Old 03-15-2014, 06:39 PM   #6609
roroskis
Drives: 2014 Subaru BRZ
Originally Posted by extrashaky View Post
I haven't been able to find a phone mount that didn't put the phone in an awkward or stupid place in this car, so I got fed up looking and made one myself out of 18 gauge aluminum. The paint didn't come out all that great, but the crappy bits are mostly hidden, so I'm not going to worry about trying to fix it.
Correct me if I'm wrong, but doesn't Beatsonic do something like this? http://www.beatsonicusa.com/qbf13.html
roroskis is offline   Reply With Quote
Old 03-15-2014, 07:16 PM   #6610
extrashaky
Drives: 2014 BRZ Limited
That's not in the same spot. Mine is mounted a bit closer to the driver alongside the head unit.
That mount might have been acceptable, but until just moments ago I was under the impression that the passenger side airbag popped out from under that cover, and I didn't want it over there where it would become a missile if the airbag deployed. Now that your post prompted me to look at the exploded view in the manual to make sure I wasn't about to say something stupid, I see that I was mistaken.
Meh. The aluminum cost $5, and it's bolted in. I'll keep mine.
Old 03-16-2014, 02:42 AM   #6611
edsbreezy
edsbreezy's Avatar
Drives: 2014 Subaru BRZ Premium - Red
installed my exhaust and replica rear diffuser
edsbreezy is offline   Reply With Quote
The Following 2 Users Say Thank You to edsbreezy For This Useful Post:
Evil Jesus (03-16-2014), Turkish (03-16-2014)
Old 03-16-2014, 12:29 PM   #6612
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
Took it to work today for some maintenance and upgrades. Nameless Overpipe/Frontpipe combo, Mtech shifter springs, TIC aluminum steering rack bushings, Motul and Subaru fluids.
Only catch was I had to remove the stock header!!! Car has 1200 miles on it and one of the studs for the overpipe to header flange was cross threaded from the factory?! Broke right off when I was removing the over pipe so I had to drill it out and replace the stud.
Fluids by aaronlancaster, on Flickr
Very bad cell phone shot of the inside of our BMW/MINI shop.
Shop Life by aaronlancaster, on Flickr
Proof is offline   Reply With Quote
Old 03-16-2014, 01:53 PM   #6613
xoxomichaela
xoxomichaela's Avatar
Drives: 2013 Limited Brz
Lowered and wheel spacers! Name:  ImageUploadedByTapatalk1394992407.835961.jpg
xoxomichaela is offline   Reply With Quote
The Following User Says Thank You to xoxomichaela For This Useful Post:
ericvanderwoodsen (03-19-2014)
Old 03-16-2014, 02:15 PM   #6614
bjun
bjun's Avatar
Drives: white premium brz M/T
Turbocharged.
The gain is done with 6psi on 93octane
bjun is offline   Reply With Quote
The Following 6 Users Say Thank You to bjun For This Useful Post:
DaBrz (03-16-2014), ericvanderwoodsen (03-19-2014), Husker BRZ (03-16-2014), Proof (03-16-2014), xoxomichaela (03-20-2014), zinzan (03-16-2014)
Old 03-16-2014, 04:03 PM   #6615
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Round two of painting my rear diffuser is going a lot better, patience is definitely key. I still have a couple blemishes but I believe they'll be far less noticeable once clear coat is applied and mounted to the vehicle! I'll have pics once paint dries to the touch.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 03-16-2014, 05:16 PM   #6616
Turkish
Serial Cone Killer
Turkish's Avatar
That is a @GrimmSpeed WRB rattle can photobombing the pictures of the diffuser!
... his name is...
C'THULHU
The Following User Says Thank You to Turkish For This Useful Post:
Old 03-16-2014, 05:41 PM   #6617
d3lirious
d3lirious's Avatar
Drives: brz
keen to see how that turns out!!
d3lirious is offline   Reply With Quote
Old 03-16-2014, 07:18 PM   #6618
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Washed her Name:  ImageUploadedByTapatalk1395011893.080375.jpg
The Following 2 Users Say Thank You to ChandlerSwyng For This Useful Post:
ericvanderwoodsen (03-19-2014), xoxomichaela (03-20-2014)
Old 03-16-2014, 08:03 PM   #6619
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
Installed my Air Lift Performance Digital V2 kit this weekend. Finished up the wiring zip ties today and calibration. Hard parked (in picture) is probably 3 - 3 1/2" lower than stock height is guess? I never measured. It's low though, haha.
Overall it was a relatively easy install. Still gotta build a false floor type setup of sorts for the compressor and manifold but it's halfway clean in the trunk right now.
The front tires are about 1/16" from the fender liner and rear tires are about 1" from them. If I removed them or got them super hot and "formed" them up further I could easily get another 1" of drop. Even then I'd still have nothing underneath touching the ground which rules.
Now to get my final heights set, all torque specs rechecked, and 4 wheel alignment on Tuesday!
AdamBomb518 is offline   Reply With Quote
The Following User Says Thank You to AdamBomb518 For This Useful Post:
ChandlerSwyng (03-16-2014)
Old 03-16-2014, 08:04 PM   #6620
ChandlerSwyng
Looks fucking sinister I love it
The Following User Says Thank You to ChandlerSwyng For This Useful Post:
AdamBomb518 (03-16-2014)
Old 03-16-2014, 08:08 PM   #6621
AdamBomb518
Stealth ***e
Thanks dude! I'm so happy with it. Black everything!!!
Old 03-16-2014, 08:15 PM   #6622
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Perrin Cold Air Intake, Perrin Inlet Hose, patched cracked fiberglass on the bumper... Busy weekend, but getting ready for a HPDE.
milhouse is offline   Reply With Quote
