#659 |
^^ What exactly wasn't recommended? Raising higher than stock, or adjusting height for the winter?
#660 | |
Drives: Scion FR-S 2013 Raven
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
Am lowered 0.8" front and 1"rear for winter and I live in Québec...it's perfect, it's Just enough to doesn't having any problems... Brake and tires are enough on this car to go at the track.
o= FR-S =o |
#661 |
Drives: SWP BRZ 6MT
#662 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Mikepage (01-21-2014) |
#663 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | utekineir (01-21-2014) |
#664 | |
- Andy |
#665 | |
You could do a 15mm drop or so. - Andy |
#666 | |
Which bushing?
o= FR-S =o |
#667 |
Drives: 2015 WRX
Hmm, I'm running T2s with raceseng rear top hats. I'm only lowered 1" but the top hats raise the mounting point up 2". I know i asked this before I put then on but will this cause issues?
#668 |
BOXER FR
Drives: WRB BRZ Limited
So, I went for a drive in my buddy`s BRZ with the Bilstein PSS. I really really like the dampening quality of the Bilstein, but I am not a fan of the progressive springs. After driving a few different set ups, I think I`m leaning towards a linear 400/400 rate on a mono-tube damper.
main purpose of the car: the car will see 2-3 track events a year, but 90% for spirited daily driving. most importantly, the car will be on extreme performance summer tires such as the Hankook RS3's or Dunlop Direzza's ( i think this is important as tire compound and suspension set up should be in sync). main question: can the bilstein be equipped with Swift coilover springs, or does it only accept OEM style springs? if it does accept coilover springs will the dampening curve cover up to 400lbs? will I mess up all the work that the German engineers put into the kit by switching out the springs? or will I be happy with just camber plate/sway bars/swift spec R springs on the oem shocks for what I want to do with the car? I would say the Bilsteins are almost perfect for my taste, but still just a bit bouncy... I rather be a bit stiffer and have less bobblehead and hit bumps a bit harder.
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#669 | |
We use stiffer springs to keep the geometry in check, but stiffer bars will work too. |
#670 | |
#671 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | mokinbird87 (01-21-2014) |
#672 | |
BOXER FR
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
