Old 11-17-2015, 10:07 AM   #6679
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by stockysnail View Post
You're looking at a very loud car that puts up numbers about 250-260whp. You don't need injectors at all unless you go with e85 or the 335 kit instead.
You don't need the injectors at all, even with E85 on the smaller blower.
Old 11-17-2015, 01:24 PM   #6680
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Yep. I run E85 all day long on stock injectors. About 15k miles so far.
Dustin is offline   Reply With Quote
Old 11-17-2015, 04:10 PM   #6681
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
You using a smaller pulley with your 210? if so perhaps that's why you're not running larger injectors? Regardless I guess it's not 'required but probably recommended in conjunction with a larger fuel pump.
stockysnail is offline   Reply With Quote
Old 11-19-2015, 02:31 PM   #6682
smudge
Drives: Supercharged GT86
Anyone able to post up a dyno plot for a 335 kit on pump gas please?
smudge is offline   Reply With Quote
Old 11-20-2015, 09:43 PM   #6683
iLLDYNASTi
iLLDYNASTi's Avatar
Drives: 2013 DGM BRZ
So Im trying to get my 210 installed and i cant figure out two things. So i came here to ask. First. How do you get the map sensor onto the supercharger(the instructions dont really explain that) Second. Where does the cable for the water pump plug into? The instructions say nothing about what the cable gets connected to just says to attach it to the mount then test it works later. Nothing about what it plugs into.
"Don't ask me...I just work here"
iLLDYNASTi is offline   Reply With Quote
Old 11-21-2015, 02:31 AM   #6684
Dustin
Twin Screw You
Dustin's Avatar
@iLLDYNASTi Map sensor goes onto the black plate that bolts to the intake manifold. Not sure what you mean by "cable for water pump".
Old 11-21-2015, 03:51 AM   #6685
stockysnail
Just the tip
The power to the water pump plugs into one of your port injectors. You may need to bend the tip of the metal connection just a wee bit otherwise it may come loose like mine did then wonder what the hell is going on with your car, break it, fix it, then finally figure out it was only that the plug was a little loose.
The Following User Says Thank You to stockysnail For This Useful Post:
iLLDYNASTi (11-21-2015)
Old 11-21-2015, 11:13 AM   #6686
iLLDYNASTi
iLLDYNASTi's Avatar
I see where it goes, it just doesnt fit there. Unless they send a smaller one or your supposed to mod the stock one which seems like a bad idea.
Old 11-21-2015, 04:22 PM   #6687
smudge
Mapping wasn't as we'd hoped on the 335 and built engine
Issues with the 3bar MAP sensor not liking the Sprintex/ECUTEK setup which is the same for Mike @ Moto East and a few others after we read into it, so ECUTEK are looking into that for Mark, and the IAT's are very, very high even on a 15 second dyno run
Mark at Abbey Motorsport has worked some great magic so far and I've got a decent map with 7000krpm to play with. The drive home was just insane. Pulls like an absolute train and triple digit speeds come far quicker than I expected. Car will have some more work next week
Old 11-21-2015, 11:14 PM   #6688
Dustin
Twin Screw You
Dustin's Avatar
@iLLDYNASTi, not a great pic but the only 1 I have. Mine installed with no problem. What part is not fitting?
Old 11-21-2015, 11:42 PM   #6689
iLLDYNASTi
iLLDYNASTi's Avatar
@Dustin so the stock map sensor looks in no way like it will fit in the spot on the manifold and the picture in the instructions looks nothing like the stock sensor I have. Does the kit come with a new one and I didn't get it or do I need to modify the existing one?
Old 11-22-2015, 05:58 AM   #6690
Kodename47
Kodename47's Avatar
Drives: UK GT86
Use original, no modification required. Sure you have the MAP sensor and not the MAF or something else?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-22-2015, 12:06 PM   #6691
xjohnx
Grip>Slip
xjohnx's Avatar
I'm good down to 69mm on stock injectors on E85 with Delicious Tune. Actually had larger injectors beforehand but yanked them and put stockers back in. Drivability increased ten fold, much smoother response and zero issues.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
Dustin (11-22-2015), stockysnail (11-22-2015)
Old 11-22-2015, 03:17 PM   #6692
iLLDYNASTi
iLLDYNASTi's Avatar
You know I just might be that dumbass that has the MAF sensor. MAF comes off the intake piping right then the MAP is on the stock manifold right?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
