf6mech is offline
Old 10-07-2016, 07:48 AM   #669
C130NAV
C130NAV's Avatar
Maybe that's why I have not had issues. Since I'm still in Limp mode on the fuel gauge I usually fill her up no more than 70 miles past half. 😂😂. I got gun shy ran out of fuel one night on the Mass Turnpike.
C130NAV is offline
Old 10-07-2016, 04:18 PM   #670
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
https://www.summitracing.com/search/...fuel-cell-foam
bet that would help
IceFyre13th is offline
Old 10-07-2016, 07:17 PM   #671
cf6mech
Originally Posted by IceFyre13th View Post
Problem with foam is it has to be periodicly replaced and it would definately play havic on the floats......there is floats for each side passenger and driver.
cf6mech is offline
Old 10-08-2016, 06:27 AM   #672
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I've recently blown my boosted FA20 because of fuel starvation below 1/4 tank(drag racing ...LOL), the simplest fix imho is a FBM Walbro 485 In tank kit ( Or the new Radium which i did not get a chance to test) feeding a surge tank.
SmsAlSuwaidi is offline
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 09:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 10:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 05:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 01:19 PM
