Old 04-28-2020, 04:32 PM   #645
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
quik1987 is offline   Reply With Quote
The Following User Says Thank You to quik1987 For This Useful Post:
JesseG (06-19-2020)
Old 07-01-2020, 02:53 PM   #646
rixter145
Sleep Chomper
rixter145's Avatar
ToG 3" Titanium Exhaust
https://www.facebook.com/Rixteryo/vi...9871937198294/
rixter145 is offline   Reply With Quote
Old 10-09-2020, 05:38 AM   #647
tweedbean
tweedbean's Avatar
Drives: White GT86
I thought I would post up my exhaust setup for reference. I had the Invidia N1 exhaust fitted, while there I decided to have the following exhaust setup as I had all the parts in the garage:
N/A Engine > Borla UEL(Already fitted) > Milltek Overpipe > TD Decat front pipe > Invidia Resonated Midpipe > Invidia N1 back boxes
I would say this is on the extreme level of volume, especially on cold start which will need to be mapped out at some point, even I can admit cold start sounds awful. But once that drops, its has a nice tick over burble, then when you put your foot down it has a very deep tone with that Subaru rumble, I would say it sounds exactly like an Impreza STI minus the turbo noises. This setup isn't for the faint hearted but this car is a toy for me, I dont have a commute, I have 3 other cars to drive if I need something more sensible, so the noise doesnt bother me in the slightest, I love it.
I removed my rear diffuser lip to make it easier for the garage to fit the exhaust, so I need to refit that, also its going to take some getting used to seeing the angled tips that point to the sides, as per the design:
Invidia N1 fitted by James Baker, on Flickr
Here is a quick sound clip, so drastically different from stock, its not for everyone. I wanted that UEL rumble and I certainly got that:
A comparison between stock and this setup if you need a reminder:
At motorway speeds, it is very noisy, it may not have helped I had the rear seats flat as I had the stock exhaust system in the car, which does fit Will let you know once I close those seats to see if it makes much of a difference. As part of my audio upgrade I will be covering the boot and rear seat area with Silent Coat 3mm which should help reduce that noise in the cabin and improve the audio setup.
tweedbean is offline   Reply With Quote
Old 10-10-2020, 06:38 PM   #648
smoke86
Drives: smoke Toyota 86
Originally Posted by Glitchy86 View Post
Hey guys hopefully I'm in the right thread.
I'm saving up to get a catback in a month or two.
I like deep sound exhaust I have been watching so many videos of different catbacks and has narrow it down to these 3.
Greddy evo gt
Invidia N2
Borla S (something not sure about the name)
I know the sound on the video on YT are not very accurate and sadly not many 86's around where I live (Saudi Arabia).
Based of YT videos I like the Greddy's sound the most but I'm so afraid about how low the exhaust is. I'll be installing new wheels and will be installing the Eibach pro kit. Will the Greddy evo gt be scraping every where I go? Or it won't be that much of a difference with 1" drop. I'm worried the most about angled "roads" like going up in the parking lot....etc.
As for the Invidia N2 I'm not sure if the sound of it is very deep like the greddy or borla, some videos shows it as a deep sounding exhaust and some not. If you have one or heard one pls share your thoughts.
Finally the Borla which I like how deep the sound of it but it seems very quiet from the videos I've seen, again if you have one or heard one IRL please share your thoughts.
Your help is appreciated, Thanks in advance.
Sent from my SM-G975F using Tapatalk
I’d check out the Perrin 2.5 inch resonated. I have zero drone. You hear it when you’re on it and when you’re cruising it behaves like a gentleman
That’s mine.
smoke86 is offline   Reply With Quote
Old 12-23-2020, 12:56 PM   #649
D20Z
Drives: 20 BRZ
BRZ STi Sports Exhaust
D20Z is offline   Reply With Quote
The Following User Says Thank You to D20Z For This Useful Post:
RToyo86 (12-23-2020)
Old 12-23-2020, 02:40 PM   #650
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I want the sti axleback just for the double walled tips.
The Following User Says Thank You to RToyo86 For This Useful Post:
gpvecchi (12-23-2020)
Old 04-14-2021, 09:08 PM   #651
Tormenta
Drives: Fr-s
hello FRS team,
Here is my fully built FA20 with turbo kit (partial see link for details), with ECUTEK down and mid pipes etc.
If in Houston LMK instead of shipping we can meet and help install it.
https://www.ebay.com/itm/164618578080
thank you
Tormenta is offline   Reply With Quote
Old 08-21-2021, 03:00 PM   #652
series.trackday
series.trackday's Avatar
Drives: '17 Subaru BRZ series.Yellow
I'm just going to throw this in here, because I was searching for the answer in the thread and found incorrect info:
The HKS Hi-Power Spec-L version 2 is significantly quieter than the TRD Sports exhaust. Less/no drone, and also lighter.
series.trackday is offline   Reply With Quote
Old 02-16-2022, 03:49 AM   #653
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Sound levels of Gruppe-S catless UEL, HKS dual resonator front pipe, & stock catback setup.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
The Following User Says Thank You to sygfrid For This Useful Post:
RToyo86 (02-16-2022)
Old 02-16-2022, 03:54 AM   #654
sygfrid
FT8Syg
sygfrid's Avatar
FT86 Speed Factory catted UEL & '19 TRD SE cat back w/ mid pipe wrapped in DEI Form-A-Shield to muffle some of the pipe's frequencies.
Sent from my SM-G781W using Tapatalk
Old 02-17-2022, 02:46 PM   #655
norcalpb
norcalpb's Avatar
RevWorks UEL header, Nameless front pipe/op combo, Greddy Supreme SP catback exhaust.
HKS EL Header, stock frontpipe/op, Perrin 2.5” resonated catback.
The Following User Says Thank You to norcalpb For This Useful Post:
RToyo86 (03-13-2022)
Old 03-13-2022, 10:59 AM   #656
RToyo86
RToyo86's Avatar
Gruppe-s header and overpipe, stock front pipe, Greddy SP catback
Setup drones a bit from 1500-2700rpm.
Old 03-16-2022, 05:35 AM   #657
sygfrid
FT8Syg
sygfrid's Avatar
Cold start levels of STi Performance Muffler, Gruppe-S catless UEL, HKS dual resonator front pipe, stock mid pipe, & Ecutek-tuned. Ambient temp of 5C, & the BRZ was parked for 2 days.
Old 12-08-2022, 12:08 PM   #658
ohmikegoodness
Drives: 2018 Crystal White Pearl BRZ
HKS Hi Power V2. With JDL UEL, my fave
ohmikegoodness is offline   Reply With Quote
LIGHTNING RED BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 409 03-01-2025 11:28 AM
FIRESTORM FR-S Compilation DarrenDriven FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1294 10-23-2023 03:57 PM
ARGENTO FR-S Compilation DarrenDriven FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 565 09-28-2022 11:42 PM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
