Old 02-27-2018, 10:29 PM   #645
fika84
fika84's Avatar
Originally Posted by churchx View Post
It's easy to get such compression. Just swap in cummins diesel
If they made a boxer diesel, I would be allllll over it.
fika84 is offline   Reply With Quote
Old 03-06-2018, 01:44 PM   #646
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
They do make a boxer diesel. Although getting one from overseas is probably not easy.
Sent from my P008 using Tapatalk
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
Old 03-06-2018, 01:58 PM   #647
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by cyde01 View Post
Even if 14:1 or 15:1 comp were possible, you gotta ask yourself how much more hp you're even gonna make over an already sky high 13:1 or 13.5:1 ratio. You're risking a lot for minimal gains imo.
Why minimal gains? The motor is compressing more air and fuel.
Granted the Civic was like bore n stroked n sleeved to 2.5L n had a motec system n valve work n e85 n everything, but doing 11.3 @124 and 330whp is good stuff. Could it be done with less money with FI? Yes but if someone wants to pony up the cash then it is their build, and I wouldn’t mind seeing it.
Old 03-07-2018, 02:10 AM   #648
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
I'm saying minimal compared to an already sky high comp like celek's 13:1 ratio, and minimal compared to the extreme risk you're subjecting your engine to. That civic makes a lot of hp, but dare i say it would still make a lot of hp with the comp lowered to 13:1. Most of the gains it's making are coming from elsewhere.
cyde01 is offline   Reply With Quote
Old 03-07-2018, 11:43 AM   #649
Irace86.2.0
He over-bored the k24 from an Acura TSX to 2.5L. Unless he went with super light pistons and rods to get the redline significantly higher, it was likely low compared to the k20, which is why horsepower was about the same between the k20 and k24 (just the torque significantly improved). I feel like most of the gains are coming from the compression and e85 then flow of the head/cams, larger throttle body and exhaust, which is why he needs to rev it out so much to extract that peak hp. He probably did raise the redline because vtech doesn't kit in until 6800rpms, but I would still argue it was in the compression ratio.
Old 03-07-2018, 01:41 PM   #650
cyde01
cyde01's Avatar
i still doubt that lowering that specific build from 14:1 to 13:1 would decrease the power by much. but you know what it seems like neither of us are familiar enough with this k24 build anyway and even if we were it's an apples to oranges comparison.
but back to celek's build. celek is already running an extremely high 13:1 ratio. 14:1 is not that high of a bump compared to 13:1, even though detonation risk is significantly higher. on top of that, you got the law of diminishing returns due to heat and friction. putting the civic aside, if celek raised comp from 13:1 to 14:1, do you really think that he would make anything more than minimal gains? for that much more detonation risk?
Old 03-07-2018, 06:58 PM   #651
Irace86.2.0
I don’t know what the detonation risk is on E85 to comment.
Old 03-09-2018, 11:33 AM   #652
Voltwings
Drives: In the market for an 86 twin
So first and foremost i do not have have an 86 twin, i have just been lurking this forum and trying to learn what i can about this platform as i consider an 86 for my next HPDE car.
Without getting too off topic, i do have years of tracking and recreational tuning experience and this seems like a fun topic to become involved in.
With regards to compression, we're going to do some ricer math here. All else equal, 1 point of compression is going to give you about a 4% bump in power. Assuming this build will make 250 whp peak at 13:1, you could expect about 260 whp peak going 14:1. Now, keep in mind, that is a percentage gain, which means given the very linear power band of this engine i would expect curve gains to be minimal in the majority of the powerband? Yes, 3, 5, 7... over the whole curve is nothing to scoff at, but that "all else equal" is a very big caveat, and increasing compression brings in some other draw backs as others have mentioned.
Now, onto the E85 issue. I have DI tuning experience and on my personal vehicle went down to as little as 2 gallons of E85 in a 16 gallon tank and still had impressive knock resistance. E85 in direct injection applications has an effective octane of about 160, which is why you see a lot of times DI cars are tuned on E85 blends. You do not need large amounts of E85, really anything over 25% (common referred to as E30 or E33) is unnecessary, so you may as well use as little as needed and keep the head room.
At any rate, that is my .02 to this discussion, i'll go back to lurking.
Voltwings is offline   Reply With Quote
Old 03-09-2018, 01:33 PM   #653
churchx
churchx's Avatar
Drives: 2014 GT86
Octane number of 160 for E85? Wasn't it rather around 110?
Old 03-09-2018, 02:34 PM   #654
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Subaru is not developing the diesel engine anymore.
Old 03-09-2018, 02:40 PM   #655
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
there are heat of vaporization benefits to E85, which would be more significant in a DI engine compared to PI, but i doubt they are as drastic as an effective octane number of 160
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 03-09-2018, 02:59 PM   #656
Voltwings
A computational model is used in
this paper to determine the knock resistance and effective octane number of these alcohol
fuels when they are directly injected. The model indicates that the effective octane
numbers are around 160 for ethanol and 180 for methanol.
Taken from:
https://energy.mit.edu/wp-content/up...-08-001-RP.pdf
I started tuning in ... 2011, so it has been several years since i have read this article.
Old 03-09-2018, 04:13 PM   #657
Code Monkey
Drives: Subaru BRZ
Originally Posted by Voltwings View Post
So first and foremost....
Hello stranger.
Code Monkey is offline   Reply With Quote
Old 03-09-2018, 04:36 PM   #658
Voltwings
Originally Posted by Code Monkey View Post
Hello stranger.
Oh shit haha, sending you a PM.
/threadjack
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
