Old 01-24-2014, 06:32 PM   #645
husker741
Originally Posted by Fett4Real View Post
They said the heat shield wouldn't fit but the under tray would.
Sent from my SCH-I545 using Tapatalk
Yup. I'm probably going to just wrap mine. Or see if they offer some coating options.
husker741 is offline
Old 01-24-2014, 06:33 PM   #646
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
They're offering coating pretty sure. Wrapping will decrease the life of the header.
Fett4Real is offline
Old 01-24-2014, 06:36 PM   #647
husker741
Awhile back they said that the coating will be more than they thought, if I remember correctly.
Old 01-24-2014, 06:38 PM   #648
husker741
Edit: here is the post http://www.ft86club.com/forums/showp...&postcount=446
Old 01-24-2014, 09:30 PM   #649
uRBAN_Metal
Drives: '13 BRZ
You guys may want to check this out
http://ft86speedfactory.com/ft86-cat...ader-1389.html
uRBAN_Metal is offline
Old 01-24-2014, 09:43 PM   #650
JHarperFRS
JHarperFRS's Avatar
Drives: 2013 Scion FR-S "White Out"
@FT-86 SpeedFactory
I see that you guys didn't waste any time putting the Un-catted UEL header up for sale...How many are available, or are they just built upon order ? Hopefully the Catted UEL will be released, soon....because I need it, badly !!!
JHarperFRS is offline
Old 01-24-2014, 11:09 PM   #651
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
I am uniterested by this link....give me a catted header MEOW!
shaunsweeney is offline
Old 01-24-2014, 11:12 PM   #652
shaunsweeney
The Grimmspeed gaskets are a very nice touch!
Old 01-25-2014, 09:05 AM   #653
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I have a new curiosity. Regardless of what I put on my car it will be getting a tune. I originally thought I wanted a catted UEL header because that's what it has stock, and I wanted no issues. People say that it will throw a CEL without a tune without a cat, but that's not an issue if you get it tuned, right? Is there any reason to get the catted version when you plan on tuning the car? Is there something negative about the function of a catless header? I may be interested in the catless version now.
Nevermore is offline
Old 01-25-2014, 09:10 AM   #654
jonbonazza
In some states its illegal to remove any of the cats. If you live in one of these states, then a shop probably wont install it for you. Also, if you live in a state that requires emissions tests, then you may not pass. Other than that the only downside is noise. It *should* perform better than a catted variant.
Sent from my Nexus 4 using Tapatalk
jonbonazza is offline
The Following 2 Users Say Thank You to jonbonazza For This Useful Post:
FT-86 SpeedFactory (01-25-2014), Nevermore (01-25-2014)
Old 01-25-2014, 09:14 AM   #655
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I think I checked this and as far as I can remember, Kentucky has no emission laws. I'll definitely check again. And I don't mind if it's a little louder. I like the way the silver car sounds with the uncatted version so there shouldn't be a problem with the sound. I want that boxer rumble, but if my setup rasps I'll cry haha
Old 01-25-2014, 09:46 AM   #656
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
are there any videos of this header with invidia n1 catback ??
mikeg7827 is offline
Old 01-25-2014, 11:59 AM   #657
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by caffeinejunky View Post
A question I didn't really see brought up in the thread (if it was brought up I apologize). I know you guys said this is just bolt on and go, but did you guys do a comparison between stock tune and tuned? How much gain?
We have done only stock with no tune. Time has been short to get back to the Dyno and do tune testing. We definitely will be and expect more power to be made. Hopefully we can get a nice break in the weather soon.
Originally Posted by shaunsweeney View Post
I never saw the question about heat shielding answered either. Will anything be provided?
The stock shielding won't even come close to fitting. They have insulation in there and it's all the wrong shape anyway. No other sheilding will be provided or should be needed. If you wanted you could always add on the "stick on reflective stuff" to the oil pan, but we stay away from it.
Ceramic coating will also be offered. Still sourcing a good local place to have that done.
If you get a tune a catless one will be just fine. And if you have not cat, you will want a resonated front pipe and a resonated exhaust to keep the rasp out and the rumble rocking.
FT-86 SpeedFactory is offline
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
Nevermore (01-25-2014), shaunsweeney (01-25-2014)
Old 01-25-2014, 12:01 PM   #658
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Will you guys be able to provide any MAF data or any volume changes in air flow?
Assuming someone has a tune for an sc kit, will a new tune be needed? I'm guessing not because this is intended as a bolt on setup requiring no special tune. If that is true, then the volume changes are so miner it essentially mirrors the stock header. Thanks!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
