03-22-2015, 05:03 PM | #645 |
Drives: FRS, Supra, Colorado D, GLC63
My next step to combat the heat and the horrible oil pressure these cars have when they get hot. Trying out some new oil too.
Setrab 25-row oil cooler to upgrade my current 14 row. Non thermostatic sandwich plate will be reused as well. The core will be covered until I'm at the track. |
The Following User Says Thank You to The Racers Line For This Useful Post: | Koa (03-22-2015) |
04-05-2015, 06:14 PM | #646 |
Drives: RX-7 / BRZ
Alright guys, any reason I shouldn't go with an oem coolant base oil cooler setup with my turbo kit? The price difference on the forester kit and the aftermarket ones is much to my liking. With FI my coolant seems steady at 90c/194f which is much lower than the 230 I seem to get lightly driving the car daily for 25-30min. The coolant based oil cooler would also help the turbo warm up in winter which is a plus I guess.
Also taking a bit from the new STi concept. Another way to cut the mustasche... the it would look much worse on the production brz since it isn't beveled as much.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
04-07-2015, 01:41 AM | #647 |
i just installed the seibon DV hood on my car and I'm pleased with how much heat it's letting out. You can literally see the heat radiating out now, and thats barely even pushing the car very hard.
For anyone that doesn't run a vented hood, I would highly recommend it. I was always against vented hoods for cosmetic reasons, but the DV from seibon keeps the factory lines and the two large horizontal slits are large enough to act like a chimney.
The Following 8 Users Say Thank You to protpibe For This Useful Post: | 8686 (04-07-2015), BatStig (05-01-2015), blue cat (04-07-2015), Efferalgan (04-07-2015), GT86_PRAGUE (08-03-2015), Hyper4mance2k (06-01-2015), Sellout (04-09-2015), Subzero (04-07-2015), Xuningshen (04-28-2015) |
04-07-2015, 10:45 AM | #648 |
NASA SpecE30 Racer
I agree on the vented hood. That definitely was going to be the next step on my BRZ. A properly designed one has added venting and downforce benefits.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
04-07-2015, 12:25 PM | #649 |
Drives: 2013 FRS Whiteout
Getting mine sometime this month lol. Do these carbon hoods have holes to attach the gas struts or does the oem hood prop need to be used? I know they're all probably different so I was wondering about the Vis AMS hood.
Btw @protpibe your car is sick.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
The Following User Says Thank You to yomny For This Useful Post: | protpibe (04-07-2015) |
04-07-2015, 02:49 PM | #650 | |
And thanks for the compliment
04-07-2015, 02:53 PM | #651 | |
04-07-2015, 05:54 PM | #652 | |
Drives: Toyota GT 86
04-07-2015, 05:56 PM | #653 |
They work fine. The seibon actually weighs more than the oem hood
The Following User Says Thank You to protpibe For This Useful Post: | Efferalgan (04-08-2015) |
04-09-2015, 07:16 PM | #654 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
04-17-2015, 08:06 AM | #655 |
Just installed my AMS hood.. carbon hoods are not my favorite look but it does well at releasing the heat and its the only one that I know of that has rain guards as it does rain a lot here in Miami
04-17-2015, 09:36 AM | #656 |
Hot Lava 6MT
Drives: Hot Lava FR-S
The Following User Says Thank You to crazyfrenchbiker For This Useful Post: | continuecrushing (04-17-2015) |
04-17-2015, 10:45 AM | #657 |
Drives:
Ya ill let you guys know how big of a difference the hood vents make. The fender vents are not for heat. They are for relieving high pressure lift in the wheel wells
04-17-2015, 06:01 PM | #658 |
Drives: 2013 Black FR-S
You guys must like spending money...
We have solved our FI heat issues with a large oil cooler core mounted in the center in front of the radiator/condenser. 0 other modifications. 0 body work. 0 ducting. 0 aftermarket fan shrouds. 0 aftermarket fans. 0 crash beam delete. 0 anything else. Stock Radiator. Skid plate in place and un-modified. https://www.google.com/webhp?sourcei...w%20series%209 Max temps: 210 F coolant, 218 F oil after 25 mins of hot laps at multiple tracks in winter and in summer. 60+ psi oil pressure to redline. 5w30. 2 cars with this setup have been running this for a year with 15+ track days.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post: | fred_boosted (11-01-2015), mkivsoopra (04-17-2015) |
Similar Threads | ||||
any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
