Old 10-10-2015, 05:38 PM   #645
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by moto-mike View Post
Good catch.
A few tidbits here as we're tearing down into a 3rd FA20 just in the last 4 weeks...
2014/07 appears to be the cutoff for when subaru had a field day and made some major changes to the FA20. Valves, valve stem seals, rocker oilers, rockers all appear to have changes right around there (though could have been in steps). We still have to measure the 3rd fa20 (15 wrx) to see where they left off there, but clearly subaru had enough reason to change around the whole head specification. While we can't speculate exactly what the reasons may be, I think it is fair to say that the later motors have had some additional input in regards to what the engineers think is a better approach.
FYI for those doing this themselves, the VIN based parts lookup is not accurate here. Valve lenghts, stem seal bore, and rocker specs need to be measured.
If anyone is curious about this, one of those is mine thanks to what appeared to possibly be oiling issues.
Luckrider is offline   Reply With Quote
The Following 2 Users Say Thank You to Luckrider For This Useful Post:
Calum (10-10-2015), sato (10-10-2015)
Old 10-11-2015, 02:48 AM   #646
JB86'd
JB86'd's Avatar
Drives: JAWS
@Nigelr32 what is the MFG date on your door panel for your 2014? Curious as I have a '14 manufactured in 08/13, wonder if I have these changes or not.
Old 10-11-2015, 02:53 AM   #647
Ultramaroon
not playing cards
Ultramaroon's Avatar
I want to pre-emptively tear into mine. :/
sato (10-13-2015)
Old 10-14-2015, 01:39 PM   #648
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
So is anyone posting to this thread running an element tuning built motor?
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 10-14-2015, 01:42 PM   #649
Luckrider
Luckrider's Avatar
I couldn't afford one when my engine went
Old 10-14-2015, 01:50 PM   #650
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
Element didn't build my motor but im running their "big valve head" package on my built motor
Sent from my SGH-T999 using Tapatalk
BRZGM3 is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZGM3 For This Useful Post:
chaoskaze (10-20-2015), Darryljr11 (10-14-2015)
Old 10-14-2015, 01:57 PM   #651
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
My car was built 12/13 mate.
Nigelr32 is offline   Reply With Quote
The Following User Says Thank You to Nigelr32 For This Useful Post:
JB86'd (10-14-2015)
Old 10-15-2015, 01:06 PM   #652
markitect
Drives: Scion FRS
Originally Posted by solidONE View Post
That's it.. I'm going to trade my '13 FRS in for a '15 BRZ.
That's one of the reasons I leased my 13, and now happily own a 15.
markitect is offline   Reply With Quote
The Following User Says Thank You to markitect For This Useful Post:
solidONE (10-15-2015)
Old 10-15-2015, 03:02 PM   #653
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
That's pretty smart.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
sato (10-15-2015)
Old 11-20-2015, 09:35 AM   #654
GT86_PRAGUE
Drives: GT86
Does anyone know if it is safe to remove stock oil pressure switch? I need a place where to put analog oil temp sensor. I have extra oil pressure in galley plug. I also have Perrin oil cooler and I am not a fan of putting another oil plate.
So, is the stock oil pressure sender just for the dummy light or is it used by ECU to anything else? Can I remove it without consequences?
I found some threads here where people removed it, but I just want to be sure.
Thanks.
GT86_PRAGUE is offline   Reply With Quote
Old 11-20-2015, 10:37 AM   #655
celek
Resident Gear Head
celek's Avatar
Thanks.
Not at home to look at the Factory manual but usually the switches are used for the dummy light on the dashboard not the ECU if I recall.
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
GT86_PRAGUE (11-20-2015)
Old 11-20-2015, 12:34 PM   #656
Nigelr32
The FA20 has two switches on the oil gallery. either one measures temp and one measures pressure, or one is the light and one is pressure. The stock ECU definitely reads oil pressure, not sure about oil temperature.
Old 11-20-2015, 12:38 PM   #657
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
I'm fairly certain it's the other way around. The switch right by the filter is for the light and then there's a temp sensor right next to it.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
celek (11-20-2015)
Old 11-20-2015, 02:21 PM   #658
LS1M
Drives: 2015 BRZ
The stock pressure switch is to the left as you look at the block. All it does is switch on the dash light at around 2.5 psi. Does not go to the ECU. The sensor on the right is temperature, and it does go to the ECU.
LS1M is offline   Reply With Quote
The Following User Says Thank You to LS1M For This Useful Post:
GT86_PRAGUE (11-22-2015)
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 03:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 06:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 01:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-18-2013 12:24 AM
