Old 03-12-2018, 03:07 PM   #659
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I looked at using expanding foam (although it was the stuff in the can) and was steered away from it by multiple people who have done composites work. They recommended the floral foam as it didn't need as much finishing work and is cheaper.
DustinS is offline   Reply With Quote
Old 03-19-2018, 05:18 PM   #660
DustinS
DustinS's Avatar
That's a close one.
Old 03-20-2018, 01:33 PM   #661
DustinS
DustinS's Avatar
Cold/Rainy Weather sucks. Got a few of the wires extended until I couldn't handle the cold and rain.
Old 03-22-2018, 11:47 AM   #662
DustinS
DustinS's Avatar
More wiring work. I stole the Negative Terminal off my battery and used it to place a terminal in the engine bay. Allows me to keep the battery monitor plug thing on the negative terminal. Not exactly sure if I could delete it, so I would rather keep it.
Pictures are pretty bad as it was cold and dark out as I was finishing up.
Plan is to just bolt the negative terminal on, possibly do the same with the positive terminal with an electrical cut off switch/fuse.
Engine bay positive terminal Finished up. Just need to mount it.
Got the extension harness finished, wrapped, and routed. Need to figure out that Small harness for the fog lights.
Wheel Speed sensor wires exit into frame:
Ignore red wire, but the speed sensor wiring pops out right where it needs to.
Then harness continues behind the headlights. Still needs attached, will do that once I am 100% sure everything works as it should.
Used the nice fabric OEM-esque tape on some of the wiring. I really like the look.
The engine bay is filthy and needs a good deep clean, Hope to do that before engine gets back from Texas Speed. Next is the custom make some wheel covers so the tires quite throwing stuff into the engine bay.
Old 03-26-2018, 03:30 PM   #663
DustinS
DustinS's Avatar
After Fighting flickr uploader all morning, I have some updates to post.
Got the speed sensor wire finished:
Mounting. Needs Painted Black
Currently trying to figure out a way to make this look a little cleaner, though it won't really be seen...
Got the manifold flanges cut off and ready for the engine to be returned and installed.
Radiator Mounting finished up, and factory fan shroud mounts removed.
I also started on a side project. Wanted to clean up the area around the fuse box...
Trying to decide where to go from there. I have a few people telling me to smooth it out and make a mold for it, then make it out of carbon. I am contemplating just making it smooth and painting it satin black.
Old 04-11-2018, 10:49 AM   #664
DustinS
DustinS's Avatar
Engine is still waiting to be shipped...
Got the Expansion tank mounted. I wish the ports were on opposite sides, but I will make them work. I can/will move it up later if need be.
Custom Bracket. Could be a bit cleaner, but oh well. Most likely paint it black.
This will most likely be changed to a -12an fitting. I will run AN lines for the heater lines to make it look nice.
Contemplating removing the cross brace bracket as they don't fit with the LS anyway. I'll make a new bracket when I design new cross braces.
Old 04-12-2018, 12:11 PM   #665
DustinS
DustinS's Avatar
Got the positive terminal installed and brackets painted. Finished up for now.
Old 04-12-2018, 04:25 PM   #666
DustinS
DustinS's Avatar
Old 04-13-2018, 01:31 PM   #667
DustinS
DustinS's Avatar
Well I got a tiny bit of work done yesterday. I popped open the fuel tank to see if I could figure out my fueling issue. Runs out of fuel around 1/4 tank. I couldn't find anything. Thought the tank was SUPER full. Seems my car always breaks/gets taken off the road right after filling the tank.
Ground Strap finished up
I am going to make a few of these to ground the engine and alternator to the frame. I also got the AMP power wire removed as I no longer need it to go to the front of the car.
Engine will be here Tuesday. I think we will just try and stab it in tuesday after work as well. Shouldn't be too much longer till it's running. Though I still have a lot parts to order haha.
Old 04-16-2018, 04:15 PM   #668
DustinS
DustinS's Avatar
Some new STI rear hubs. No longer running 5x100 Hubs.
Old 04-17-2018, 10:34 AM   #669
DustinS
DustinS's Avatar
Battery Relocation pretty much finished up.
Carefully drilled out some rivnuts as mounts for the battery ties. Still need a main fuse on this side of the positive wire. Using the old battery tray holder as the Battery bracket as it will keep the trunk mat thing from falling on the battery.
While I was down there working on the battery mounts I found the left rear shock has blown pretty bad.
Edit:
Woo! Ready to get this in.
I am going to see about getting the oil pan modified today before dropping it in. This would get rid of the oil bypass valve for the DOD and allow me to run the front sway bar.
Old 04-17-2018, 03:02 PM   #670
DustinS
DustinS's Avatar
They even included break in oil!
Old 04-18-2018, 10:49 AM   #671
DustinS
DustinS's Avatar
Took the oil pan off as I needed (or so I thought) to remove and cap the oil bypass valve used for the DOD cars, and I was going to cut the pan for sway bar and have it welded shut. I didn't get pictures of the cutting, but I only ended up cutting the pan a bit, but not enough that I needed to get it welded up. I decided to leave that for a future project.
Texas Speed was kind enough to cap it for me:
After a bit of fiddling and a trip to the autoparts store for some new hardware for the engine mounts. We were able to get it in. Though I can't get one of the transmission mount bolts in. I still need to mess with that.
Forgot how much room there is for everything. Expansion tank may be moved upwards a tad.
I am trying to decide if I want to try and mount the wiring harness in the gap in the trans tunnel. Will clean up the firewall, but may cause issues with heat, and rubbing. I have plenty of time to figure that out though.
Old 04-18-2018, 02:28 PM   #672
DustinS
DustinS's Avatar
Nice little package today. Still waiting on the -4 hose and -4 90 degree fitting.
Hose and fittings on right are for the catch can. Running -6an for that. Most likely mount it where the fuse box went.
Got the -4an fittings mocked up for coolant overflow and steam port. I REALLY hate pipe threads. The fact you can see the threads drives me nuts.
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 11:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 12:43 PM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 06:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 01:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 03:50 PM
